Question about Dishwashers
I have a whirlpool dishwasher model number du810swpq3, after the dishwasher stops, there is still a little bit of water left at the bottom. I've checked the drain air gap and it seems clear. Any suggestions??
bluegreenash
  • 661 Answers
SOURCE: Not draining...hose clear
not really, it sounds like you have done all the basics,
Posted on Oct 09, 2007
  • 121 Answers
SOURCE: water build up in dishwasher- clogged drain
I would not recomment putting chemicals in the dishwasher. There is usually some kind of filter in the bottomt at you can easily take out and clean. It's common to have parts of labels and plastic clog this up.
Try removing and cleaning this first. It may also be reached from a separate hatch in the fronc of your dishwasher, depending on the make and model. Just make sure it's securly back in place before you start it afterwards, or you may flood your kitchen.
You may also try to disconnect the hose and blow through it to see if you may be able to blow back any objects stuck there.
If none of this helps your problem may be in the pump, and then it's usually a job for professionals.
Posted on Nov 07, 2007
watugot
  • 290 Answers
SOURCE: whirlpool dishwasher stopped working...
It sounds like the thermal fuse in the control console has blown.
Turn power off to unit.
Remove the outer door panel and then the console.
Remove the black plastic cover from over the circuit board if it has one.
You should see the thermal fuse clipped to the circuit board housing.
If you have an ohm meter, check for continuity across it, it should read closed.
If you don't have a meter, unplug the wires from it and and hook them together.
Turn power back on to unit, hold door switches down and cancel cycle. The washer should drain the water.
If this doesn't work, check your door switches to make sure they are closing properly.
Posted on Nov 17, 2007
  • 351 Answers
SOURCE: Whirlpool dishwasher not draining
blockage in the drain hose somewhere
Posted on Mar 20, 2008
jbjaxiis
  • 95 Answers
SOURCE: Sears Kenmore Automatic Dishwasher: Models No. 14041 /14045 /14045... Problem:
Many dishwasher have their drainlines tied into under sink disposers. If a person caps the sink drain while dishwasher is running, it can back the water back to the washer keeping dishes dirty and backing up water
Posted on Jul 06, 2008
My dishwasher dosen't work drain.the water is left in the bottom.
What is the model number? Maybe as simple as a cloged drain spout or hose.
Mar 24, 2011 | Whirlpool Dishwashers
Hi, I have an ASKO D3250 dishwasher and it keeps stopping during the wash cycle and flashing the heavy pots and pots symbol simultaneously. I tried cleaning the filter basket and found a little plastic...
The part is a cap for the drain pump. You can put it back into position by removing the filters and placing it to the left of where the circular filter would be positioned. The part goes in with the part numbers on the bottom facing down. When positioned it should not interfere with the threads for the circular filter. You may have to scoop out the water in the bottom, to have a better look at how it is positioned. It is always normal to have a little bit of water in the bottom filter area (below the silver screen filter).
Oct 18, 2010 | Asko 24 in. D3530FI Built-in Dishwasher
I have a whirlpool model number du810swpq3 dishwasher. It began to emit smoke during the washing cycle. I immediately began to suspect a belt problem but this model does not have a belt. Any suggestions?...
You have to check the water pump.Solenoid valves. Check whether any electrical part getting over heated!
Switch of the machine after a short 5 mins run and check
Apr 07, 2010 | Dishwashers
Whirlpool Gold Quiet Partner Dishwasher - Leaking!
Hello Summers2Go! We are terribly sorry to hear of your concern with your Whirlpool Dishwasher. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your name, reviewer name (Summers2Go), phone number, street address, zip code, model & serial number, and date of purchase on the appliance. We would be happy to assist you. We look forward to your reply.
Jun 18, 2017 | Whirlpool 24 in. GU2500 XTP Built-in...
Whirlpool dishwasher float 'assembly' model-DU810SWPQ2
Enter your model number into a site like partselect.com to get a parts diagram for your dishwasher so that you can see what the part looks like. The float just extends through the base to close a micro switch so the dishwasher shuts off the inlet water valve.
http://tclaundryrepair.com/
Feb 17, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
No water
you should have a little round white mushroom looking piece on the inside bottom front right corner of the dishwasher tap it and see if it goes down and then it should work
Dec 22, 2008 | Dishwashers
Puddle on the floor, 36" diag. SW of Dishwasher door after cycle
TO MUCH SOAP RUN A FEW TIMES WITH OUT ANY AND STOP USE THE PACK OF SOAP
Dec 03, 2008 | Whirlpool 24 in. DU1055XTPS Stainless...
I turned on my Whirlpool dishwasher last night before I went to bed. It is a model number DU915PwP82. Sometime shortly after that, a water line broke in my neighborhood. The water was off and caused...
Hi.
Often there is a lot of grit in the water supply after a pipe has been repaired, and this may have clogged one or more of the valves in your line, or the gauze filter in the inlet port on your machine. I would first turn off the water to the machine and disconnect the flexible pipe at the inlet valve on the back of the machine. If the inlet filter is clogged, there is part of your problem. If it isn't, place the end of the inlet hose in a bucket and turn on the water supply a little bit to see if water comes out. If it doesn't flow freely, then it's likely another valve in the line is clogged.
I think the machine may have stopped because it is waiting for water to reach the required level. You could check this, I guess, by adding water from a jug and then closing the door.
Hope this helps you a bit. D.
Jul 31, 2008 | Whirlpool Dishwashers
Dishwashers Logo
249 people viewed this question
Top Dishwashers Experts
