Question about Air Tools & Compressors
Hi have a colt 255 air compressor needed to change the oil. needed a basic step into doing this? how much oil is needed? is there a drain plug? or do you lie it onto it side?
  • 652 Answers
There is a plug on the bottom or side. use quaker state sae 30 fill it till it comes out the fill hole or until you can see the oil in the fillhole. If you cannot find the drain plug you can dump the oil out the fill plug but this is not advised unless there is no drain plug. You should find drain on btm of engine.
Posted on Oct 14, 2010
Where do I buy spare parts from for the Able Cooke Colt 255 air compressor?
I broke the air flow adjuster knob where do i find it
Jan 31, 2013 | Vacuums
What grade oil do I use to change out on my Chicago Pneumatic RPC-561VNS? The manual says a compressor grade non-deturgent oil should be used, but does no specify a grade.
Hi and welcome to FixYa, I am Kelly.
Compressor grade oils are basically SAE30 W oil. Read this:
Rol-Air OILCOMP30W34C Air Compressor Pump Oil - 30W Quart features ,
Specially engineered and tested to match the requirements of Rol-Air air
compressors , Provides superior rust and corrosion protection.
I.e SAE 30W oil / the same thing you would use in an older lawn mower engine or generator.
What they don't tell you is because they have re-labeled the 30W oil to OILCOMP30W they can charge you big time for SAE 30W oil. The only difference is the label.
Thanks for choosing FixYa,
Kelly
Sep 22, 2011 | Chicago Pneumatic 60Gallon TwoStage Air...
Able cooke air compressor colt 255 instruction manual
Have a Colt 255 that won't build air pressure. Any hints?
Oct 14, 2010 | Vacuums
I just bought a used Craftsman air compressor at a garage sale...100PSI, twin cylinder, 1HP motor. Model # 106.154440. Runs fine, but wondered how to check the oil level in the compressor case and if it...
I have a Sears 106.154581 most likely like yours. You will find a small plug (fill hole) and slightly larger plug on side of pump close to bottom (drain hole). Fill compressor with compressor oil to top thread of fill hole. Oil should look rather clear with very little odor. Compressor oil is available at Lowes for about $3. Good luck
Aug 16, 2010 | Craftsman Air Tools & Compressors
I have a robinair 34700zasking me if i wanna change the oil nowhow do i do that and what type of oil i need to use?....ty
You have run the machine 10+ hours for vacuum since last oil change. so you have to change vacuum pump oil. For change vacuum pump oil just follow the bellow step: Press main menu then keep pressing up or down arrow key till display show "CHANGE VACUUM OIL'' then press "YES" key. Now vacuum pmp will run for two minute & stop automaticly. When pump stop you just open the oil drain plug & oil fill cap of vacuum pump ( Located oute side of the machine near high & low side hose ) & drain all oil from vacuum pump. After draining used oil,replace oil drain plug & fill new ROBINAIR vacuum pump oil till middel of sight glass.Press "YES" key & follow on screen messeage. NOTE: Do not over fill the pump & Do not use any COMPRESSOR oil on the vacuum pump!
Hope this will help you & if it is please vote for my support.
Jul 05, 2010 | Robinair Cool Tech 34700Z Recovery,...
I have run my aire compressor and it won't go above 50psi. I drained the tank before started running. The drain plug is closed. It is an "oil less" Craftsman 15 gallon 3hp compresson. What could be causing...
blown piston rings blown headgasket valve damage i would strip the barrel off buddy once done this get back to me i will tell you step for step what to do
Oct 10, 2009 | Air Tools & Compressors
How to change oil on 1.5 hp,2 gal. air compressor
run the machine until it fills up then unscrew drain plug on front or underneith pump unit once drain replace plug and unscrew filler plug and fill with oil till it comes 1/2 full on sight glass or touches line on dipstick done
Sep 26, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Over service craftsman air compressor with oil
Just find the drain plug and drain out some of the oil and put the plug back at the right time to get about the correct oil level.
The drain plug may be the sight window itself, if you can't find one.
If you need more help, post a comment.
Thanks,
Tim
Mar 27, 2009 | Craftsman 1 Hp, 4 Gal. Air Compressor
Chang oil and care of filter of oil
How to change Oil>>
Step 1.
Put the bike and your tools in a convenient place. Raise the bike onto its kickstand in a clear area that can get a little dirty. Gather your new oil, tools, rags and drain pan in one place so you don't have to run to get a tool in the middle of the oil change.
Step 2.
Find the drain plug and filler cap. Before you begin to work, make sure the engine is not hot, though it should be slightly warm. Remove the filler cap so that the oil settles to the bottom of the can and can be properly drained.
Step 3.
Place your drain pan underneath the bike's drain plug. You can use a flat piece of metal, or even a piece of cardboard, to channel the oil into the drain pan.
Step 4.
Use a socket wrench to open the drain plug. Open the plug slowly so any built-up pressure can diffuse. Keep an eye on the oil's flow so you can catch as much of it as possible with the drain pan.
Step 5.
Change the oil filter. While this is not strictly necessary, it's a good idea to take the time to change the bike's oil filter. Locate the oil filter using the motorcycle's manual and replace it with a new one.
Step 6.
Replace the drain plug and refill the oil. Make sure the drain plug is securely fastened and then pour fresh oil into the tank, using the amount of oil that is specified by the bike's manual.
>>After 5000 kms you need to change the filter. Oil brand is a matter of preference as oil and filter is really a cheap price to pay so that your engine will last and last.
please rate this solution.
Thanks for using FixYa.
Feb 13, 2009 | 2007 Bajaj Discover DTS-I
Air Tools & Compressors Logo
111 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
