Fitted new hard drive my old one stoped working but it says no opperating system found
    Problem Solver:
  • 5 Answers
Hello, when you buy a new hard drive you have to install your own operating system. The Hard drive is blank from the factory.
Posted on Oct 14, 2010
My Maxtor 1000GB harddrive has stoped working. PN:9NZ2D8-500. SN:2HBECHWY. It connects by a USB and powed by a transformer that was supplied by Maxtor. All of the parts are about two years old, brough
I replace my hard drives after 2 or 3 years. Yours seems to have quit early, possibly the transformer is not working. If your external drive lights up, the electronics could be bad. At any rate, the bad news is it sounds like time for a new drive. I hope you have a backup of the contents.
Dec 23, 2017 | Maxtor Computers & Internet
Hi, I have a Seagate ST38421A HDD in an EMachines EOne PC, very old, Win98. When I turn on the PC it says there is no HD found in the system, and when I try to install Windows XP, it says it has no...
Sorry to say it it but your hard drive in your computer has stopes working. Best way to fix it is to buy a new hard drive for your computer or just buy a brand new computers.
Mar 04, 2011 | Seagate U4 8421 (ST38421A) Hard Drive
My original disk crashed... I bought a new drive, but can't seem to get the thing working... What do I do, to get the new disk working in the old housing... Thx
first check that both disks are the same and that the new one will fit the connections in the old casing...do the connections in the old casing and format the new drive...this should get the thing working..
Hope this is helpful?
Jul 01, 2010 | Iomega 1TB Home Media Network Hard Drive...
I recently bought a security system for my home. The Camera opperates in standard deffinition. I need to find a DVR to record on a hard drive that will record at least 200, but preferably 500 hours of the...
Hi I am vortash , Just a suggestion but why not just buy a USB video capture device off Ebay and turn an old lap top into a PVR then you can fit an external Hard drive and record for however long the hard drive is capable of ?. You would possibly have greater control of picture search also when trying to find a particular piece of recording . Regards Vortash
Mar 30, 2010 | Televison & Video
New sata hard drive i installed keeps saying ntl not found checked bios ok cant start up to format drive or insall opperating system any idea?
Hi mikecoombe,
The easiest way to put in a new drive is to boot to the old drive as a master then put the new drive in as a slave. Make sure that if your using all sata drives, that you specify which drive to boot to in your bios. Then Format from your OS, and load away.
Good Luck
Mark
Sep 17, 2009 | Seagate 500GB Maxtor Diamondmax21 SATA2...
Additional hard drive needed
Just buy a new SATA HD of what ever capacity fits your budget. Keep the old one as it works with your setup. There is no point causing extra work for yourself.
Power off the computer. Conenct Power to the drive and a SATA cable to the new drive (should be supplied with it) and the motherboard. Power on the computer and then format the new drive. The drive letter will be assigned by the Operating System. Once completed you have a new drive to use.
Sep 10, 2009 | Hitachi HTS541612J9SA00 120 GB SATA Hard...
Opperating system not found
First thing you need to try is remove all disks from the computer, CD's, DVD's, Media Cards, External Harddrives, Floppy disks or USB drives.
Any of these could be attempting to boot and causing the error. If you remove all of these and still get the same error, either the hard drive in your laptop or the installation of windows is damaged.
If the installation is damaged, you can restore the system using the factory set of Recovery disks from Toshiba but this will wipe out any files and programs you have saved on the computer.
If you try this and it fails, the hard drive is likely faulty and will need to be replaced, then the Recovery set can be used to set up the computer using the new hard drive.
Either way if you do have important files on the drive and need them back you may need to send the drive to a pro for Data Recovery. If so comment back here and I will get you contact info for one of the companies I use.
Chris
May 18, 2009 | Toshiba Satellite A215-S7422 Notebook
Putting damaged hard drive into new laptop
Have you considered an external case for your old hard drive? These can be found at newegg and tiger direct. I have successfully gotten data off of some old laptop drives this way. Hopefully your drive was/is not encrypted or this solution will probably not work.
In order to know if the drives will fit you would have to look up the specifications for both laptops. Look to see if they are both the same as far as hard drive size (2.5, etc), connector (IDE or SATA). One problem you will encounter just swapping out the drives is that there will be new hardware in the new computer and Windows sometimes reacts badly to a big change in system components. Sometimes it will blue screen, sometimes it will ask you to reregister and boot up, but even then you can have problems. Hopefully this helps some.
May 04, 2009 | Computers & Internet
Operating system not found
yes, the sys. settings is on the bios, scence theres nothing on the harddrive its telling you that you do not have windows (or any other opperating system) on it and it cannot run without it you can buy opperating sys. at wall-mart, bestbuy and other companys such as that.or if you have a windows (or other opperating system) you can run that cd and install
Apr 02, 2009 | Samsung (SP0822N) 80 GB Hard Drive
Error loading operating system
The Thinkpad T23 is old, and would not worth fixing. Save your money on a new one.
The problem with your laptop is that the hard disk or the disk controller has failed and therefore cannot find the operating system on the hard disk. The error message states that it can't see the operating system that is on the hard disk.
If the hard disk is the only thing that has failed then you can buy a new hard disk and install Windows operating system on it to get a working laptop again. You will also most likely need to download the device drivers (ie. video, audio, modem, LAN adapter etc.) from IBM to install after the Windows installation.
Try to borrow a 2.5" drive or get a cheap one from a computer market and fit it to your laptop to see if the BIOS can detect the hard drive. If it works then outlay some money to buy a decent size hard drive, no point wasting money if the laptop is faulty.
Dec 09, 2008 | IBM ThinkPad T23 Notebook
Computers & Internet Logo
David Payne
David Payne
