Question about Maytag MZD2766GES Side by Side Refrigerator
"hissing" freezer, red hot coils, and daily leak
My MZD2766GES makes a hissing noise. When I look in the I can see through the vent in the back that the coils are red hot. This also seems to be causing a leak from the same area that happens typically during the night. What is going on and how can I fix it?
  • nashvilleCC Jun 02, 2008
    well, the leak is actually water on the floor in the mornings. and it's a considerable amount. The "hissing is very rare and always accompany the red hot coils.
  • nashvilleCC Jun 08, 2008
    hey, i figured it out, it was the defrost drain had frozen over and clogged therefore the extra water was leaking onto the floor. thanks
  • 3,037 Answers
The coolant is leaking if the coils have a hole. You can't actually fix this yourself. A qualified and certified professional Must work with the coolant. You could order new coils but in order to fix the ones you have, you will need to contact a repairman about this. This isn't something that anyone can do. I can get you a list of contact people but I'm sure the place you bought it from or a local supplier will be able to help you out. good luck and please let me know if you have any further questions as I would be more than happy to help.
The hissing noise would be the leak, you should turn this off immediately to not cause any further damage to the system.
Posted on Jun 02, 2008
  • 1 more comment
  • Benjamin Patri
    Benjamin Patri Jun 02, 2008
    Is the refrigerator still cold though or is there an elevated temperature with this problem
  • Benjamin Patri
    Benjamin Patri Jun 08, 2008
    If you are satisfied with your experience here, then feel free to provide me with some feedback by
    rating my solution. If you need any more help, I would be glad to
    assist you, just ask.
    Thanks for your time and service and I hope you have a Great Day!
  • Benjamin Patri
    So the hissing I assume was coming from the drain then as it wasn't draining properly. Thanks for the update and glad you fixed it. Have a good day
  • 796 Answers
The thermostat must not be functioning properly...
you need to replace them
Freezer leaks water out the bottom
sounds like your defrost drain line is clogged or unhooked, you will have to remove everything from the freezer and take the inside back cover off to check the problem.
Mar 22, 2014 | GE Refrigerators
The freezer stopped working (the fridge is working but not as cold as it should be), I cleaned all the vents and the freezer worked again fro a short time then I heard a noise like possibly the fan...
It does sound like a bad fan motor. With the compressor getting hot you may need to change the start relay, overload and run capacitor if it continues to run like this with a defective fan motor. What is the correct model number? Sea Breeze
The condenser fan motor for a model MZD2766GES is part number=> 61005323 Condenser Fan Motor or here=> 61005323 Condenser Fan Motor
Oct 18, 2013 | Maytag MZD2766GES Side by Side...
Freezer leaking water to the floor
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Aug 09, 2011 | Maytag MZD2766GES Side by Side...
My Neff fridge freezer model K3965 is leaking - Puddles of water are appearing underneath and ice is accumilating at bottom off freezer. I have looked inside and can't see a leak but ocasionly can...
If the drain is clogged with Ice or ? it overflows into the ref. or freezer
Leo Ponder
imufo2
Aug 08, 2011 | Neff K3965XO Side by Side Refrigerator
My freezer is located in a garage that is staying hot in these 90 degree temps. I just heard a noise coming from it, looked and stuff was thawing. Husband unplugged and noise has stopped fills like cold...
I would first check to make sure the the condenser coils are free of debri and there is not something against the fan.
Did the noise sound electrical or mechanical or a hiss. A hiss is most likely a freon leak or a compressor blown (usually not worth repairing). A mechanical sound could be something blocking a moving part like a fan. Electrical could mean about anything.
I would check the condenser grill and then plug it back up and try to tell where the noise was coming from.
Jun 08, 2011 | Kenmore Freezers
I heard a hissing while I was looking in the refrigerator, and I realized that it was coming from the freezer. I looked in the back of the freezer compartment, and I saw a red coil through the vents at the...
Hi and welcome to FixYa. I am Kelly. Relax :) You just witnessed part of the NORMAL automatic defrost cycle. There is a heating element in a glass tube that melts ice off of the evaporator until either a thermistor or 60 Deg F defrost thermostat cycle and terminate the defrost cycle. Just so you know automatic defrosting cycle intervals are anywhere from every 6 hours up to 16 hours and 35 minutes depending on the model. The hissing sound you heard was melting ice dripping on to the hot glass tube of the heating element so the water was boiling on the glass tube. It is nothing to worry about unless the defrost cycle never terminates. (i.e the unit never starts back up)
Thanks for choosing FixYa,
Kelly
Nov 15, 2010 | Refrigerators
I have a model ED2CHQXKB05, series SR4452983 from November 2004. Freezer on the left side. The freezer drips into a vented area in the back: I can see the drips when I open the door, and each drop makes a...
What you are describing is the normal sounds it makes when it goes into defrost. The frost melts, and the resulting water will fall onto the heater which then makes your hissing noise. You dont mention that there is a problem, such as not cold or water leaking on your floor, so it sounds like all is working as it should. But you also mention you taped IT ( what is it?) to the wall in a circle.
Oct 12, 2010 | Whirlpool Freezers
Water leaks from bottom of freezer side even though the water is turned off. Also makes a humming noise prior to leak. Leaks about every 3 days.
Clean the drain pan and drain line in the back of the freezer section underneath the evaporator coil. (hint: use turkey baster with hot water) Make sure water drains when you pour it in. If it doesn't - also clean drain tube on the back of the unit behind the cover. When done - make sure to put the tube exactly where it was.
Good luck! :)
Vlad
First Choice Appliance
Apr 22, 2010 | Maytag MZD2766GES Side by Side...
In the freezer side, it leaks water from where the cool air comes through in the lower part of the freezer, seems to do it during some kind of a cycle, of which I have not figured out.
It's doing it in the defrost cycle.
Clean the drain tray and drain line in the back of the freezer section, located behind the back cover and underneath the evaporator coil. (hint: use turkey baster with hot water) Make sure water drains when you pour it in. If it doesn't - also clean drain tube on the back of the unit behind the cover. When done - make sure to put the tube exactly where it was.
Good luck! :)
Vlad
Jan 05, 2010 | Maytag MZD2766GES Side by Side...
Water pooling under freezer side of cabinet. Ice forming in bottom of freezer.
drain in bottom fo reezer is frozen w/ice (location is very far left in back lookbehind vent. use hot water and baster. force hot water through drain. /remove ice /it will work good. mm pls leave feed back..mm
Dec 07, 2009 | Maytag MZD2766GES Side by Side...
Maytag MZD2766GES Side by Side Refrigerator Logo
174 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
