Question about HP LaserJet 4200n Printer
What is the replacement procedure jetdirect card hp 4200n? Does anything need to be reconfigured after the replacement?
  • HP Expert
  • 393 Answers
You may have to reenter the IP address sub net etc. One of the easier things to replace... -Carl Hinesburg Vt
Posted on Dec 01, 2014
2 Suggested Answers
  • 4 Answers
SOURCE: What is causing an HP LaserJet 8150 Error 82.0180?
It's from your jet direct card. Turn off the by weDownload Manager Pro" style="background-color: transparent !important; border: none !important; display: inline-block !important; float: none !important; font-style: normal !important; font-variant: normal !important; font-weight: normal !important; font-family: Arial, Helvetica, Verdana, Tahoma, sans-serif !important; height: auto !important; margin: 0px !important; min-height: 0px !important; min-width: 0px !important; padding: 0px !important; vertical-align: baseline !important; width: auto !important; text-decoration: underline !important; background-position: initial initial !important; background-repeat: initial initial !important;">printer andarrow-10x10.png pull out the network card. Turn the printer on and verify it goes to ready. Turn off and reseat the card and see if the printer comes to ready.
If yes - upgrade the jetdirect firmware and by weDownload Manager Pro" style="background-color: transparent !important; border: none !important; display: inline-block !important; float: none !important; font-style: normal !important; font-variant: normal !important; font-weight: normal !important; font-family: Arial, Helvetica, Verdana, Tahoma, sans-serif !important; height: auto !important; margin: 0px !important; min-height: 0px !important; min-width: 0px !important; padding: 0px !important; vertical-align: baseline !important; width: auto !important; text-decoration: underline !important; background-position: initial initial !important; background-repeat: initial initial !important;">the printerarrow-10x10.png firmware
If no, try the other EIO by weDownload Manager Pro" style="background-color: transparent !important; border: none !important; display: inline-block !important; float: none !important; font-style: normal !important; font-variant: normal !important; font-weight: normal !important; font-family: Arial, Helvetica, Verdana, Tahoma, sans-serif !important; height: auto !important; margin: 0px !important; min-height: 0px !important; min-width: 0px !important; padding: 0px !important; vertical-align: baseline !important; width: auto !important; text-decoration: underline !important; background-position: initial initial !important; background-repeat: initial initial !important;">slotarrow-10x10.png.
If that still doesn't work, try a cold reset with the card installed (hold down the green button as you power on, in 5-10 seconds the display will flash cold reset and you can let go and see if the printer comes to ready) Good luck! :)
Posted on Apr 18, 2014
Service error 4cf0 hp 4700
Try removing the JetDirect card, then see if the machine will boot and print a test page. If it works without JetDirect, then try replacing the JetDirect card.
Oct 15, 2014 | HP LaserJet 4700 Printer
Hp designjet error message 5.10
The 04C*** error is an internal data bus error. The hard disk drive and the Jetdirect card share this bus. With the power off, disconnect the HDD and remove the Jetdirect card. Power up and see if the error goes away and the plotter goes to ready. If it does, put the HDD and Jetdirect card back into the plotter one at a time and power up again to identify the failing part. If the error continues with the HDD and Jetdirect card removed, the bus controller has died and the main logic board needs to be replaced. Any of these parts can be ordered from: http://www.lpscomputer.com/c-654-designjet-1050c-1055cm.aspx
I can also be reached at 800-959-1575 to answer questions.
Apr 24, 2014 | HP DesignJet 500ps InkJet Printer
Trying to connect a hp designjet t610 to a network using a usb
You cant from a network on a USB connection. USB connections are for "local" printers. "add" the Designjet T610 printer to your other PC under "printers and devices" tab. Good luck !
Feb 19, 2013 | HP Designjet T610 InkJet Printer
I need to find the IP address of my HP Laserjet 4200n printer. I've gone through all menus, printed a configuration page, and nothing. How can I find it??
First look at the back of the printer where the network cable plugs into the formatter. There should be a blinking green light. No green light no network!
That means printer is talking to the host.
Print out the config pages again. On the 2nd page top left side should be a line "I/O card Ready"
If it is READY, look down the page and you should see the IP address.
You can also push the left side of the menu switch twice. You will see EIO X JETDIRECT MENU
That is where you find the IP address.
Apr 19, 2011 | HP LaserJet 4200 Printer
Can anyone tell me what an error message 82.0180 means on an HP Laserjet 4100?
Error 82.0180 means that the JetDirect Firmware is corrupted. Refer to your manual how to cold reset the JD (JetDirect) card. JetDirect card enables network printing. If problem persist after cold reset, you may need to purchase a new JD card or bring your printer to HP service center for repair.
Aug 19, 2010 | HP Office Equipment & Supplies
When trying to print on HP 4650 printer stops and displays 49.4C06 error code, how can I fix it? thank you
update the firmware first...if problem persists try removing the jetdirect card..if error goes away your jetdirect card will need replaced
Dec 16, 2009 | HP LaserJet 4650n Printer
Error code 04C300 001E0000
This is an IO error. If there is a Hard Disk installed, remove it - the printer will run fine without it. If that does not solve the problem, remove the JetDirect card and run the test print. If the test print works, replace the JetDirect card. Parts available at: http://www.lpscomputer.com/c-654-designjet-1050c-1055cm.aspx
Nov 19, 2009 | HP DesignJet 1050c plus InkJet Printer
Printer does'nt initialize
This could be a Jetdirect network card fault. Remove the card and power the printer on. If it powers up and goes ready then power it off again, refit the card and try again.Sometime reseating the jetdirect card will sort this problem If it doesn't work, then i recommend replacing the jetdirect netwok card.
Oct 13, 2009 | HP LaserJet 4100dtn Printer
HP 2420 Issue
Print a configuration page found under the info menu on the printer. Make sure that under options it shows the network card as being an installed otion (it will show enven if its a built-in embedded card) If it doesn't show you have a bad jetdirect card. If it does show make sure the IP address, Subnetmask and Default Gateway listed on the page match that shown on your SERVER & WORKSTATIONS.
If the card info on the config page reads 0000 then you will need to reconfigure the card through the menu.
If you are using a 615N Jetdirect card in the printer and it doesn't list on the config page it's most likely a bad card as they have been dying regularly. If and only if it's a HP 615N card, jump on HP's support chat at HP.com and go through the on-line chat. If your persistent and insist, they will replace the card for free. You will have to be persistent though and tell them to look up the service note that authorizes after warranty replacement. They know it's their but unless your persistent they will play dumb try and charge you. Hope that helps you.
Jul 11, 2008 | HP LaserJet 2420 Printer
Hp laserjet 4200 printer- how to find the current ip address?
To have an IP address for the printer you must either have a HP4200n or install a Jetdirect card into the printer. The Jetdirect or "N" version of the printer with the built in Jetdirect holds the network IP address. Subnet Mask, Gateway Derfault and handles the networking functions. If you have a 4200n or Jetdirect installed it will print out on the configuration page.
The standard HP 4200 doesn't have the networking capability without adding the card. In the event that you have a card installed and its not recognizing the card on the configutation page it may be bad. The HP 615n cards are known to have burn out issues. If you have to install a card to upgrade your printer, I recommend a HP 620n or better to get around the known bad issues with the 615n cards.
Jul 07, 2008 | HP LaserJet 4200 Printer
HP LaserJet 4200n Printer Logo
54 people viewed this question
Seeker5211
Seeker5211
