Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
The starter works but won't move the flywheel at all whats is wrong?
    Scholar:
  • 150 Answers
On the end of the starter shaft is a nylon gear. Remove the starter and inspect it for damage, maybe stripped off the gear teeth. If that gear is in good shape check the flywheel gear teeth. You can buy a kit for that starter gear. Cheap fix.
Posted on Oct 14, 2010
  • getherdone15 Jul 15, 2011
    how do i take OFF the gear that goes up and turns the motor that starts the mower, because i can not figure it out the model number is 917257630. PLEASE HELP!!
2000 GMC Yukon 1500xl 4wd. I replaced the starter relay and now the starter and flywheel are out of sync. The switch panel on dash is back on. How do I get them reset into sync?
the starter and flywheel cannot "unsync" unless you removed the starter and reinstalled it incorrectly! .. the starter pinion is moved "up or forward" on the starter shaft and engages the flywheel when the starter is "engaged".. the flywheel never moves from its factory installed position (unless something catastrophic happened).. the starter pinion always engages unless there is something wrong with the starter
Sep 17, 2017 | GMC Cars & Trucks
I have a murray 20in. And it won't start its getting gas and firing what is wrong Murray 20in.push mower getting gas and fire but won't start
The kill switch may be mis adjusted. Sometimes the cable stretches and you need to adjust it or shorten the cable.
May 28, 2016 | Murray Garden
1997 sable ,new starter turns but does engage
Could be that there were 4 cylinder engines and 6 cylinder engines and you may have the wrong starter. There could be several bendix drives that have thinner or broader gears or that need to go farther into the end bushing. If the end bushing is too long, the bendix will not be able to travel far enough to engage the flywheel.
Sep 26, 2017 | Mercury Sable Cars & Trucks
Tiller won't start
Best advice is to spray some ether in the carb, if that doesn't start it up, then check the spark plug.
Mar 17, 2013 | Mtd Garden
1965 mustang starter fires but won't engage flywheel. it is a brand new starter
Doesn't matter. The forks inside the starter may be missing or broke off or bad spring in starter that pushes the gear out. Try new started. Starter may have to be shimmed to make contact with flywheel. Starter may be kicking out but not engaging flywheel.
Jan 17, 2013 | 1965 Ford Mustang
1984 Ford Ranger Starter replaced but won't engage flywheel
it sounds like it need a shim to mount it up. not sure where you can get one though. maybe make it. search starter shims to see what i mean
Nov 30, 2017 | 1984 Ford Ranger
Starter works fine but won't crank engine. the pick up has to be given a push first before it starts
If the starter is spinning when you try to start but doesn't spin the engine over then you most likely have teeth missing off the flywheel ring gear. The facts that you say you have to push it and then it starts means the flywheel position changes and the starter has good teeth on the flywheel to engage. To confirm this next time the engine won't crank over remove the starter and look inside at the flywheel for missing flywheel teeth.
Mar 13, 2012 | Ford Cars & Trucks
2007 grand prix won't start but lights and horn work
Your battery is to low on power it needs a good charge, or replace it is the best option for a brand new one!
Feb 27, 2012 | 2007 Pontiac Grand Prix
2000 Chevy s10 manual changed starter still won't start the starter is spinning but the engine won't turn over.
Do you have the correct starter and is it grinding, this sounds like a bad flywheel or wrong starter or even a bad one. look at teeth of flywheel and see if they are damaged. good day
Jun 19, 2011 | 2000 Chevrolet S-10
Replaced starter in '93 F-150 6 cyl auto, new starter works but doesn't engage flywheel. Flywheel teeth aren't damaged, can flywheel be adjusted to bring it forward to mesh with starter bendix?
If the starter bendix is working then they gave you the wrong starter. or if yours has the cylinoid mounted on it , this woud be bad. either way you will need to take it back to the store. flywheels can't be adjusted
Nov 27, 2010 | 1993 Ford F150 SuperCab
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
308 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
