Question about Karcher 2500 PSI Pressure Washer
I had a bolt break off the engine shaft end and tookthe pump apart and replaced the bolt. How do you fill the pump back up with oil?
The pump housing usually has a plastic viewport about half way up on side of pump
Oil should come to middle of viewport
Use 20 or 30 weight non detergent oil > SAE20 SAE30
The engine uses 10-W-30 and should come about half way up dip stick
Posted on Oct 14, 2010
Where Is The Oil Pump Located>? And How Do I Replace The Oil Pump
Here you go. BIG Job!
http://www.ehow.com/how_4506339_replace-oil-pump-ford-taurus.html
The oil pump is an essential piece of equipment that keeps your Ford Taurus running. It lubricates the engine by keeping the oil circulating. Without this lubrication, the engine wouldn't run. An oil pump is usually located in the oil pan. If you want to change the oil pump and replace it with a new one, roll up your sleeves and get ready for some dirty work.
How to Check if an Oil Pump Is Bad
Things You'll Need
  • Wrench
  • New oil pump
  • New A/C bolts
Remove Old Oil Pump
  1. Drive your Ford Taurus up onto ramps or lifts so you have room to work as you pull out the oil pump. You could also use a jack, but make sure you brace the front wheels so they don't roll. In addition, set the emergency break firmly into position so the car doesn't roll.
  2. Take the engine out and put it on an engine stand then remove the upper intake manifold. Take off the valve covers then the accessory drive belt.
  3. Remove the power steering pump and the alternator. The water pump is the next component to remove, followed by the A/C compressor and bracket.
  4. Rotate the pulley shaft clockwise to remove the crankshaft pulley. It has left-handed threads.
  5. Pull out the oil pan and the oil pump screen and tube. Take off the front cover and the timing chains and remove the crankshaft timing gears. Finally, remove the oil pump, taking note of the bolts you removed and in which order you remove them.
Insert New Oil Pump
  1. Install the new oil pump and put the bolts back on in the same manner you removed them. Tighten these bolts to 71 to 106 in-lb.
  2. Reinsert the crankshaft timing gears, timing chains and front cover. Put the oil pump screen and tube back on, torquing the bolts to 71 to 106 in-lb, and torque the nut to 15 to 22 ft-lb.
  3. Put the oil pan back in, then the crankshaft pulley. Install the A/C compressor and bracket using new bolts for the A/C. Add the water pump, alternator, power steering pump, the accessory drive belt, valve covers and upper intake manifold.
  4. Replace the engine back into your Ford Taurus and fill the crankcase. Start your engine and look for leaks in the area you were working.
Read more : http://www.ehow.com/how_4506339_replace-oil-pump-ford-taurus.html
Aug 06, 2015 | 2004 Ford Taurus
What is the torque spec for a 2003 jeep wrangler 2.4 connecting rods
  • ENGINE 2.4L
DESCRIPTION
N·m
Ft. Lbs.
In. Lbs.
Balance Shaft Carrier to Block-Bolts
54
40
Balance Shaft Gear Cover-Double Ended Fastener
12
105
Balance Shaft Sprocket- Bolt
28
250
Balance Shaft Chain Tensioner-Bolts
12
105
Balance Shaft Carrier Cover-Bolts
12
105
Camshaft Sprocket-Bolt
101
75
Connecting Rod Cap-Bolts
54 +1/4 turn
40 +1/4 turn
Crankshaft Main Bearing Cap/Bedplate - M8 Bolts
34
250
M11 Bolts
41 +1/4 Turn
30 +1/4 Turn
Crankshaft Damper
136
100
Cylinder Head Cover- Bolts
12
105
Flex Plate to Crankshaft
95
70
Flywheel Mounting Bolts
81
60
Engine Mount Bracket Right-Bolts
61
45
Exhaust Manifold to Cylinder Head-Bolts
23
200
Exhaust Manifold Heat Shield-Bolts
12
105
Intake Manifold - Lower -Bolts
28
250
Oil Filter
20
15
Oil Pan-Bolts
12
105
Oil Pan Drain-Plug
27
20
Oil Pump to Block-Bolts
28
250
Oil Pump Cover Plate-Bolts
12
105
Oil Pump Pick-up Tube-Bolt
28
20
Oil Pump Relief Valve-Cap
41
30
Spark Plugs
28
Timing Belt Covers - Front Covers to Rear Cover-Bolts
12
105
- Rear Cover-Bolts
12
105
Timing Belt Tensioner Assembly-Bolts
61
45
Sep 27, 2014 | Cars & Trucks
I have a ANNOVI pressure washer and I can not seam to get the engine apart from the pressure pump. All bolts are removed and the bludy thing will not come apart. The lock nut on the drive is not even
There may be no good news for you. Once those hollow shaft pumps seize to a engine shaft, they can be real buggers. In fact, they can be impossible.
