I hav a compaq nx9005, im running windows vista,when i boot up it says disk read error,,i dont think its reconizing my hard drive but i try to go into set up it wont let me change my config,,dont no wat to do,,its not the motherboard i hope,,ive run out of solutions,,,need help,,,,thanx
  • 6 Answers
It looks like your hard drives failed. You need to replace it and re install Windows vista on it.
Posted on Oct 14, 2010
I have a compaq laptop about 8 months when i turn it on it has a black screen says soft hard disk error 1 (301) what does that mean? how do i fix it?
a softdisk error 301 means the hard drive is failing it is common on hp and compaq laptops ( hp owns compaq) unfortunately you are screwed to say the leas the hard drive is failingt. BUT you can save your data by hooking up an external hd and running ubuntu live cd to boot and copy any files you need from your hard drive over. you can download ubuntu from ubuntu.com and download and burn the live cd then you will need to set via ur bios when you boot i think its f2 or del key to get into the bios then go to boot order and select cd dvd drive to boot b4 cd then boot into the ubuntu disk and copy your files.
Mar 14, 2011 | Computers & Internet
I got a message that reads Non-System disc or disc error replace and strike any key when ready. What do I do?
Here the reason why youre getting the error message
Remove the non-system disk from your boot device. For example, remove the non-system disk from the floppy drive or the CD-ROM drive.
Change your computer's boot sequence in you Bios. Make sure that you select a device that has boot files (or operating system files) installed.
If you start your computer from a hard disk drive, install a bootable operating system (such as Windows XP, Vista or Windows 7) on the drive.
Thanks for using Fixya
Jan 24, 2011 | Compaq Evo N620c Notebook
I replaced a hard drive and after loading windows xp, my laptop wont boot, it only gives a hard drive read error.
Remove it then insert again. if the problem as is use another hard drive... also check the set up setting of your unit.
Aug 19, 2010 | HP Compaq Evo n800c Notebook
Compaq SR1650NX HARD DRIVE MESSED UP RECOVERY DISK WON'T WORK REPLACED HARD DRIVE CAN'T GET BIOS TO RECONIZE HARD DRIVE SHOWS UP IN BOOT BUT NOT IN MAIN HP SAID TO INSTALL NEW OS HAD OLD 98SE LOADED WORKED...
Are you trying to set up a raid configuration? If not I would reformat using the 98 disk and reinstall. (You may be able to skip installing 98, try installing xp first and it should ask for the disk containing the software (win98) that qualifies for the upgrade.
Jul 11, 2010 | HP Compaq Presario SR1650NX...
MY cOMPAQ pRESARIO CQ60 fell and cant complete boot
Most likely in this case, the damage is to the hard drive or its connection to the motherboard. The CQ series though has a three point screw attachment for the hard drive so Im more inclined to think that the shock of the landing has damaged the read/write head on the hard drive. If you happen to have another hard drive for a laptop, try installing a new drive and run the installation disc and see if it will complete and boot completely....if it will then the problem was the old drive.
May 23, 2010 | HP Compaq Presario CQ60-249US Notebook
I have a aspire 6930 laptop from acer it will boot past post but not into windows not even in safe mode it just goes to green bar like windows is starting then blue screen with error stop:oxoooooo7b...
id reinstall vista ! if you want to do this you need to get in to the bios which u press F2 i believe when the comp first starts up when your in the bios scroll along to boot menu u shud see a boot list with your hard drive at the top ,you need to change your dvd drive to the top so itll boot from dvd , restart your computer with a windows vista disc in the dvd drive and i think it shud give you an option to fix your system if doesnt work then definitly do a clean install of vista using your product code . hope this works
Oct 18, 2009 | Acer Aspire 6930-6082 Notebook PC
Boot pc problem 2
Yes you have to delete the partitions making one large drive and then format it in NTFS as XP is more secure in this file system and utilizes the space better.
Feb 04, 2009 | HP Compaq EVO D510 Intel Desktop PC -...
Boot pc problem
You can solve this by going into the bios setup & changing the boot order. Make the dvd/cd drive 1st in boot line then hdd. This should allow you to boot up from the windows xp disc. Hope this helps & please rate this solution fixya. Thanks.
Boot up problem..
i dont think the internet files had a difference.
a disk read error mean thateither you have a floppy in your computer or the hard drive is corrupt. that cannnot be fixed so i recomend getting a new hard drive.
Jaddude
Jan 07, 2009 | Dell Latitude D600 Notebook
Non system disk or disk error
get a new hard drive and reinstall software + OS
May 06, 2008 | Compaq Armada E500 Notebook
Computers & Internet Logo
55 people viewed this question
David Payne
David Payne
