Question about Roper FES330 Electric Kitchen Range
Roper Oven FES310 will not go to self cleaning mode
SOURCE: self clean light blinks when you turn oven on (oven does not work)
I had this same problem with mine (still posted under unsolved) This is the simpler model with the old turn style knob and the lever you slide over to lock the door for cleaning What I think (keep in mind I know little about ovens, more about cars) is that the switch that tells the oven the door is latched is staying engaged, and this is part of the lever mechanism. I cleaned and lubed this mechanism (obviously I would guess you want to use a food safe lubricant) and then moved the lever several times with the oven on so I could see if it turned on. After a few tries the cleaning light went off and the oven light came on. No, its not really a technical answer, all indications to me where that the problem was in the switch which is part of the latch mechanism. Good luck
Posted on Dec 25, 2006
SOURCE: Oven wont turn on.
I tried several times to get my oven to work and nothing seemed to help. After downloading the manual from this site, my husband locked and unlocked the oven door several times very hard and it knocked something in place and now my oven works. I hope it works for you.
Posted on Dec 08, 2007
SOURCE: Roper Self cleaning Oven
how dirty is the oven? if it is not bad then 2 hours if it is then 3 hours.
make sure you don't have any pet birds in the house cause it could be toxic to them.
Posted on Nov 01, 2008
SOURCE: ROPER ELECTRIC RANGE SELF CLEANING
how long to leave on to self clean
Posted on Apr 18, 2009
jumptrout51
  • 3361 Answers
SOURCE: Have Roper LP Range model S8757. This is a self
Your oven temperature sensor is bad and must be replaced.
It is inside the oven, a short metal piece extends into the oven. It is secured by a screw into the back wall of the oven.
Posted on Oct 12, 2009
Testimonial: "Replaced oven temperature sensor and works great! I am now ready for the Holidays!!! Thanks for your help!!"
Why is oven door locked after self-cleaning mode?
How To Fix Oven Door That Doesn't Open After Self Clean ...
www.partselect.com/...Stove-Oven/Door-Will-Not-Open-After-Self-Clea...
How To Fix An Oven Door That Won't Open After A Self Clean Cycle ... This may reset the control and allow you to unlock the door. If you still cannot unlock the .
Repair - Dead oven after self clean mode, blank display ...
? 9:38
https://www.youtube.com/watch?v=UylZKwzAPow
Feb 22, 2014 - Uploaded by Random Repair
Repair - Dead oven after self clean mode, blank display, locked door Kitchen Aid Whirlpool How to repair an ...
Nov 26, 2015 | Kenmore Kitchen Ranges
How o clean my roper self cleaning oven
i wouldn't use the self clean,more problems than good,the oven gets up to 1000 degrees and can damage electronics in oven,you need the model number off of the oven,you can google it and find manual to tell you how to put it into self clean but like i say you're better off doing it with easyoff,also don't use self clean near holidays or any other speacial occaisions,in case it does do damage,you might not be able to get parts or parts will have to be ordered and might take longer than 7 to 10 days depending on brand name and age.good luck
Oct 19, 2014 | Ovens
F5 E1 error won't go away
You cannot bypass it. You can check for a broken door latch switch. fairly cheap repair.
Nov 16, 2013 | Roper FGS326RD0, FGS326RD1, FGS326RD2,...
Can't unlock oven door
Put the oven in self clean mode, it will lock the oven, once the self clean mode has started turn the self clean mode off, give it a second and the oven should turn off. Same thing just happened to me and it worked.
Dec 24, 2010 | KitchenAid Ovens
Stuck in clean mode. Ge Spectra xl44 My wife cleaned the over a couple of years ago using the self cleaning mode and ever since then the oven has been stuck in clean mode when we try to use it. I've...
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Nov 25, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
HOW TO START THE OVEN CLEANING MODE?
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
May 12, 2010 | Jenn-Air JJW8530C Expressions Collection...
Have Roper LP Range model S8757. This is a self cleaning oven but takes forever. So I cleaned it myself and now oven won't light. Get F3 on display.
Oct 12, 2009 | Roper FGP305 Gas Kitchen Range
How do I know when my self cleaning oven is over for Roper gas ra
If you have a digital display it will tell you when it's done,If not the average is about three hours for cleaning and another hour + for cool down the door usually won't open till the temp inside gets below 300 F but you can cancel the cycle anytime you like.
Sep 23, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Oct 31, 2008 | Roper FEP320 Electric Kitchen Range
Roper FES330 Electric Kitchen Range Logo
Top Roper Kitchen Ranges Experts
Dan Webster
Dan Webster
Jim Thurston
 Fix Your Board
Fix Your Board
Are you a Roper Kitchen Range Expert? Answer questions, earn points and help others