But before you give up and completely destroy the pump to remove it from the shaft -- the mounting flange has threaded holes that are designed for taking the pump off. The bolts that you removed go through unthreaded holes on the pump flange and into threaded holes on the engine. On the pump flange, there are also either two or four threaded holes. So you take the same bolts and screw them into the threaded flange holes -- the idea being they will contact the engine as you screw them down and push the pump outward.
BUT: this does not always provide a fix. That flange is made out of cast aluminum so it is not very strong. It breaks quite easily. So your best shot at getting the pump off this way is to go slow. Put some oil on the bolt threads, so they will turn easily. Try to bring them up to equal pressure and then use a meium hammer to "ping" somewhere. Remember though, the entire pump casing is made out of this cast alluminum and is very brittle. It is easy to knock a hole in the pump with a hammer. But alternating with some persistent pinging and then tightening the bolts a little more (tighten/ping/tighten/ping) is the shot you have. When tightening down on the bolts - equal pressure on each side is very important. And I can't over emphasis....just a little bit at the time! And if you can (if there is room) pinging on the engine shaft a git can help too.
If it seems to move a little, but then gets even more resistent, oil the engine shaft and knock the pump back down and then start over going in the off direction. This is because once you get some oil under the hollow pump shaft it usually will free up.
From someone who knows how frustrating it is, I hope this helps you. If it does, please take a sec to rate me. Thanks!
Don
Mar 18, 2012 | Garden
Have 10000 miles on my bike does the shaft drive oil need to be changed or what?
Final drive assemblies on motorcycles generally cost over $1000. They tend to show signs of dirt after only 5000 miles. Having driven shaft drive motor cycles for over 30 years I usually change my 85/90 Hypoid gear oil at every second engine oil change. It is never very dirty but if taken into the sun light will show some fine metal chips (nothing to worry about). I highly recommend using synthetic Hypoid gear oil. It will cause less friction and the final drive will run at a much cooler temperature. One quart of Hypoid gear oil will change the rear end oil 3 or 4 times so it is good, cheap preventive maintenance. Simply take off the large fill cap, place a pan under the small drain bolt at the bottom of the pan,remove the drain bolt, drain the oil, put the drain bolt back in, and fill the final drive to the bottom of the larger fill hole (usually a quarter to half cup of oil), then replace the large cap being careful to only snug it tight enough to seal in the oil. If you over tighten it, it is designed to break! Be sure to check the owners manual on the exact amount of oil to use. Honda has changed the fill technique for some of the newer models. With a higher fill hole on some newer models you may be over filling the final drive, so you may have to measure the amount. Too much oil will cause waste and may cause over flow out the top vent. Happy Trails.
Aug 15, 2011 | 2004 Honda VT 750 Shadow Aero
I need to replace oil pump on a 1988 ford bronco 2
Remove oil pan, making sure to drain oil first. Remove oil pump attaching bolts. Lift off oil pump and withdraw oil pump drive shaft.
INSTALLATION;
Prime the new oil pump by filling either the inlet or outlet port with engine oil. Rotate the pump shaft to distribute oil within the pump body. Insert oil pump drive shaft into block dwith the pointed end facing inward. The pointed end is closest to the pressed-on flange. Place oil pump into position with a new gasket and install attaching screws. Tighten the screws to 15-22 foot pounds of tourque. Clean and install the oil pump inlet tube and screen assembly with a new gasket. Tighten the bolts, then replace the oil pan.
Oil Pan;
Clean of any debris and replace gasket. Fit the oil pan bolts and tighten in two steps. Start from the rear/left hand side and tighten first, then tighten the bolt in the front/right side. Alternate from rear to front, working from back to front and front to back.
Oct 06, 2010 | 1988 Ford Bronco II
How to replace oil pump
REMOVAL & INSTALLATION
Gasoline Engines
See Figures 1 and 2
Fig. Fig. 1: Exploded view of the oil pump used on 2.0L and 2.3L gasoline engines
Fig. Fig. 2: Exploded view of the oil pump used on the 4.0L engine-2.8L and 2.9L engines are similar
  1. Follow the service procedures under Oil Pan Removal and remove the oil pan assembly.
  2. Remove the oil pump retainer bolts and remove the oil pump.
To install:
  1. Prime the oil pump with clean engine oil by filling either the inlet or outlet port with clean engine oil.
  2. Rotate the pump shaft to distribute the oil within the pump body. Install the pump and tighten the mounting bolts to 14-21 ft. lbs. on 2.0L and 2.3L engines; 6-10 ft. lbs. on 2.8L and 2.9L engines or 13-15 ft. lbs. on 4.0L engines.
Do not force the oil pump if it does not seat readily. The oil pump driveshaft may be misaligned with the distributor shaft assembly. To align, rotate the intermediate driveshaft into a new position.
  1. Install the oil pan as previously described. The oil pumps are not serviceable. If defective, they must be replaced.
Remember rated this.
Aug 11, 2010 | 1989 Ford Ranger
Where is the oil pump located in A 1993 ford thunderbird V6?
