NEC model NW-452-keeps stopping and showing LE -manual says check clothes in tub to see if collected on one side so I removed them-also is washer on uneven floor-no its worked fine for 3 years-is the lid open- no- Problem did start when I tried to wash some quite heavy and bulky bathroom mats and it may have unbalanced bowl but Ive removed them and tried to run machine wash on every setting but lamp reverts to LE and it beeps and stops
  • philcuthbert Oct 17, 2010
    OK Ive done everything you suggest but no luck....Ive got a machine full of water ...and clothes...can you recommend a repairer in my area ...Devonport...and if necessary replace the washer...good grief ..its only 4 years old.....and I dont use it much....I live alone as a 60 plus man...so its not has if its been used for a family...its obviously a **** machine....can you recommend a better one....of course without any responsibility..by the way...your response came through through the spam box...something wrong....I dont usually even look at that box..I would certainly look at using your service again..Ive got some other electrical...TV..computer...fridge...Bose system...and more problems but resonses are not going to be found yby me if they come through the spam system
    Phil
    No Devomprt Auckand New Zealand
  • 10,515 Answers
To start with, this is a common problem on these washers. There could be many reasons for the same. Disconnect the power supply for few minutes, say 15 minutes and then turn on the machine. If the same error display is there, it could be a bad news.
Check and make sure that the lid switch is fine.Behind the lid left hand side facing from the front of the machine is a small cover, a spring connected to the lid will rust out over time, so you need to check those. LE display indicates that there's a problem with the motor circuit. Testing the motor circuit components is best done by a profession service person, using the correct test procedures. This display (LE) indicates that the problem could be the control board, the motor itself, or both.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Oct 14, 2010
  • taran_2005
    taran_2005 Oct 17, 2010
    Thanks for your response!!
    Is that Davenport - Florida?
    Kindly mention the state so that i could try to find out names of few repair shops.
    Let me know,so that we could proceed.
    Hope i helped you.
I am Looking for the meaning to eror code LE on my washing machine it is an nec model No NW 452
According to what's written in the manual...
'LE' will light up if the machine is unbalanced or the lid is open. This can be corrected by following operation: WATER SUPPLYfi RINSEfi DRAIN. However if the unbalanced condition is unchanged despite repeating the above operation, the lamp 'UE' will light up, and the buzzer will sound to indicate a problem.
Jan 13, 2011 | Washing Machines
Nec nw-452 washing maching gives le message after filling with water? any help?
The lid switch is faulty and needs to be replaced or bypassed.
Sep 28, 2010 | Washing Machines
NEC nw-452 coming up with LE fault.
LE means the lid is up. If it's down try lifting it up
Sep 09, 2010 | Washing Machines
NEC nw-452 coming up with LE fault. How do i fix it?
Jun 21, 2010 | Washing Machines
I also have an NEC NW-452 Washing Machine,it has stopped working completely,doesn't power-up at all,the User Manual troubleshooting guide is no help at all,I tested it it with a Digital Multimeter to see...
take the top off and follow the mains cable to where the cable is connected in the terminal block it could have come loose or the cable itself is at fault check the wire from the plug terminals to the terminal block eric
Dec 27, 2017 | Washing Machines
NEC NW-452 Washing Machine will not run a Hot Wash
by memory it is located at the lop of unit, where u attach the inlet hoses 2 the machine. u need to remove inlet hoses first with water turned off, then undo 2 screws at back of washer holding plastic panel that covers water valves and electics. it unclips off, i always have trouble myself. once u have that panel off remove wires to hot valve ( that is the 1 that had the hot water hose attached to it) put your tester on the terminals. if u get a different continuity reading compared to your cold it is faulty. if it is the same your computer at the front of unit is faulty.see how u go but remember turn off the power b4 u work on it! dont want any acciedents. please reply back for more help. good luck!
Mar 10, 2010 | Washing Machines
FTW445ges2 Washer won't drain, buzzes during drain cycle
Hi...
You need to check this parts.
Inspect the drain hose for kinks
Test the timer control
Test the lid switch(some models)
Inspect the water pump
Inspect the driver belt(belt drive only)
Inspect the motor coupler
It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump.
It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.
It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems:
  • If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
  • If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Hope it will help you.
Regards
ICmanServer
Aug 01, 2009 | Frigidaire GLTF2940ES Front Load Washer
Washing Machines Logo
126 people viewed this question
Top Washing Machines Experts
