Question about Admiral AW22 Top Load Washer
Agitated The agitator works when I hold it down, otherwise it floats up.  I can't tell if there is anything missing....
  • 240 Answers
Probably a bolt missing from middle of agitator
Posted on Jun 03, 2008
Clothes stuck under agitator
I would try to get clothes out, even if destroyed first. Otherwise,
there is a plastic cover cap on the top of the agitator. remove
by unscrewing or prying off. Hold down nut is exposed and remove
carefully, gently and with a ballanced pry up from underneath to raise agitator.
Aug 23, 2014 | GE WBSR3140DW Top Load Washer
I caught a piece of plastic bag in the power mate. The overload/ reset button is now lit and the agitator won't turn. I have taken the head apart removed the agitator and put it back in place, and there...
Try turning the agitator by hand-double check all is free and you have not missed anything-check manual for reset button-some buttons you have to hold down to reset-the manual should tell you how to reset
Jan 06, 2014 | Kenmore 28015 Bagged Canister Vacuum
I have a Maytag performa it works well but has developed a fault in that the agitator rides up and floats on its own when washing!
If you check toward the lower end of the agitator there should be a screw which is supposed to hold it in place. It may have come loose or come out altogether. Fixing it will stop the agitator floating up.
Jul 06, 2011 | Washing Machines
Machine wont agitate
If the machine sounds like it is running OK. The agitator has lost its connection drive shaft because gear splines that connect it to the agitator have been damaged. You didn't really do anything wrong, this just happens occasionally. Hopefully yours has a sleeve that can be replaced rather than replacing the whole agitator.
It is tricky on some agitators, their may be a nut on the top of the agitator that holds or connects the agitator to a drive shaft. The top of the agitator probably has a plastic cap that covers this up and can usually be pried off to expose it. If there doesn't appear to be connection like this then the agitator may simply lift up. If you decide to try lifting the agitator up, let me know and I give you further guidance.
You might also call your local Appliance Supply store and with your make and model number, ask them if you unit has the sleeve or do you have to replace the agitator. I'll bet they will tell you.
Mar 02, 2011 | Hoover Washing Machines
Agitator keeps rising up and washing getting stuck/twisted underneath
The nut that holds the agatator on has come loose and is properly floating around in the agitator.Or it just needs to be pushed down to lock it in place. At worst the bolt and nut has rusted away. (repair man)
Dec 21, 2010 | GE Washing Machines
Machine quit agitating, but spins fine
After looking further into the machine's actions I then grabbeds the clothes mover to see if that would do anything. It started agitating, so I just finished the agitation cycle by manually holding the appropriate area, and then I removed the agitator coupling and noticed that the splines were wore down.
Jul 22, 2009 | GE Washing Machines
AGITATOR
You are missing the coupling that holds the agitator to the shaft.
Aug 24, 2008 | Amana NAV5800A Top Load Washer
Loose Agitator
Usually, there is a bolt that holds the agitator on. If you remove the cap off the center of the agitator, you should find a bolt underneath that you can tighten back down. Adding a little thread lock to the bolt wont hurt.
Jul 10, 2008 | Maytag PAV2300 Top Load Washer
MAYTAG LEGACY MODEL # SAV205DAWW
I've got the same problem. The diagram is a bit deceiving because it appears to show the agitator/auger as one piece. However, the bolt only holds the agitator (lower portion) and then the auger slips in place over that. The fabric softener cup then snaps to the top of the auger.
Best I can tell is that the slotted 'ears' on top of the agitator are worn thus preventing a secure fit between the agitator and auger. I just finished putting some hard thumb pressure on each of the ears and bent them outward some. The auger fits much tighter now and I'm doing a test run of clothes. It is holding but I will probably have to replace what they describe as the agitator / auger assembly, costs $53.54. I don't see any other fix but would appreciate further input.
Thanks
Feb 01, 2008 | Maytag Legacy Series Top Load Washer
Maytag won't spin or agitate
I have had the same problem and found that the teeth on the under side of the agitator had been worn down to nothing... I assume this is from years of over loading (not from me) and so the agitator could not spin any more... i would tighten the bolt that holds th agitator on and it would come loose after a few loads. So my solution was to get a little bit longer bolt and newer plastic washer and tighten it as tight as i could and it seemed to work. Versus buying a new agitator base that would cost about $20-$30 and would have to wait for the part to be ordered. hope this helps
May 26, 2007 | Maytag PAV2300 Top Load Washer
Admiral AW22 Top Load Washer Logo
178 people viewed this question
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal De
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
