Cool. Actually, I tried that, don't think that was the problem, [carriage may just have been jammed] but it may have been.
See I sort of half solved the problem [but it added a new one]. Releasing the carriage required a little bit of force [which I added with the release lever up and down to see which was which], which I didn't
want to use, but after many hours I got fed up. I did muck about with
the little tab, as part of it, suggested by another feller [Ryan], to release the mechanism, so maybe
that was a part of it, but on it's own it didn't work.
Directly
under the carriage, toward the right, built into the rail, is a little
lever, which I had also been fooling around with. I messed with the
initial tab, and pulled this little lever under the carriage, and
whacked the left side of the carriage with my hand [with escalating degrees of hardness] a few times till I hit it quite hard, while
trying to sort of jiggle it, or get it to budge (although at first VERY
lightly with a hammer, but I stopped because I didn't want to ruin it)
and finally it moved to the right and now swings freely!
But, this sort of led to a-
New Problem:
I
can move the carriage with my hand, and it is still connected to the
string, springs, and rails and all, but it doesn't lock, that is to
type, it just swings back and forth freely. Tapping keys has no effect
except to just whack.
I consulted with a typewriter guy on the phone [but he wants over a hundred bucks to fix it] and he said, seemingly certain, that "the main spring is broken".
Would you maybe have any clues about this? Any advice is appreciated as I would love to start typing with this!
Thanks a billion for your response and advice, and any more you may be able to render.
Regards,
Carl.
SOURCE: Olivetti Lettera 32 - carriage progression problem
Could be the carriage release lever is jammed or worse the escapement dog is broken.
SOURCE: olivetti lettera 22 replacement black/red ribbon ?
Try Office Depot or one of those big box office supply houses.The Lettera 22 is a pretty old typewriter, but the ribbons ought to be available
SOURCE: Broken Platen Knob on Olivetti Lettera 25
Platen knobs are usually held by an Allen screw in the side of the shaft, which can be hard to see and get at, but have a good look.
SOURCE: Can't find carriage lock on Olivetti Lettera 25
The unlocking lever is just below the right ink-roll up=loose down=locked for carriage.You slightly push the carriage bar to the right and at the same time push the lever in upward position. success!
