Question about Amana Dryers
My electric amana dryer runs and the tub spins, but it will not heat up
  • Amana Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Posted on Oct 15, 2010
Amana 7200 dryer, runs but has no while running.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
heatman101
Dec 31, 2010 | Amana NED7200TW Electric Dryer
Dryer tub doesn't spin - motor runs and hot air comes into the tub area but the tub itself has quit spinning. Could this be the belt since the motor is running and the dryer is heating up? This is an...
Unfortunately you will have to search for thebelt with auto stores to see if any of the models will match. Check to see if any machine spares shops can help, get intouch with industriaal spares outlets to help you.
Sep 23, 2010 | Amana DLE330RAW Electric Dryer
Running the dryer with normal settings. Dryer runs, tub spins, but NO HEAT. Error code popping up after a couple of minutes is "Ad". Any ideas on what the issue might be?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Aug 23, 2010 | Frigidaire AEQ6000ES Electric Dryer
Amana model 2330aww....runs but does not heat up....just started happening, dried one load then it stopped heating up
heatman101
Aug 15, 2010 | Amana NDE2330AY Electric Dryer
Where is the heating element on a amana dle dryer
Depends on the model. Usually on the back lower left side under tub or right behind the tub in the top center. The frist location you remove the front panel to get to element and the second location the lid has to be raised up
Mar 02, 2010 | Amana DLE330RAW Electric Dryer
Dryer is making a humming noise and wont spin.
you probably have broken belt which drive the tub or drive wheel. open the top and see if a belt or open the bottom you see it there
Jun 23, 2009 | Amana DLE330RAW Electric Dryer
Belt broke on Amana dryer
belt goes around drum and motor pulley and under tentioner
Feb 18, 2009 | Amana NDE5800AY Electric Dryer
Amana electric dryer model LEA30Aw will not heat
The heating element measures 10 Ohms at 68 degrees farenheit. Usually if the element is bad, it will measure infinity.
Dec 24, 2008 | Amana Dryers
Dryers Logo
55 people viewed this question
Top Amana Dryers Experts
Tim Whalen
Sal De
Are you an Amana Dryer Expert? Answer questions, earn points and help others
