Question about Motorola TalkAbout T5000 2-Way Radio
I wnt to use my motorola radio while hunting but can't seem to figure ot how to turn off the key tones. any help?
  • Motorola Master
  • 1,654 Answers
Hold in the + (plus) button while turning on the radio.
Best regards.
Posted on Oct 15, 2010
MT1500 shows full battery but beep's like it's dead
Hello
This double beep tone you are hearing is a acknowledgment tone indicating that the radio is in the transmitting mode. On the Motorola MT1500 radio you can adjust the tone volume separate from the reception volume by simply holding down the volume control and setting the tone volume level.
I hope this helps.
Bruce
Jan 04, 2014 | Motorola Radio Communications
My biggest issue is the "roger" beep. Want to use it for a hunt, but the beep is constant after hitting the PTT button. I have read that on some models, hold the + or volume button while...
Here is a link to the SX700 manual (very close match to the SX800, which we could not find a user guide for) http://www.giantintl.com/ContentManage/manuals/Moto/SX700.pdf
Look on page 2. Check both the Keypad Tones and the Talk Confirmation Tone (Roger Beep) instructions, on the lower left. This should help you.
Best regards.
Dec 28, 2010 | Motorola Walkie Talkie 2-Way Radio
Trying to get our Motorola (yellow/ black) to communicate with Midland two way radios. They Midland will receive messages from Motorola, but they can not send to it Motorola.
Most likely your CTCSS tone codes are not turned on on the Midland radios. The CTCSS codes are also known as "Privacy Codes" or similar.
They will be from 1 to 38. Your Midland manual will tell how to set the codes on the radios. The Motorolas usually show the selected tone code below the channel number.
Alternately, you may be able to turn off the tone code on the Motorola radio(s) by setting it to "0" or "off". Then you will not need codes turned on on any of your radios and they should all communicate fine.
Dec 16, 2010 | Motorola Walkie Talkies 2-Way Radio
Have Talkabout 250 and want to turn off the beeping. any ideas
The following instructions are for the T289, which is very similar to the T250. It is possible they will work to turn off your beeps.
Alert Tones
The Alert Tones (beeps) on the Talkabout radios are set at a fixed volume
level and cannot be lowered. However, Alert Tones can be disabled. When
Alert Tones are disabled, the radio will receive messages at the volume
setting you've selected, but you will not hear beeps when you press control
buttons.
Disabling Alert Tones:
1. Hold down the Monitor button while you turn radio on.
2. To re-activate Alert Tones, turn the radio off, then on again while holding
the Monitor button down.
Here is a link to the user guide: http://www.motorola.com/mdirect/manuals/T289_User_Manual.pdf
Oct 20, 2010 | Motorola Talkabout FRS 250 (14 Channels)...
There is a way to keep the radio from "beeping" after a transmission but i cant find it in the guide as to how to go about turning that feature off(?). The radio is 3-5 years old if that makes a...
It should be able to be turned on or off by holding the + (plus) button in while turning on the radio. We could not find the manual directly for the T5000, but here is a link to the T5100 and T5200: http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T5XXX_User_Manual_E.pdf
Best regards.
Oct 12, 2010 | Motorola TalkAbout T5000 2-Way Radio
Motorola T5100 Radio
Setting and Transmitting Call Tones
Your radio can transmit different call tones to other radios in your group so you can alert them that you want to talk.
To set a call tone:
1. With the radio on, press MENU 3 times. The current call tone setting flashes and displays.
2. Press + or - to change and hear the call tone.
3. Press MENU or PTT to set the new call tone or turn feature off.
http://www.motorola.com/mdirect/manuals/T50-T55_UserGuide.pdf
Sep 11, 2008 | Motorola Talkabout T5100 (14 Channels)...
Ring tone thingy
To set a call tone:
Sep 07, 2008 | Motorola Talkabout T5420 (14 Channels)...
Motorola T5210 does not receive
Are you sure that the radios share the same sub audible tone? Look at your owner manual for the section dealling with (and different people call it different things) ie: CTCSS, DCS, Private tone, code...etc... make sure that the tones are the same on both radios... this is usually the smaller number on the display.
Apr 13, 2008 | Motorola HT1000, MTS2000, MTX8000/9000...
Muting the sound
The sound produced by a Motorola radio when the mike is keyed refers to the "Transmitting Call Tone" which is another feature other than the "Interference Eliminator" or the "Roger Beep" feature.
On most Motorola GMRS/FRS TalkAbout radios, setting the "Call Tone" to 0 disables the feature. This is done with the radio ON by pressing on the "Menu" button 3 times which will result in the display showing the current Call Tone setting (flashing) and the letters CA; pressing on the <- or +> buttons will change selection (you will also hear the different Tones), select 0 (it may be up to 5 or 10 depending on the version). Press on the "Menu" or "PTT" button to set, save and exit.
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Nov 25, 2007 | Motorola TalkAbout T5530 2-Way Radio
Motorola TalkAbout T5000 2-Way Radio Logo
116 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
bill tarkulich
Level 1 Expert
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
