Question about Dryers
My dryer runs but the heat wont work - Dryers
    President:
  • 1,140 Answers
Your heating element has most likely burnt out, although it could be just a wiring fault.
If you have a resistance tester (multimeter) and you can get access to the element, you can check this very easily. Simply put the test probes onto the live and neutral terminals on the element (With the power OFF) and you should get a resistance reading of 0 (zero) ohms. If you get a reading of 1, you have an open-circuit, meaning the element is burnt out.
They are fairly simple to replace if you're a reasonably competent DIY'er with basic electrical knowlege. Universal elements are often available far cheaper than the specific OEM part and work just as well . . . in my opinion.
If you can post the model of your dryer and location, I may be able to find a supplier for you.
Please rate my solution if you find this helpful.
Posted on Oct 14, 2010
Dryer works but timer doesn't move. I just replaced it and still having the same problem.
Kenmore 400 6942 Dryer Heat timer - Questions - Fixya
www.fixya.com > Forum > Dryers > Kenmore > Kenmore 400 6942 Dryer
Kenmore 400 6942 Dryer, heat timer related issues. ... The timer doesn't work. ... the heat turns back on the timer stops,heat shuts off the timer will move again,if the ... not heating/timer knob not turning . the dryer works but is not heating and i ...
kenmore 400 doesn't heat, and timer doesn't move, but dryer ...
www.shopyourway.com > Manage My Life > Questions
I understand your Kenmore 400 Dryer doesn't heat up or the timer doesn't move, butit tumbles sometimes. I found the manual for your Kenmore Dryer in ...
Fixing an Electric Dryer that Doesn't Heat and the Timer ...
? 5:51
https://www.youtube.com/watch?v=0mo_gw0p2CI
Jun 29, 2013 - Uploaded by SamuraiRepairman
Although electric dryers are the simplest appliance to work on, ....and now the dryer won't heat and the timer doesn't advance, butthe motor still runs? .... Diagose a Whirlpool or Kenmore Dryerthat Keeps Running, Wont Shut ...
Dec 21, 2015 | Kenmore 400 6942 Dryer
My dryer wont heat
Not sure of my brand, but when my dryer would continue to run without heating, I replaced one small fuse in the back using Google to find the right part (What Causes Gas Dryer to Stop Heating) and a youtube video to walk me through the process. Instead of a $75 maintenance visit or purchasing a new dryer, I solved the problem for $2.50.
This video worked for me, but you could search for other brands.
May 06, 2012 | Whirlpool Dryers
Frigidiaire dryer (model - leq2152eso)runs everything works but wont heat up and no display codes
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Apr 20, 2011 | Dryers
My dryer runs but it won't heat up.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
Check out this tip that will give more details…
Gas dryer not working gas dryer not heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
Check out this tip to see the things that can fail to cause your electric dryer not to work.
Dryer Troubleshooting Electric dryer wont heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Aug 24, 2010 | Kenmore 84052 Dryer
RUNS BUT NO HEAT
heatman101
Aug 21, 2010 | GE Profile DPSR473GW Dryer
I have GE dbl33eb4ww dyer that wont get clothes dry till you run them through about trhee or four times
heatman101
Aug 19, 2010 | GE DBL333EA Electric Dryer
My dryer wont heat, but air flows well. Also, it
# 1 Check to see if your timer is turning as the dryer is running. If not it will need to be replaced.
# 2 You will need to verify that your heating element is coming on when the dryer is running
Oct 02, 2009 | Dryers
No heat after drying several loads
the vent in your house may be stop up in the wall.
Jun 15, 2009 | LG DLG3788W Gas Dryer
Dryers Logo
41 people viewed this question
Top Dryers Experts
