Question about Garden
The cutter head on my Dayton 2AC31A notcher is broken need a new one can you find a one
    Problem Solver:
  • 5 Answers
Call w.w. grainger parts. number is available at any grainger store
Posted on Oct 14, 2010
My ryobi 30cc grass cutter model rtp 3000 runs but no power to cut gass
I have seen the flex cable broken between the power head and the cutter head .
Feb 20, 2016 | Stihl FS 85 Weed Eater
Cutter spins freely
The driveshaft is broke in the tube or the head drive is broken or srtipped out. Take head off and pull out the cable. It just slides out.
Apr 16, 2014 | Craftsman 25cc Gas Line Trimmer
How do you change the cutter bar bearings on a delta 12 inch planer
You are looking at a major disassembly to get at the cutter head bearings, everything is built around the cutter head. The motor drives the cutter head on one end of it and the cutter head drives the rollers at the other end. Most of the components have to be removed to get the cutter head and it's bearings out. You can go to www.ereplacementparts.com and do a search on your model number for a good breakdown of your planner and see what you need to remove to get at the cutter head and it's bearings.
Sep 03, 2012 | Delta Masonry Tools
Why would one of the shaving heads on Shaver spin around??
Most likely, one of the shaver heads is damaged and the cutter is embedded in the comb causing the whole thing to spin. It could also be that the retainer that holds the blades in blace is worn or broken and can not properly hold it in place.
If you require new heads or retainer, you should find what you need at shaveroutlet.com
Sep 09, 2010 | Health & Beauty
Engine run but don't turn
You're a bit vague in your problem description here, but I'm assuming you mean that when you give your machine gas that the cutting head will not turn. First I would check the cutter head to be sure that no trash has wound itself around the shaft preventing the head to turn...if that is not the problem turn the cutter head by hand and check to see that the bearing inside the cutter head has not seized, it should turn freely with no noise....if no joy check the cable which runs through the shaft from the engine to the cutter head it may be broken or frayed, also check to see that there are no problems with the clutch (broken springs, broken pads, or a broken key) that should do it ...hope this helps...;-D
Aug 09, 2010 | Ryobi Garden
Problem with shaver
are you talking about springs under the center cutter bar between the foils? If so, you will need a new foil and cutter set. It is available at shaveroutlet.com with link below
http://shaveroutlet.com/braun-8000-series-360-complete-foil-and-cutter-p-143.html
Or maybe you refer to a spring that goes to one of the clips that hold the foil assembly to the pivoting swivel frame. If so, you will need the part linked below
http://shaveroutlet.com/braun-8000-series-activator-motor-drive-unit-p-36.html
Jan 14, 2010 | Braun 360° Complete 8985 Electric Shaver
New head
Hello Brian, You can give the folks at www.electricshaver.com a try. They typically stock all the replacement and repair parts for most brands of electric shavers.
Here's a link to their site where you'll find part #5646768 for about $38 for a new set of the cutter head and foil (screen). It's always best to replace BOTH the foil and cutter block (head) at the same time, as any mircro burrs or nicks in the cutter blades will quickly ruin any new foil screen.
http://www.electricshaverstore.com/get_item_5646768_braun-foil-cutter-kit-360-complete-8000-series.htm
As you know, this is the simplest and easiest way to get an electric shaver back to a "like-new" shaving experience.
I hope you find this Very Helpful and best regards!
Nov 11, 2009 | Health & Beauty
Cant get plasma cutter to arc
chek inner core of hand peace lead
Aug 07, 2009 | Welding Tools
Need thingy that replacement heads & cutter fits into
Remington R 950 replacement heads is Remington SP 19 titanium MicroFlex replacement heads and cutters.
Jan 11, 2009 | Remington Titanium Microflex R-950...
Garden Logo
60 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
