Question about Campbell Hausfeld 26 - Gallon Air Compressor
My cambell hausfeld , model WL650001AJ won`t come on . Have power to and through ths switch . Motor hooked direct to power and no start . Any thoughts ?
  • Campbell Hau... Master
  • 885 Answers
Check for a reset switch on the motor or air pump. They're usually located on the edge of the motor housing sometimes partially hidden by the air shroud around the air pump. It's usually a white button about the size of a pencil eraser with a two digit number in the middle of it. If it's sticking out of its housing push it in to reset it.
Posted on Oct 14, 2010
  • 4 Answers
If you hooked power directly to motor there is nothing else. Did the motor hum when you did that? If not then you probably have an open winding in the motor.
If it did hum you may have a bind on the motor or pump.
Posted on Jun 17, 2012
Spray gun for cambell hausfeld model.#al2305-02..where can i get one
http://www.searspartsdirect.com/partsdirect/part-model/Campbell-hausfeld-Parts/Painting-equipment-Parts/Model-AL2305/0166/0733055
Dec 14, 2014 | Air Tools & Compressors
I have a grren white and back wires goin to my
Black is the AC hot wire.
White is the AC neutral wire
And the green is your grounding wire.
Black will prob go to power switch, then to air pressure safety switch, and then to the motor.
White may go directly to motor or power switch.
And green will go usually to motor case or common tie point for grounds.
Oct 19, 2014 | Air Tools & Compressors
My 5hp 13 gallon compressor won,t run when you turn it on there is no wind nothing at all how do i bypass the switch and hook it direct
you don't connect it up direct unless you want to destroy the compressor and burn the motor out
check for a reset or thermal overload button if it just shut down when over pressured
replace the pressure control switch is the best fix after checking out the motor condition
Jul 04, 2017 | Campbell Hausfeld 26 - Gallon Air...
Cambell Hausfeld model wl506201aj compressor Hums when switched on
This could be caused by one of two things:
- a stuck or broke tank check valve. This would be evident if the compressor starts up when there is no pressure in the tanks but only hums when the tank pressure is up. Some valves can be cleaned and will work for a while but they usually have to be replaced.
- motor start capacitor. If the capacitor is bad it won't get the motor spinning, with or without pressure in the tanks. You can test it by taking the shroud off the pump and carefully bumping the motor to get it turning. Be careful, it may run up to full speed right away. If it runs replace the capacitor, if not you may have a burnt or shorted motor.
Apr 11, 2012 | Campbell Hausfeld Air Compressor Check...
Name: Campbell Hausfeld S/N: 0519588 Year: 1996 3.5 HP 11 Gallon Do you carry parts for the compressor described above ? In particular a Conrad Kit
No
This is not a business
It is a social web site,
we are at home
Use the Cambell Web site
You can buy directly from them
Mar 15, 2011 | Campbell Hausfeld NoEX8300 5HP 20GAL Hd...
Campbell Hausfeld 26 - Gallon  Air Compressor Logo
542 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
