Question about Maytag Bravos 7.0 Cu. Ft. Electric Dryer
The heat comes on but the barrel does not turn. the dryer is only 3 yrs old. what gives?
  • Maytag Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Posted on Jan 15, 2011
Barrel turns no heat-new fuse-same-new element-same. Old element burned could new fuse pop and I need new one
Be sure to check for lint inside the filter housing and also vent blockage. 240 volts is going into the dryer. The motor runs on 120 so you might have a voltage problem. Heating element needs 240 volts. here is my video let me know if this helps:
Dec 21, 2012 | Kenmore Dryers
Clanking dryer and burning smell when on
the clanking is due to the main axel bearing worn out or loose the burning is due to clothing lint gathered around the heating element and catching fire this dryer sounds like it needs a real good service pull the back of take out the barrel . take note of how the drive belt comes off as there tricky to put back on clean all the lint from around the heating iron and re assemble with all bolts tight and you should get another couple of yrs out of it
need more advice feel free to email
pleas remember to rank my reply
Nov 30, 2010 | Kenmore Dryers
Dryer spontaneously turns on, barrel doesn't spin
If the dryer is more than 10-15 yrs old its probably a good idea to get another one...from what you told me it sounds like a pretty serious electrical problem or short with the Motor or control switch...I wouldn't suggest you try and fix this one yourself...
Apr 20, 2010 | Kenmore Dryers
My dryer is not heating,we have checked all of the settings, and the barrel is spinning so can you please help, the unit is about 4 yrs.old I have a maytag neptune
check ur breaker first, dryers will run on 120volts but wont heat unless have 240.
if electric check ur heating element, thermostats, and thermal fuse for continuity with a meter.
if gas check the ignitor,thermal fuse, and secondary gas coils,
Feb 05, 2010 | Maytag Dryers
My gas dryer (3 yrs old today) wont turn. It just
O turned the drum by hand and it started running
Nov 04, 2009 | Frigidaire Dryers
3 yrs old stopped in the middle of a cycle .
need to change thermal fuse,when dryer gets filled with lint they pop,it is a safety device that pops when dryer over heats
Nov 03, 2009 | Maytag Dryers
No heat will come from the dryer
Check the dryer breaker pair in the house electrical box. Push off, then on. If the breakers trip immediately, then you have a direct short circuit in the dryer, usually the heating element which involves removing the drum to get at the element(s). If the breakers hold, then try the dryer. If you get heat--ok. If drum turns, but no heat--check with a voltmeter across the two slanted slots in the power socket. You should read ~220 volts AC. If near zero, then one of the breakers is probably bad. Get an electrician to replace the breaker pair.
Aug 17, 2009 | Dryers
GE Dryer doesn't give out heat.
OK, i would check the thermal fuse. is usually located on or around the blower housing. Check the vent duct if its not on the blower motor housing. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
If the fuse is OK, there is only one more problem spot and that will be the timer itself. replace the timer/control if the fuse is OK.
Jun 01, 2009 | GE 5.8 Cu. Ft. Extra-Large Capacity...
Dryer turns but no heat
In some cases, even if the igniter is glowing, the resistance may not be low enough to turn on the gas valve. If 3-5 yrs old, the igniter has probably gone bad. ($50.00 to $90.00 for igniter). The coils also have an occasion to go bad, albeit rarely.
May 11, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Bravos 7.0 Cu. Ft. Electric Dryer Logo
51 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
