Question about Haier HWR06XC3 Air Conditioner
The unit ,has e-1 on the read out,and it will not come on
  • Haier Master
  • 43,501 Answers
Here is a tip that gives a further explanation of that E-1 code. The causes ofthe E-1 code can be varied depending or the brand of your air conditioner.
Read through this tip... it will help you understand what is happening withyour window air conditioning unit and give you some things to try to help youget your problem resolved.
E-1 Code on Window Air Conditioning Units
heatman101
Posted on Oct 14, 2010
How do I reset drum error message
These machines need to have their drum units replaced every 12000 pages. If you have replaced it then it needs to have the machine reset. Normally the instructions are included in the box with the new drum unit but not many people read these.
  1. Open the front cover (Where you put the cartridge and drum unit in)
  2. Press the Back Button
  3. Display reads "Replace Drum 1. Yes 2. No"
  4. Press the number 1
  5. The display reads "Accepted"
  6. Close the Front Cover
If you have not replaced the drum unit and you reset the drum counter you will see a noticeable degradation of the printouts coming from the machine.
Oct 06, 2014 | Brother MFC-7420 Printer
Check engine light for volvo 850 wont go off wat else can be the problem if i got a full tune up and put in new spark plugs plus it trembles alot and it shakes when i start it up plus wen i put it on...
Hi, I recommend you access the OBD panel to extract the trouble codes. Then send us the trouble codes for further advice. On 850 models the DLC is located in the engine compartment in front of the module box, behind the passenger side headlamp.
  1. Open diagnostic socket cover and install selector cable into socket No. 2 for fuel injection codes or socket No. 6 (except Motronic systems) for ignition codes.
  2. Turn the ignition switch to the ON position.
  3. Enter control system 1 by pressing the button once. Hold the button for at least 1 second, but not more than 3.
  4. Watch the diode light and count the number of flashes in the 3 flash series indicating a fault code. The flash series are separated by 3 second intervals. Note fault codes.
1f there are no fault codes in the diagnostic unit, the diode will flash 1-1-1 and the fuel system is operating correctly.
  1. If diode light does not flash when button is pressed, or no code is flashed there is a problem with the soft-diagnostic system, proceed as follows:
    1. Check ground connections on the intake manifold, and the ground connection for the Lambda-sond at the right front mudguard.
    2. Check the fuses for the pump relay and the primary pump. On 240 models, fuses are located inside the engine compartment on the left side wheel well housing. On 760/780 models, fuses are located in the center console, just below the radio. On 740/940 models, fuses are located behind the ashtray. Access can be gained by removing the ashtray, and pressing upward on the tab marked electrical fuses press. On 850 models, the fuses are located on the left side of the engine compartment behind the strut mount plate. The fuses on 960 models are located on the far left side of the dashboard. The driver's door must be open to gain access to the fuses.
    3. Remove glove compartment, and check control unit ground connections.
    4. Turn the ignition switch to the OFF position. Remove control unit connector and connector protective sleeve.
    5. Check diagnostic socket by connecting a voltmeter between ground and No. 4 connection on the control unit connector. Reading should be 12 volts. If no voltage is present, check lead between control unit connector and fuse No. 1 in the fuse/relay box.
    6. Turn the ignition to the ON position, and install selector cable into the No. 2 socket on the diagnostic socket. Connect a voltmeter between ground and No. 12 connection on the control unit connector. Reading should be 12 volts. Press the button on diagnostic socket and note reading. Reading on the voltmeter should be 0 volts. If no voltage at the control unit is present, take reading at the diagnostic socket connector. If reading remains at 12 volts when button is pressed, check diagnostic socket.
    7. Connect a voltmeter between ground and the red/black lead on the diagnostic socket connector. Reading should be 12 volts.
    8. Connect a suitable ohmmeter between ground and the brown/black lead in the diagnostic socket connector. Reading should be 0 ohms.
    9. Turn the ignition to the OFF position. Connect ohmmeter between diagnostic socket selector cable and the pin under selector button. The ohmmeter should read infinity. Press the button and note the reading. The reading should be 0 ohms.
    10. Connect a suitable diode/multimeter tester, or equivalent, between the diagnostic socket diode light and the selector cable. Connect red test pin from the tester to pin under diode light and black test pin from tester to selector cable. A reading on the tester indicates correct diode light function. With no reading on tester, replace diagnostic socket.
    11. Check the system relay/primary relay by connecting a voltmeter between ground and the No. 9 connection on the control unit connector, then connect a jumper wire between ground and No. 21 connection on the control unit connector. The relay should activate and the reading should be 12 volts.
