Question about HP Compaq Presario SR1250NX (PJ534AA) PC Desktop
My Compaq Presario SR1250nx will not turn on. The power chord is attached and power strip is turned on. I've also tested on a stand alone outlet to ensure it wasn't the power chord. A little green light right below the power supply chord plug in on the back of the Computer unit is steady green as soon as the power supply is plugged in and active. However, when I push the power button on the front of the unit, absolutely nothing happens. Normally there is a green light below the power button on the front of the unit that stays on after powering up, but the computer makes no noise, shows no light and no fans go on or anything. It was working a few hours ago and I did a system shutdown and now it won't work.
  • Nicholas Remelman May 29, 2013
    I'm having the same problem with a Compaq Persario SR2150nx. I changed out the power supply, all the connections are in all the way, and the computer still won't power on. Could it be that the motherboard has died? This computer hasn't been turned on in months. I even cleaned all the dust from the CPU.
  • 3 Answers
Looks like your power supply's failed. The green light on the back of your power supply is just a neon light that just confirms that the power lead is OK, it does not relate to the status of the power supply! Try powering it up with another power supply, or replacing the power supply.
Posted on Oct 14, 2010
    Genius:
  • 1,016 Answers
It sounds like you have a power supply unit failure, this unit is in the rear of the computer and it may have blown the fuse in it.
Try to hold the power switch on for 5 secs when you plug it in, if the unit still wont switch on then thats what the problem will be.
Hope this helps, let me know if you want more information.
Thanks
Jason
Computer wont boot up
Hello there and weclome to Fixya:
can you tell me if the power supply is even turning on if not double check the power cord to ensure that it is connected in both the computer and the outlet if so if you unplug the cord then press in and hold the power button for at least 20 sec this clears
the esd from the machine now try to plug it in and see if it now works if now you will have to replace the power supply which is really easy but try this first and let me know what happnes ok ?
Best regards Mike
Oct 12, 2012 | HP Compaq Presario SR1250NX (PJ534AA) PC...
I have a presario SR1250NX and it won't come out
if you are not an technician i'd suggest to take it to the service center.
i think it might be the psu/memory related issue and as an user you are not able to remedy the situation yourself
Mar 09, 2012 | Compaq Computers & Internet
HP Compaq Presario SR1250NX PC , will not turn
If no lgihts, sounds or anything at all, more than likely power supply.
Dec 30, 2009 | Compaq Computers & Internet
Computer will not turn on , yes , it's plugged in.
Dec 30, 2009 | HP Compaq Presario SR1250NX (PJ534AA) PC...
My sr1250nx won't power up. blinking green light in back right below power cord
generally in dese cases its a HW problem> open up the side panel> disconnect the thickest bunch of power cable on the motherboard(ATX connector) it either has a 20-24 pin connector> then turn on the PC> if the Light at th back is steady> the motherboard has gone bad> if its off> the power supply has gone bad
Oct 05, 2009 | HP Compaq Presario SR1250NX (PJ534AA) PC...
Cant turn On my Compact presario f700
Assuming you have checked the the power strip or outlet by testing it with another electrical appliance to see if it is in operation, you can test
the power supply to the unit with a tester or oscilloscope. If it still does not work then check the cable that plugs directly into the unit and replace it if necessary. You can also open the unit to check if the cable is attached properly to the motherboard.
Aug 26, 2009 | HP Compaq Presario F500 F700 and G6000...
I have computer that wont turn off
unplug all your power outlet, see its turns off...
Jun 18, 2009 | HP Compaq Presario SR1250NX (PJ534AA) PC...
Computer wont turn on or off
power unit PSU dead is there a fan motion ? beware of PSU that sleep in the night ... mine did it and destroyed the syste, also the auto safety may have dumped out and it will not resume unless the system is repaired, could be power or maybe an internal chip Memory short, processor dead, fan stopped inside ... never run without it there may be a loose connection stopped fan . Mike
Jun 13, 2009 | HP Compaq Presario SR1250NX (PJ534AA) PC...
Laptop won't power up
if there a battery, try to remove the battery and put the charger..try to check if the power come or not come.
second, if not come the power without battery..you must check first the charger output,working or not working..and third, check the power jack...thats the last...
Jan 04, 2009 | Compaq Presario Notebook
Dont have the disc
You can order the recovery disks from HP here:
https://warp2.external.hp.com/driver/dr_country_select.asp?Product=5069-7837〈=en&cc=us
If this helps please rate my solution.  Thanks
Dec 12, 2008 | HP Compaq Presario SR1250NX (PJ534AA) PC...
HP Compaq Presario SR1250NX (PJ534AA) PC Desktop Logo
518 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
