Question about Yard Machines 24a 021h700 4.5 Horsepower Chipper/Shredder/Vacuum, Push Model
After turning on it began making a rattling sound coming from yhe blade and then it turned off. the sound was of meyal hitting against the frame or something
    Scholar:
  • 150 Answers
For safety remove the spark plug and disconnect it from the plug wire. Tilt the machine back and rotate the blade by hand and make sure it clears the mower deck all the way around. Check to see if blade is tight. Any movement of the blade on the shaft is unacceptable. Tighten blade, if it won't start with blade tightened it may have sheared the flywheel key.
Posted on Oct 14, 2010
How do i change a blade for a zona mini hack saw?
Hello there.
The TENSION in the frame holds these blades in their slot.
What you do is
1) turn the saw upside down so the blade is pointing upwards.
2) Hold the handle of the saw tight against your tummy or if you have strong arms just your hands So the saw faces away from you.
3) Put the far end of the frame against a hard surface like a wall or bench.
4) Push the handle against the force and you will see the FRAME bend very slightly, this will allow you to push the blade out of its slot.
Engage new blade at the handle end then do the reverse of the above to allow the other end of the blade to go in the slot .
DONE !!!
Sep 21, 2014 | Zona Blade: 36-656 Mini Hack Saw Blades...
Unit makes a loud rattling noise when operating
Hello, most likely the fan blade is either loose or cracked at the hub causing the blade to hit the fan shroud. You will either have tighten the fan blade or have to get a replacement.
Jun 20, 2012 | Kenmore 71121 Air Conditioner
Is it difficult to change out the radiator fan, or bracket. I noticed when idling the fan turns on and a bad rattling noise is made and then stops when fan cut off.
It seems that the radiator fan is hitting against the frame and so there is noise and vibration when the fan comes on. Shut down engine and check on the blades, see if there was any damage that would have changed the alignment or postion of the fan. If so you will need to remove and reset the fan. If the bearings or blades are seen to be faulty , replace them before the radiator is damaged.
May 18, 2011 | 2000 Nissan Maxima
My computer when turned on is making a big rattling sound. What is wrong with the computer and how can I fix it?
Sounds like something is loose and is hitting the fan blades.
Remove the cover and check the cables near the fan, tie the cables back and make sure they don't hit the fan blades.
Sep 20, 2010 | Computers & Internet
I have a model 5BS520C. The light works but when I pull the chain for the fan, I hear the sound of three speeds but the blades do not turn. ed.pfohl@gmail.com
Here some toubleshooting:
Problem 1. Fan will not start.
Probable Cause
1. Fuse or circuit breaker blown.
2. Loose power line connections to the fan, or loose wire connections in the switch housing.
3. Reversing switch in neutral position.
Suggested Remedy
1. Check main and branch circuit fuses or circuit breakers.
2. Check line wire connections to fan and switch wire connections in the switch housing.
3. Make sure reversing switch position is all the way to one side.
WARNING: Make sure main power is turned off.
Problem 2. Fan sounds noisy.
Probable Cause
1. Blades not attached to fan.
2. Loose screws in motor housing.
3. Screws securing fan blade flanges to motor hub are loose.
4. Switch housing binding against the blade hub.
5. Wire connectors inside switch housing rattling.
6. Screws holding blades to flanges are loose.
Suggested Remedy
1. Attach blades to fan before operating.
2. Check to make sure all screws in motor housing are snug (not over-tight).
3. Check to make sure the screws which attach the fan flanges to the motor hub are tight.
4. Check to make sure that the switch housing does not bind against the blade hub.
5. Check to make sure wire connectors in switch housing are not rattling against each other or against the interior wall of the witch housing.
6. Tighten screws securely.
Problem 3. Fan wobbles
Probable Cause
1. Setscrew in motor coupling is loose.
2. Setscrew in the hanger ball/downrod assembly is loose.
4. Fan blade flanges not seated properly.
5. Hanger bracket and/or outlet box is not securely fastened.
6. Fan blades could be out of balance.
Suggested Remedy
1. Tighten the setscrew in the motor coupling.
2. Tighten the setscrew in the hanger ball/downrod assembly.
3. Check to be sure screws which attach the fan blade to motor hub are tight.
4. Check to be sure the fan blade flanges seat firmly and uniformly to the surface of the motor hub. If flanges are seated incorrectly, loosen the flange screws and retighten.
5. Tighten the hanger bracket screws to the outlet box, and/or secure outlet box.
6. Interchanging an adjacent (side-by-side) blade pair can redistribute the weight and result in smoother operation.
WARNING: FOR YOUR OWN SAFETY TURN OFF POWER AT FUSE BOX OR CIRCUIT BREAKER BEFORE TROUBLESHOOTING YOUR FAN!!!
Hope helps.
Sep 02, 2010 | Monte Carlo Dryers
Kitchenaid refrigerator / freezer knocking noise
Hmmm. Makes sure it is not the fan inside the freezer. The compressor is not capable of loud noise since it is sealed and sits on rubber mount. The knocking might be due to the fan blade hitting ice build up. You should not see any frost in a freezer. If there is frost, you can defrost completely then set the fridge to a lower setting.
Feb 11, 2010 | KitchenAid (KSRD22FKST) Side by Side...
Loud noises
your torque converter could have went. i feel its definetly your trans. i need more input
Dec 15, 2009 | 1987 Chevrolet Blazer
Possible shock?
Yes! if you have struts the shock mounts cound be shot,Also check to see your exhaust isn't missing any hangers,that makes noise too,when the pipe clunks against the frame.Good Luck !
Nov 23, 2008 | 2007 Pontiac Aztek
Amana Bottom Freezer
  I have found tubing rattling against plastic tray on right side in back.  Also found this tray rattling against frame.  You can take back off unit and llisten for noise.   Watch out for spinning condensor fan blade.  Very sharp,  believe me!!  Try pressing on tubing.
Oct 14, 2007 | Refrigerators
Yard Machines 24a 021h700 4.5 Horsepower Chipper/Shredder/Vacuum, Push Model Logo
189 people viewed this question
Top Yard Machines Heavy Machinery Experts
Roland W VanLue
Roland W VanLue
rjivaro
donald boissonneault
Are you a Yard Machines Heavy Machinery Expert? Answer questions, earn points and help others
