Question about Texas Instruments BA-II Plus Calculator
How do we calculate the crossover rate on the ba 2 calculator
SOURCE: Viking V714 calculator tax rate change
1. Press C button
2. Press 1 then 5 button for the 15% VAT rate - 15 is shown on screen
3 Press SET Button
4. Press TAX+ button
5 Press = Button - 15.00 is shown on screen
All is done, check by doing:
C
100
TAX+
answer will be 115.00
Press TAX+ again- answer is 15.00
Posted on Dec 29, 2008
SOURCE: Tax Rate change on calculator
1. Press [AC]
2. Hold [SET/%] key for about 2 seconds
3. Press [TAX+]
4. Input the tax rate
5. Press [SET/%]
Otherwise, see the Casio's FAQ page
http://www.casio.com/support/techsupport/08B88781-94BF-4C2F-A867-7E5AF85AC461
Posted on Apr 06, 2009
  • 3 Answers
SOURCE: No decimal display on TI BA-II calculator
Your BA II PLUS stores numeric values internally to an accuracy of 13 digits. However, the numbers it displays depends on the number of decimal places to which you have it set (choice of 0–9 or floating decimal). To set the number of decimal places displayed to three: hit [2ND][FORMAT][3][ENTER]This setting also continues indefinitely (even though the calculator is turned off and on) until it is changed.
Posted on Jun 11, 2009
SOURCE: How do I set the GST/VAT tax rate on a Casio WM220T calculator
This works on several different casio calculators
Press AC butoon
Press AND HOLD % /Rate Set button for 2 to 3 seconds - This is important
Press Tax+ button
Input the tax rate you want eg: 12½% = 12.5
Press the % /Rate set button again
Voila
Posted on Sep 01, 2009
  • 8073 Answers
SOURCE: Using e on the BA II plus financial calculator
To use the exponential function, you must enter the number then press [2nd][e to the x] or [e^x] for short.
e^(-0.1) is entered as (-)0.1 [2nd][e^x], where (-) is the change sign key
You will need to use extra parentheses to avoid errors.
20 - 18*( (-)0.1 [2nd][e^x] ) [=]
The Minus sign between 20 and 18 is the regular one. The (-) before the 0.1 is the change sign key (-) or sometimes labeled +/-. The asterisk is the multiplication sign.
Hope it helps.
Posted on Oct 15, 2009
I am trying to calculate powers with my Texas Instruments BA ii plus, but big powers such as ^360 gives me an error msg. How can I solve this problem? Thanks!
Break the problem up into smaller pieces.
There's a limit to how big a number the calculator can represent. Numbers as large as 10 times 10 to the 100 simply can't fit into the calculator. For really large numbers, calculate the mantissa and the exponent (power) separately.
For example, to calculate 2^360, first calculate 2^300: press 2 ^ 3 0 0 = and see 2.037036*10^90. Divide by 10^90 (and remember the 90): / 1 0 y^x 9 0 = and see 2.04. Multiply by 2^60: * 2 ^ 6 0 = and see 2.348543*10^18. Multiply that by the 10^90 we took out earlier by adding exponents and write down 2.348543*10^108. That number is too large to fit into the calculator but we got it by calculating the 2.348543 and the 108 separately.
Oct 25, 2013 | Texas Instruments BA-II Plus Calculator
How do I compute fractional exponents on the TI BA II Plus calculator?
The same way you raise a number to a non-fractional power, using the y^x button. For your example, press
3 y^x ( 1 / 1 2 ) =
or
3 y^x 1 2 1/x =
Dec 08, 2012 | Texas Instruments BA-II Plus Calculator
I can't figure out how to calculate the cube root of 216 on my BA II Plus Texas Instrument Calculator
Press 2 1 6 y^x 3 1/x =
The y^x button is located just above the 9 button, the 1/x button is located just above that.
Aug 22, 2011 | Texas Instruments BA-II Plus Calculator
I have two BA real estate calculator with the same problem. Each one is slightly off in the calculation. Example. $100,000 loan 6% rate 30 year term should have a 599.99 payment and when I input this...
$596.57 is what I get with payments occurring at the beginning of the month. Set it to handle payments at the end of the month. My calculator gives $599.55 for this case.
I'm not sure about the BA RE, but on the BA-II Plus you change the Begin/End setting by pressing 2nd [BGN] and 2nd [SET].
Mar 09, 2011 | Texas Instruments BA Real Estate...
How to calculate interest rate based on original balance and payment amount using BA II Plus
Work with the simple formula: Interest = Initial * rate * time
To find the total amount, add the Initial plus the Interest, then subtract what has been paid. This will change the amount of money that will be accruing interest, though, so if there is a payment schedule you will need to repeat this calculation to get an exact number.
Find more information on wikipedia: http://en.wikipedia.org/wiki/Interest#Simple_interest
Mar 07, 2011 | Texas Instruments BA-II Plus Calculator
I simply can not get the BA 11 plus to run a simple TVM calculation. Although I have the card, and feel that I am following the instructions properly, I always get error 5 code. What am I doing wrong?...
Error 5 indicates one of two conditions while doing a TVM calculation.
1) You tried to compute the interest rate when FV, PV, and PMT all have the same sign. Make sure cash inflows are positive and outflows are negative.
2) The LN input is not greater than zero during calculations.
The first is much more likely.
Jan 03, 2011 | Texas Instruments BA-II Plus Calculator
TI BA 2 Plus Calculator: Cannot figure out how to use log(10) function, not the natural log but the base of 10 log
The BA II+ does not have a key for the common logarithm function. You can calculate the common log of a number by calculating its natural log and then dividing by the natural log of 10.
log10(x) = ln(x)/ln(10)
The same procedure works for logarithms to any base.
Dec 14, 2010 | Texas Instruments BA II PLUS Financial...
How do i calculate a mortgage payment on a ba II plus calculator
Enter the number of months, press N. Enter the annual interest rate, press I/Y. Enter the amount of the loan, press PV. Press CPT then PMT to calculate the amount of the monthly payment.
Full details, as well as how to do other types of calculations, are in the manual.
Nov 10, 2010 | Texas Instruments BA-II Plus Calculator
Interest only payments
I gave up using the Texas BA II. I used an on-line mortgage calculator for interest only. I was able to get a full printout.
I would like to learn more about the BA II and how to do this type of math on it.
Thank you
Mar 02, 2008 | Texas Instruments BA-II Plus Calculator
Texas Instruments BA-II Plus Calculator Logo
1,617 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
