Question about Sony MHC-GX8800 CD Shelf System
Sony MHC-GX8800 only stays on for about 3 secondin then turns off the speakers are in correctly but still wont stay on
3 Suggested Answers
SOURCE: So when I turn on my sony MHC-GX8800 shelf system,
check speakers, you only use original speakers
Posted on Feb 22, 2010
I had a extremely similar problem with that model the only difference is that it used to turn off whenever I put the volume up. Anyway there was a peace of stranded wire behind the speakers terminal block connector, so be sure to check it out.
Posted on Jun 28, 2012
Mhc-rg222 red light blinks power button wont turn on unit
Check the back of the unit for speaker wire shorts, if everything looks fine suspect the output ic's in the stereo.
May 26, 2012 | Sony MHC-RG222 CD Shelf System
My sony mhc-s9d goes to 'push system protect;
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
May 18, 2011 | Sony Audio Players & Recorders
Every time i plug in my mhc ec99i it will click 3 times then say protect
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Mar 15, 2011 | Sony MHC-EC98Pi Shelf System
After turning on my Sony MHC-GX750 it goes into stand by mode. What can i do to fix the problem?
Turn the unit off and dis-connect the speaker wires, press power and turn down volume, if it comes out of standby mode and comes on it means there is a short in the wires or one of the speakers. But! if it stays in standby with everything dis-connected it proves that one or more of the audio output ic packs is shorted and needs a tech to resolve the issue.
Jan 28, 2011 | Sony Audio Players & Recorders
So when I turn on my sony MHC-GX8800 shelf system, it stays on for a few seconds and then turns off. The power button flashes red as well
Feb 02, 2010 | Sony MHC-GX8800 CD Shelf System
Stereo won't play
only use original speaker, check cable circuits..
Oct 31, 2008 | Sony MHC-GX8800 CD Shelf System
Lost speaker output at rear of unit
Check the continuity of your speaker cables either by using them on another system or with a test meter. Could be that the cables got damaged in the move.
JohnC
Jan 04, 2008 | Sony MHC-GX8800 CD Shelf System
Any experts out there?
Can air can put a film or sometimes dust on the laser. It will need cleaning by hand with soft cloth and alcohol.
Dec 21, 2007 | Sony MHC-GX8800 CD Shelf System
Hello
Please insert an Cleaning CD to clean the Laser pickup unit
Regards,
Aby
Sony MHC-GX8800 CD Shelf System Logo
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
