Question about Danby DWC283BLS Wine Cooler
I have a Danby DWC238BLS. There is power to the unit but the unit fails to cool. Any thoughts?
Danby Kegerator runs but does not Cool
sounds like maybe no coolant in system if compressor is working. you know like in your car a/c unit, sometimes refrigerant needs to be added. just a guess, I'm not an expert.
Nov 08, 2012 | Danby DKC645BLS Compact Beverage Cooler
Danby DPR2262W propane refrigerator stopped cooling
OK-to make this short-you either have a boiler tube blockage or Hydrogen diffusion.If your cooling unit quit suddenly,you more than likely have a boiler tube blockage due to precipitation of Sodium Chromate.If your cooling unit gradually quit working it's Hydrogen diffusion.This process is not easy to understand,and I won't bother you with the details as to why.By the way,burping is a myth,it dosen't work.If there is a blockage in your cooling unit turning your refrigerator upside down won't dislodge it.Danby dosen't make stand alone Propane refrigerators anymore,and since the cooling unit is foamed into the box,it's a throw away refrigerator.You will have to get a Servel RGE 400 made by Dometic.It's the same size as the Danby and I have those for a very good price.Go to: www.marvinspropanerefrigerators.com
Aug 20, 2012 | Danby DPR2262 Top Freezer Refrigerator
Cant find manual. How do you adjust tempature on this ? Thank you
First make sure that the unit is in Cool mode. (Press the Mode button: the choices are Cool, Dehumidify, Fan and Auto. You will see the mode at the top of the LCD display - Cool to the left and Auto above the temperature display) Then press the + or - buttons (or the up/down arrows on the remote) to reach the temperature that you want the unit to maintain. If you press both the up and down buttons together, the current set temperature will display for about 5 seconds. Then you can set the unit back into the Auto mode so that the mode and fan will switch on as needed.
Danby has the manual for the DPAC7099 on their site: http://www.danby.com/product/DPAC7099/4 . See the Literature tab. The direct link is http://www.danby.ca/cms/uploads/products/en_manual/dpac7099_web.pdf .
I hope this helps.
Aug 02, 2011 | Danby DPAC7099 Air Conditioner
Danby DPAC8399 Portable Air Conditioner no Cool air
You possibly might have a bad switch or have a dirty ac unit.Try 1st turning off the unit and cleaning the inside ...
May 27, 2010 | Danby DPAC8020 Air Conditioner
Our danby dwc 283bls is not cooling. The motor
If compressor is running and it gets hot and the unit does not cool the compressor is bad or you have a leak in the system. if you see oil there's a leak.
May 22, 2010 | Danby DWC283BLS Wine Cooler
How can you make your conditioner cool to 40 degrees
ACs are designed to cool down to about 68^F, don't think it has a chance of doing what you want w/o re-engineering the system which is not really an option.
Sep 26, 2009 | Danby DAC9003D Air Conditioner
I can't seem to get the A/C to work. I'm thinking of getting a hose as a last resort. It seems to alternate blowing cool air, then hot air after a few minutes. There's also a tendency for the a/c to...
The symtoms you describe appear to indicate that the AC might be low on the freon charge. Usually blowing cold and then hot is the first sign that the unit is low on refridgerant and is working hard to keep cooling.
Further, the tripping of the breakers/electric power also indicates that the unit is working hard to cool and as a result is running hot and is causing the power to trip off. If you can get a AC tech to recharge the unit, you should be all set.
Here's a link to a site with the owners manual and a troubleshooting guide for your unit. You can access it for free.
http://www.retrevo.com/support/Danby-DPAC9030-Air-Conditioners-manual/id/886bh650/t/2/
Hope this helps you get things working again! Best Regards!
Jul 31, 2009 | Danby DPAC9030 Air Conditioner
Danby ALSO does not cool 3 days old
Take it back where you bought it. A 12,000 BTU unit should be more than enough for a 192 square foot room, so there is some problem with the unit.
Jul 10, 2009 | Danby Portable Air Conditioner
Compressor runs and gets hot but does not cool unit
This product has been discontinued
i dont think many danby units are parts supported
more likely generic after market parts fitted by air con mechanics do the job
relay first might be a thematic one and an compressor motor fan relay
then check gas pressure
https://www.winecoolerdirect.com/danby-wine-cooler-dual-zone-dwc283bls/DWC283BLS.html
Service Manual.pdfwww.reliablepartsinc.com/danby/Manuals%20.../Service%20Manuals/DWC282%20%...
Mar 06, 2017 | Danby DWC283BLS Wine Cooler
Danby DWC283BLS Wine Cooler Logo
46 people viewed this question
Top Danby Furniture Experts
Dan Webster
Dan Webster
Dennis Boxerman
jdthefixer
Are you a Danby Furniture Expert? Answer questions, earn points and help others
