Question about Sony Televison & Video
My sony tv is problem colour which code for screen setting plz halp me modile kp-es43mn1 ser.no: 1001128
Soulvisitor
  • 1113 Answers
SOURCE: Sony rear projector KP-53517
You have convergence issues
See this link
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-i.html
and this one
Posted on Dec 29, 2007
  • 184 Answers
SOURCE: Screen shakes / jumps vertically on my Sony KP-51HW40
The jitter is called a vertical sync problem. The problem is on the "A" board. It can be replaced or rebuilt but will be quite expensive to service.
michtech
Posted on Feb 13, 2009
SOURCE: Sony tv rear video projector KP 51hw40 green screen, turns off
it cost $500 to fix then my red went
Posted on May 11, 2009
Wise Frog
  • 13 Answers
SOURCE: Sony wide screen projection tv model kp-57wv600.
I found this solution from SONY's website.
The STANDBY light will flash if an issue is detected within the television. This can sometimes be resolved by simply following the steps below to reset the television.
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required. Please note the number of times the STANDBY light flashes and relay that information to the service center.
I hope this helps.
Posted on Aug 05, 2009
  • 59 Answers
SOURCE: TV has colour lightning like effect then turns
sounds like you have a bad tube you can attepmt a temporary fix for this problem but is kinda hazardous and does'nt always do any good . but you can remove the front of the tv where the speakers areand tap on the base of the tubes lightly to see if you can get some of the carbon build up loose from inside the tube. also try adjusting the screen voltage for what ever color you see the lines for sometimes turning down the screen voltage can help
Posted on Jan 25, 2010
Can see image but the screen is all red
Generally Tv screens use three different colours to make the picture, and if one or two of these colours don't show you will see the picture but in specially one colour (like looking through a red filter in your case).
If you are using an input into the TV (DVR or Games console etc) then I would firstly move the cable around in the back of the TV and the console to see if anything changes or flickers in and out of being correct. If this does happen I would recommend buying a new cable to fulfil the purpose.
If this does not happen and you are still seeing red then there may be an issue with the connection inside the back of your TV, this shouldn't be a very expensive issue to fix as you are still getting a picture but I would recommend getting a specialist to check it out if you are not confident in fixing this manually.
Thirdly and most unlikely is the settings inside the TV have changed, some TV's like yours will allow you to change colour settings on the screen. I would go into the menu and find the section that allows you to change the colours and have a check to see if any of the settings seem off.
Dec 14, 2011 | Sony KP-57WS500 57" Rear Projection...
I have a Sony KP-46S25. The screen is cracked. I
There are 2 screens for this set, a protective (outer) screen and a fresnel (inner) screen. Which one needs to be replaced?
Dan
Apr 08, 2010 | Sony KP-46S25 TV
Sony tv rear projection screen 10 blink
change the switch and check for bad connection, Job must be done by some one who has basic electronics background.
Jan 03, 2010 | Sony KP-FX532M91 TV
Wavy coloured lines on the screen all the time & hue
Tv repairman. the green picture tube has an intermittent short in it. This is an expensive fix.
Mar 30, 2009 | Sony KP-51WS500 51" Rear Projection...
SONY TV MODEL # KP-65WV700 SER.# 9002706
Blue Gun is right side of TV if you look in TV from back side. Part number is as follows..
8-733-663-25 {CRT 07MVC62(B)-L} [KP-65WV700 ONLY]
Mar 13, 2009 | Sony Televison & Video
Vertical bars both sides of screen visable with white background
do thy get lighter going from left to right? prob bad scan filter in hv. need tech unless your very handy.
Dec 05, 2008 | Sony KP-53HS10 TV
Appearing rainbow colour for sometime and getting off.
There are few cold (dry) solder joints in convergence board of your tv Sony KP-46WT500
Please inspect convergence board and resold dry solder joints.
Oct 18, 2008 | Sony KP-46WT500 46" Rear Projection...
Televison & Video Logo
35 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
