Question about Whirlpool Kitchen Ranges
As i'm baking oven temp keeps rising does not shut off.
  • 132 Answers
I think mabey your thermastat is bad.
Posted on Oct 14, 2010
Oven won't pre-heat or reach bake temp?
Could be the oven thermostat, that's the long skinny tube with the thin copper pipe coming off it follow it back to the oven knob. Test it by putting a putting an oven thermometer in and compare the difference they only cost a few dollars at good home ware shops.
May 07, 2014 | Maytag MGR5751AD Gas Kitchen Range
RF214LXTS 0 I have a whirlpool stove, have power on both incoming legs. the top works fine, but the bake and broil elements in the oven dont work. the saftey fuse on the back seems to ohm out good as...
The way power typically is supplied to the bake/broil elements is that directly off the terminal block 120volts ac is supplied directly to the elements at all times and when the touch pad is pushed a relay on the clock/eoc (electronic oven control) will close and supply 120vac so the element has 240vac to heat. you should be able to see the wire coming directly off the terminal block where the cord from the house wireing connects to,going directly to the elements and as stated above theother 120 vac from the relay to the elements (their is 2 relays,one for bake and one for broil)
As far as testing the oven sensor(temp probe) at room temp the ohms reading should be 1060-1100 ohms and as the tempature rise the ohms rise so to test it verify is 1060-1100 at room temp then heating it usinga blow dryer,match or cigarette lighter and the ohms should rise as it gets hotter and drop when its cooling
Good luck,i hope this helps and if it does help please give me 4 thumbs up
Gene
Jul 27, 2011 | Whirlpool Ovens
Pilot light stays lit but oven will not stay lit
I would be interested to know just how long it is that the oven does stay lit. All ovens, gas and electric, cycle off and on throughout a baking cycle, to maintain the proper temp. If the flames or the power to the element were to stay on at full power for the life of the food's required time in the oven it would most likely wind up charred. The temp would simply continue to rise, up and up and up. If that's what it appears to be doing, then it's just working normally. If it goes out completely and stays off, doesn't come back on in a few minutes, then it may be in a keep warm mode. Many ranges have a TIMED BAKE cycle available, so you can set the clock to start the oven at such and such a time, cook the food and then shut off. Once it's finished with the cooking cycle, it goes into a keep warm mode, where it will come on for a short time and then go off, to maintain about 180 degrees. Not hot enough to really cook anything anymore, but hot enough to keep it warm for you when you get ready to eat.
If this seems to be the way it's acting, then look for the timed bake function on the console and set things back to a manual mode.
Apr 22, 2011 | Kitchen Ranges
When I turn on my Maytag performa using the "bake" function, everything looks ok on the display, however the temp. never rises above 100. I've tried "bake" and "convect", and neither one work. "Clean"...
Usually the problem is the heating element. This is easy to check and usually inexpensive. There is a video at www.appliancehelponline.com/servicemanual.html that will walk you thru testing and replacing. It may be a different model but the testing and replacement will be the same. You can also enter your model # for diagrams and illustrations of your specific model.
Apr 09, 2010 | Maytag 30" Built-In Single Electric Wall...
Old kenmore built in oven wont unlock
When I turn on my Maytag performa using the "bake" function, everything looks ok on the display, however the temp. never rises above 100. I've tried "bake" and "convect", and neither one work. "Clean" doesn't work either. The oven will lock, and display shows that it's heating up, but temp. never rises.
However....."broil" feature works just fine.
Please help.
Apr 09, 2010 | Ovens
My Maytag Performa oven and stove top will not turn on (heat up)
Please help.
Mar 09, 2010 | Maytag 30" Built-In Single Electric Wall...
KitchenAid Oven Temp.- Bottomside of Pizza or Cake stays uncooked
I have a 2yo Kitchenaid oven, and my advice is first, don't use convection for cakes or pizza. Use the thermal oven. For pizza preheat to 500 degrees, then put the pizza on the lowest rack, and bake for 7-8 minutes.This way the bottom browns, and the top doesn't get broiled from the top element coming on during the bake cycle.
As for cakes, again place them on the low rack so that they get bottom heat. I keep my eye on the oven and when the broil element comes on I stick a piece of foil over the cake until it goes off. Otherwise it will set the top and the cake won't rise as much. Even doing that cakes don't rise as much as they did in my old oven, and they brown too much on top.
The convection oven does a good job of cookies, and the broil mode is okay.
I wish I hadn't bought this oven, but I didn't know about the upper (broil) element coming on during the bake cycle until I'd had it for awhile, and it was too late to return it.
If anyone's shopping for an oven, ask questions, and don't get one that maintains the oven temperature by activating the broil element when baking.
Jun 24, 2009 | KitchenAid Architect ® II KEBS208S...
Won't bake, but all else works
Swap the broil and bake ignitors(they are both the same) see if the bake works. If the oven bake works then you need only replace the ignitor. If it does not then I would say you should check the valve for continuity. If open, bad gas valve. If continuity is detected, bad oven control.
Dec 22, 2008 | Kitchen Ranges
Kitchen Ranges Logo
43 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
