Question about Kenmore Ovens
SELF CLEANING DOS NOT WORK .I SEE DOOR LOCK NOT WORKING.ONLY USED IT IN ABOUT 5 YEARS.
    Genius:
  • 1,478 Answers
I will advice you unlock your oven by pressing and holding the "Clean/Off" button.
Take care.
Posted on Oct 14, 2010
Scholtes FE46 and the door is locked. Also no clock/timer lights. Temp/function and oven work but is locked even though completely cold.
Here are a couple of things to try:
  1. Unplug the unit or shut off the circuit breaker for 5 minutes. Plug the unit back in or turn on the circuit breaker. Set the clock and gently try moving the door lock lever (is so equipped) or opening the door.
  2. Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever (is so equipped) or opening the door.
Read through the following for mire info:
Appliance411 FAQ After self clean range oven door won open
Mar 25, 2016 | Ovens
Oven will not unlock after self clean
Unfortunately, the high temperature limit sensor probably failed during the self-clean cycle. The oven control unit will not receive the signal that the oven is cool enough to unlock the door without the sensor.
If the oven is cool, you can try unplugging the oven for a while and then see if the oven unlocks after power is restored. Pressing the Cancel button several times (or pressing and holding Cancel, depending on the model) may also work. Sometimes, starting a new cleaning cycle and then stopping it (and waiting for the oven to cool) will work.
However if the sensor has failed, the above steps are unlikely to work. You can try to move the lock manually. On some models, you can use a bent coat hanger to slide between the oven door and the frame and push the lock over. On other units, you might open the back panel and rotate the lock mechanism cam.
The oven will not work until the high temperature sensor is replaced. Sometimes the lock mechanism fails and that is what needs to be replaced. If the oven works, then look at replacing the lock motor.
I hope this helps. If your oven is under warranty, contact GE for the repair. Please add a comment with the model of your unit for specific information on the parts you may need.
Dec 29, 2013 | Ovens
The oven won't lock shut for cleaning
Before you go working too hard to get you oven to go into the self clean mode....check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Apr 06, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Gerangeoven door won't open
Is it in time bake?
Oct 04, 2009 | GE Ovens
Door lock lites keeps flashing but the door is not locked
The F9 code indicates there is a problem with the door lock.
Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
Try canceling the clean cycle without putting the control into clean.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^%$@#$%
Mar 02, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire Gas self cleaning - lock won't release/door locked
Hold the lock button for 3-5 seconds or Find the main circuit breaker for your oven. Turn it off for fifteen minutes, then flip it back on. This should allow the door to open. Another thing sometimes, the dial for self clean will hang up, but this should fix it.goodluck hope this helps
pls appreciate by rating as fixyaa. thanks
Dec 23, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Old Amana - no manual; can't operate self clean feature
Can you locate the model number on the oven? Also any particular name of the stove? The manufactured year. These should all be available on a stainless steel or aluminum attached plate , probably on the back of the stove or inside the door.
I wouldn't try using the self cleaning feature until we get some advice. it could lock up on you and not UNLOCK. Normally self cleaning takes place at 600 or more degrees .
I'm sure others still have the same stove., I will see what I can find for you.
Aug 21, 2008 | Amana AEW4530DDS Electric Single Oven
Oven clean 'dr', F9, door lock flashing
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question&&&&^%$%^
Jun 19, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Self-cleaning gas oven
Door lock motor has probably failed.....Self clean on many
ovens can be a self destruct mode. Door latch motors, sensor
probes and even the electronic controls can be destroyed by
this operation. On many freestanding stoves the lock motor is located in the right rear (looking from the front) with a long rod connected to the lock. remove the motor and unhook the rod from the motor cam. Sometimes bending a coat hangar into a hook and sliding from the right side into the lock you can unlock the door.
Jun 02, 2008 | Frigidaire Ovens
Ovens Logo
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