  2. Press the diagnostic socket button. Note any additional fault codes.
The diagnostic system memory is full when it contains 3 fault codes. Until those codes are corrected and the memory erased, the system cannot give information on any other problems.
  1. Press the diagnostic socket button for the third time to see if a third fault code is stored in the memory. If the diode light flashes the same code 1-1-1, there are no other codes in the memory.
Fig. Fig. 1: Push button once for mode 1
Push button twice for mode 2
Push button three times for mode 3
To clear the codes:
  1. Turn the ignition switch to the ON position.
  2. Read fault codes.
  3. Press diagnostic socket button 1 time and hold for approximately 5 seconds. Release button. After 3 seconds the diode light should light up. While the light is still lit, press the button again and hold for approximately 5 seconds. After releasing the button, the diode light should go off.
  4. To ensure that the memory is erased, press the button 1 time, for 1 second but not more than 3 seconds. The diode light should flash code 1-1-1.
  5. Start and run engine. If engine will not start, correct the problem before proceeding and start over with Step 1.
  6. Check to see if new fault codes have been stored in the memory by pressing the diagnostic socket button 1 time, for 1 second but not more than 3 seconds.
  7. If fault code 1-1-1 flashes, it indicates that there are no additional fault codes stored in its memory.
Oct 05, 2011 | 1994 Volvo 850
Everytime i plug in my unit it reads E1 What does that mean
heatman101
Aug 30, 2011 | Haier Esa3089 ThruWallWindow Air...
Nighthawk carbon monoxide alarm model KN-COPP-3. ( ERR appears in the window, what does this mean ....
Readings You May See When Unit is AC Powered
Display Shows Alarm Sound Unit Status Recommended Action
Steady "Err" "Chirp" every Unit malfunctioning when Call KIDDE customer
and flashing dot 30 seconds AC powered service at 1-800-880-6788
Readings You May See When Unit is on Temporary Battery Backup
Flashing dot None Normal battery-only operation - Plug in to AC as soon as
unit will show reading only if it possible to conserve battery
senses CO
Flashing dot and "Chirp" every Unit malfunctioning when Call KIDDE customer
"Err" 30 seconds battery powered service at 1-800-880-6788
Hope this helps. Manual is here:
http://www.detectorsandalarms.com/images/pdf/Manual_KN-COPP-3_900-0100en.pdf
If this helps you resolve your problem, please consider giving a good rating and a quick thanks or good job.It will help me as well Thank you.
Oct 26, 2010 | Computers & Internet
The read out says E1 and the unit doesn't work
Here is a tip that gives a further explanation of that E-1 code. The causes of the E-1 code can be varied depending or the brand of your air conditioner.
Read through this tip... it will help you understand what is happening with your window air conditioning unit and give you some things to try to help you get your problem resolved.
http://www.fixya.com/support/r5620902-e_1_code_window_air_conditioning_units
heatman101
Aug 22, 2010 | Amana ACB087R Air Conditioner
HOW TO WEIGH THINGS IN MICROWAVE
the microwave does not weigh things. you need to know the weight for things like auto defrost.
1 pound ground beef... enter auto defrost ..10
will read 1.0 ... 1 1/2 pounds... enter 15 ..reads 1.5.... 1/2 pound enter 5...reads 0.5 . unit beeps half way through heating program.. open door.. turn meat over close door. will continue to defrost
Jul 02, 2009 | Microwave Ovens
Remote problem
I had the same problem. Finally had to read the manual. The remote and the main unit work on one of three codes - 1, 2 &3. both units have to use the same code. It's easier to change the remote.
While pressing [ENTER], hold the numbered button (1, 2 or 3) for more than two seconds. Then press [ENTER]. The display on the main unit should read SET (1, 2 or 3) to tell you which one it is in.
Mar 09, 2009 | Panasonic DMRES15 DVD Recorder
JENSEN VM9512 SD SLOT PROBLEM
I don't have this unit but I have this problem with another unit. Problem when unit read only 1-4GB SD without this symbols HC because this cards which have HC is high speed storage and need high speed storage readers or this unit need new upgrade to read SDHC and I think upgrade is not possible for this unit. You need to use only standard SD 1-4GB cards. Or you can ask service or upgrade is possible.
I hope I help :)
Oct 10, 2008 | Jensen VM9510 Car DVD Player
Haier HWR06XC3 Air Conditioner Logo
54 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Edd
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