Inside the oil pan for the 2.3 and 5.0
  1. Disconnect the negative battery cable.
  2. Remove the oil pan.
  3. Remove the oil pump inlet tube and screen assembly.
  4. Unfasten the oil pump attaching bolts, then remove the oil pump gasket and the intermediate shaft.
To install:
  1. Prime the oil pump by filling the inlet and outlet ports with engine oil and rotating the shaft of pump to distribute it.
  2. Position the intermediate driveshaft into the distributor socket.
  3. Place a new gasket on the pump body and insert the intermediate driveshaft into the pump body.
  4. Install the pump and intermediate shaft as an assembly.
WARNING Do not force the pump if it does not seat readily. The driveshaft may be misaligned with the distributor shaft. To align, rotate the intermediate driveshaft into a new position.
  1. Install and tighten the oil pump attaching screws to:
    2.3L Engine: 12-15 ft. lbs. (16-20 Nm) 5.0L Engine: 22-32 ft. lbs. (30-43 Nm)
  2. Install the oil pan.
  3. Connect the negative battery cable, then start the engine and check for leaks.
On the 3.8...
The oil pump is mounted in the front cover assembly. Oil pan removal is necessary for pick-up tube/screen replacement or service.
  2. Raise and safely support the vehicle on jackstands.
  3. Drain the engine oil, then remove the oil filter.
  4. If necessary, remove the oil cooler.
  5. Unfasten the oil pump-to-front cover retaining bolts, then remove the pump from the front cover.
  6. Lift the two pump gears from their mounting pocket in the front cover.
  7. Clean all gasket mounting surfaces.
  8. Inspect the mounting pocket for wear. If excessive wear is present, complete timing cover assembly replacement is necessary.
  9. Inspect the cover/filter mounting gasket-to-timing cover surface for flatness. Place a straightedge across the flat and check the clearance with a feeler gauge. If the measured clearance exceeds 0.004 in. (0.10mm), replace the cover/filter mount. Replace the pump gears if wear is excessive.
To install:
  1. Lightly pack the gear pocket with petroleum jelly or coat all gear surfaces with Oil Conditioner D9AZ-19579-CA or equivalent, then install the the pump gears in the cover pocket. Make sure the petroleum jelly fills all voids between the gears and pockets.
WARNING Failure to properly coat the oil pump gears may result in failure of the pump to prime when the engine is started.
  1. Position the pump body O-ring seal and install the pump body to the front cover using alignment dowels on the front cover.
  2. Tighten the pump retaining bolts as follows
    1. For vehicles through 1993, tighten the M8 bolts to 18-22 ft. lbs. (25-30 Nm) and the M10 bolts to 30-40 ft. lbs. (40-55 Nm).
    2. For 1994-96 vehicles, tighten the four smaller bolts to 15-22 ft. lbs. (20-30 Nm) and the two larger retaining bolts to 6-11 ft. lbs. (8-15 Nm).
  3. If removed, install the engine oil cooler. Install the oil filter.
  4. Carefully lower the vehicle, then refill the engine crankcase with the correct type and amount of engine oil.
  5. Connect the negative battery cable, then start the engine and check for leaks.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 28, 2010 | Cars & Trucks
Oil pump replacement, location of it, nomenclature
Remove oil pan and pump is bolted to back main bearing cap. But this is most likely not the problem. This engine is known for cam bearings spinning out of the block and cam shaft breaking inbetween #3 and 4 cam journals, oil pump is driven off the end of camshaft, engine runs very rough and makes all kinds of noise when this happens, cure is a new engine. to check for broken cam shaft removed front valve cover, have some one start or crank the engine, the 2 rocker arms on the drivers side will not move at all, most likely there will be silver metal dust laying in the low spots of the head where oil puddles up.
Mar 01, 2010 | 2001 Oldsmobile Silhouette
How do you change a oil pump
This is straight from the book.
1. Remove oil pan.
2. Place large drain pan under engine
3. Unbolt the pump and exstension shaft from the rear main cap.
4. Lower same
5.Before reinstall prime the pump with engine oil. Pour oil in the exstension shaft while turning the pump.
6. Attach the pump, extension shaft and retainer to the main bearing cap.
(aling the pump with the dowel pins while you align the top end of the exstension shaft with the lower end of the oil pump drive.
Note when proper it fits into place easily.
7. install the pump mounting bolt and torque to spec.
8. Put the oil pan back on.
Jan 28, 2010 | 1997 Pontiac Sunfire
How to change oil pump in 1998 mercury mountaineer
remove the oil pan. remove the oil pick - up tube-to -main bearing cap nut. remove the oil pump pick-up tube mounting bolts. remove the oil pump mounting bolts and lower th eoil pump assembly. If the pump is faulty, or you suspect that it's faulty, install a new one- do not attempt to repair the orginal. The oil pump hex driveshaft will come out with the pump . Examine the ends for wear,"Caution": If this shaft breaks, serious engine damage can result. If it looks worn, replace it.
Mar 17, 2009 | 1998 Mercury Mountaineer
Karcher 2500 PSI Pressure Washer Logo
234 people viewed this question
Top Karcher Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
