Question about Craftsman Saws
Light goes out immediately after plugging in the battery charger with the battery in it
  • 43,501 Answers
The battery is bad...either the circuit inside is broken or there is an internal short in the battery which will cause the charger to shut off...
heatman101
Posted on Oct 14, 2010
I need a validation code fro quickbooks pro 2011. the Licen number1063-0575-1585-222. and Product number 019-147
i have a dell latitude E5520 laptop,having a power-cut issues,the moment you press the power button,the light comes on then goes off immediately,. when u plug in the charger,the charger light indicator turns on and also goes off immediately. i need help to solve it.
Thank you
Aug 01, 2017 | The Computers & Internet
PEG Perego Battery doesn't charge.
You have to first know what type of rechargeable battery you have. lead-acid, lithium-ion, ni-cad? NEVER use an unmatched charger for a different type of battery, they can EXPLODE in your face. Your current battery may have a memory from incorrect charging procedures, your charger could be bad. You don't know enough to handle the problem yourself, take it somewhere, a car repair, or even a TV shop.
Dec 16, 2014 | Toys
When plugged into the charger the throttle light and charger light are green but when I remove the charger the throttle light immediately changes to yellow and it will not move and i hear a clicking sound
your battery voltage is dropping straight off the charger - batteries are not holding charge & need replacing. You can have your batteries load tested at the battery shop to confirm.
There are guides to battery replacement and trouble shooting here
http://www.razorama.com/razor-installation-guides.html
Jun 28, 2012 | Razor MX350 DIRT ROCKET - BLUE
Celebrity x scooter wont charge
Hello,download:SHOPRIDER SERVICE MANUAL 2007 1-800-743-0772.Save as a PDF File + Print for future,hope this has helped,Colin.
Nov 22, 2011 | Health & Beauty
I bought a new charger for my laptop as my charger broke, and the little blue light comes on but the laptop won't turn on. I have the right charger, but it still won't turn on. The power light...
The first thing to do is check that the charger is putting out the correct voltage, which should be ~18 volt. Then try to start it without the battery.
If your voltage is OK and the battery out makes no difference, then I would suspect that you have a motherboard problem that must be fixed. If the computer starts up if you wiggle the DC plug where it goes into the computer, then it's the DC jack that is looks and must be re-soldered.
Sep 11, 2011 | Compaq Presario CQ60-220US PC Laptop
I have a dell inspiron 1545. i have the charger plugged in but a red light is flashin on my laptop. this light then turns white and immediately red again.if i remove the charger the laptop just switches...
take the battery out and try powering on your computer only with the power cord plugged in
if the computer turns on then
this is the problem with the battery
you need to replace the battery
Thank you
Jan 06, 2011 | Dell Inspiron 1545 Notebook
Plug battery into charger light goes out
first of all check for at least 12 volts from the battery and the charger, you can test this using a multimeter, if the battery doesn't show any volts, lift up one side of the blue plastic housing on the top and verify that both the positive and negative wires are plugged in
Apr 19, 2010 | Peg Perego John Deere Gator HPX Ride on...
When I plug in the adapter the blue light on the charger goes out immediately and does not charge the battery. I bought a new charger and it does the same thing. I've had both chargers checked and they are...
A bad battery is a definite possibility. Shorted cells are one of the ways they can fail, and then they put too much of a drain on the charger. Take the battery out of the laptop and see if the charger light stays on. This will eliminate the computer itself as the cause. Then you'll know you need to shop for a replacement battery. Replacement batteries are available from many sources online.
Mar 23, 2010 | Dell Studio 1737 Laptop
Battery Charging light doesn't flash and battery doesn't charge
I have the same problem. Worked for 3 years and now the battery charges to green but goes dead immediately. I've changed batteries. Its the camera not the batteries. Works fine plugged in. Obviously the cameras are not charging the batteries. Canon must know but I cannot find a fix and warranty is over. I guess buying the expensive camera of the day isnt always assuring you of quality.
Dec 25, 2007 | Canon PowerShot G2 Digital Camera
Saws Logo
51 people viewed this question
Top Craftsman Saws Experts
Craig Butler
Craig Butler
Are you a Craftsman Saw Expert? Answer questions, earn points and help others
