Question about Dewalt DW715 Heavy Duty 12" Single - Bevel Compound Miter Saw
How do you replace a broken locking pin on dewalt dw708 miterbox? thx
  • 3 Answers
You do not have to drill anything out, if you are talking about the hold-down locking pin that keeps the blade assy locked down when not in use. I have created a tutorial for replacing the locking pin, you can find it here, http://mgfic.com/dewalt708_lockingpin.htm
Posted on Jan 26, 2013
2 Suggested Answers
thabrain
  • 76 Answers
SOURCE: How to replace lockdown pin DW708 12" sliding compound mitre saw
you are going to have to drill the inside pin out. be sure to center punch and drill a pilot hole. hope this helps
Posted on Oct 28, 2008
Dw708 dewalt miter saw runs backwards how to fix it
Check the polarity of you power source.
Jul 10, 2017 | Dewalt Saws
Have a dewalt dw708-lx type3 just replaced the on/off switch as the previous failed(13yr old)did two cuts this morning and new switch has now failed
Curious if you have tested the switch to make sure it is the problem? Also, have you checked the armature & brushes (make sure the brushes move freely in the brush tubes and squarely contact the armature)?
The DW708 is prone to bearing issues and the field is not uncommon either.
It would be unlikely to have a new switch fail that soon unless there is another issue causing it.
Nov 04, 2016 | Dewalt Drills
How to take off the pin that hold the ajustment lever on a DW 713 Dewalt Miter saw ?
I would use a hammer and a smaller diameter punch than the pin. Take a few wacks and see what happens. If it is rusted soak it with something like liquid wrench over night.
Oct 07, 2014 | Dewalt DW713 NA 10" Compound Miter Saw
DeWalt DW708 switch
http://c.searspartsdirect.com/lis_png/PLDM/P0201024-00003.png
This is the newer 744 series, white cord to white motor and black cord wire to black motor.
If your motor needs the mag starter that 5th loose wire, usually red, goes to the start terminal on the mag starter.
Feb 14, 2012 | Dewalt DW744S 10" Portable Table Saw with...
Rebuild dw708
I assume you are asking about the Dewalt
DW708 TYPE 3 Crosscut Miter Sawas seen here
http://www.ereplacementparts.com/dewalt-dw708-type-crosscut-miter-saw-parts-c-1009_1163_2604.html
Have you taken it apart yet? You will need screwdrivers, spring clip pliers, small bearing puller and a pipe same diameter as the inside of the bearing; for replacement of bearing.
Be sure to take out the brushes before taking out the armature.
Part 165-90
You most likely will have to replace part 87 too.
The bearing rests in there and gets worn too.
Serious bearing/vibration problems causes the end cap part 84, to wear out.
Jan 23, 2012 | Cars & Trucks
Just rented a DW708. how do I unlock the blade to
There should be a lock down pin near the pivot that needs to be dis engaged.
here is a link to the owners manual:
http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/386762-02,DW708.pdf
Jan 16, 2010 | Cross Dewalt& 12" Double-Bevel Compound...
Need to calibrate my dw708 sliding compound miter saw. How to adjust the slides for a true cut. The blade is square.
i use a framing square off of the back fence with the blade down. when it is square, i check the other side of the fence and loosen the screws on the plate with the degree increments and set it to zero
Nov 21, 2009 | Dewalt 12" Beveling Sliding Compound Miter...
Oct 26, 2008 | Saws
Dewalt DW715 Heavy Duty 12"  Single - Bevel Compound Miter Saw Logo
1,078 people viewed this question
Top Dewalt Saws Experts
Parson's Repair...
Parson's Repair...
JOHN LAPIER
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
