Question about Hobart Microwave Ovens
Have a hobart sp 1500 scale , need to get into supervisor functions to put in new plu # but don't have Secret ID # that it is asking for. Any way to get rid of it or bypass it?
How do i know the weight of the turkey its not on the package
put in on kitchen scales or bathroom scales
don't have any --go to a neighbours and ask
Nov 23, 2017 | Microwave Ovens
SOME PAD FUNCTIONS DON'T WORK
Your keypad seems to be worn. You can order a new one by model off the internet and aren't that hard to replace. Just be careful.
Jan 23, 2012 | Microwave Ovens
Where can I get a operating manual for silvercrest digital kitchen scales num: Z30170. in english
http://www.lidl-service.com/cps/rde/xchg/SID-EE4A0FEC-2E826FB3/lsp/hs.xsl/product.html?id=8346817&title=Digital+Kitchen+Scale&count=1
Aug 04, 2011 | Microwave Ovens
Everything on it functions normally, but it doesn't heat
You can fix the problem by yourself, the problem is from the magnetron (sp), this has to be replaced to make the microwave oven functions effectively......
May 11, 2011 | Microwave Ovens
Its nan oxo pull out display food scale and the screen reads F when turning it on
My OXO scale has a removable weighing platform. I removed it and wiped off the top of the scale base. When I put the platform back in place and turned the scale on, the display showed the normal numbers and icons. The F was gone.
Apr 07, 2011 | Microwave Ovens
New CR2032 battery last about 1 week before the scales say that the battery is dead. Have tried lots of different battery brands and the same happens with all. We only use the scales a couple of times a...
Sounds like the scales have developed a leak across the battery and is draining the power. New scales maybe the best option but before that, have a look to see if there is any spilliage around the pcboard and/or battery terminals.
Jan 03, 2011 | Microwave Ovens
When i try to weigh something on it it displays 'our2'. And does not work
OUR2 is probably OutZ or Out2, means you have to recalibrate your scale. Refer to your scales manual for instructions on recalibrating, usually you have to turn on your scale, press CAL button, wait till it displays for example 100g, depending on how much your scale can weight, then put that weight, for example 100g on your scale (you can use coins if you don,t have anything else, though be precise as coins can weigh more or less,informationon coins weight can be found in your country national bank site. After you put the weight, it should display OK or PASS, if it's FAIL or the scale turns itself off, it's either broken or the weight is not correct
May 16, 2010 | Microwave Ovens
MICROWAVE WILL NOT HEAT
check the connections on the h.v side because the unit works on 4500 volts and if there are any bad connctions it will not reach its working voltage and will not energize.remove all the connections 1 at a time and tighten all the terminals and try it again.you will not be able to test the components with a digital multimetre as it does not have the range.you need an analoge unit with a 10k scale and a 9 volt battery inside or it will give you falsr readings.teh diode which is thge little black unit with 1 side down to earth should read half way with the laeds on 1 way then when you put it on the opposite side it should not move.the capacitor will make the needle of the multimetre flick up when put onto the terminals both ways.the magnetron should have a short reading on the terminals but with 1 connected to the terminal of the input and 1 to the case it should not read at all,hope this helps regards les
May 15, 2008 | Maytag MMV4205 Microwave Oven
Microwave Ovens Logo
166 people viewed this question
Top Hobart Microwave Ovens Experts
William Miller
William Miller
Are you a Hobart Microwave Oven Expert? Answer questions, earn points and help others
