Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
The tv randomly powers off in the middle of shows and sometimes i can turn it back on after a couple of minutes but then it turns back off, what could be causing this?
    Sergeant:
  • 171 Answers
I think this a common problem for a ballast board
It is not sending the correct signal to the lamp
PLEASE RATE THIS SOLUTION AS I DO THIS FOR FREE !!!!
Posted on Oct 14, 2010
I have a 58 inch Sanyo flat screen TV, I turn it on everything works fine, shuts down in about 10 minutes! Sound stays on though. If I shut it off and turn it back on it does the same thing!
Easiest TV repair - How to Fix Power [TV turns off, freezes ...
? 6:44
https://www.youtube.com/watch?v=OKklZpTGBGU
Apr 27, 2014 - Uploaded by Keith Fox
I demonstrate in this video how to repair a Sanyo by swap out the... the Sanyo DP47460 that I'm having an issue with. after ~ 40minutes of watching, if I attempt to change the channel or adjust the volume, the picture/screen freezes. ... After ~ 20 seconds, theTV will automatically shut off, then turn back on.
SAMSUNG TV REPAIR- TURNS OFF RANDOMLY - YouTube
? 9:24
https://www.youtube.com/watch?v=7Rj22VNhKXg
Jun 25, 2012 - Uploaded by Tampatec
EASY HOW TO FIX SAMSUNG TV- TURNS OFF RANDOMLY Clicking ... Hi, I've got a Samsung LED TV that switches off after20 seconds and remains off. .... after about couple of minutes, is this the same problem with the tv in the video? .... 10:32. How to repair a Samsung LCD TV with a flashing standby ...
TV Turns On, Backlight Inverter Immediately Turns Off TV ..
Dec 17, 2015 | Televison & Video
Tv randomly shuts off. Not sure if it is just overheating or if it is broken.
It sounds as if you are having problems with the AC Power reaching the television. Please verify the cord is firmly seated the tv's ac inlet
Also check the wall outlet (and power strip) by plugging in a lamp into it and see if it flickers when the tv shuts off.
Good Luck!
Rich Lilja
Mar 21, 2015 | Insignia NS-32E740A12 32" Class LED HDTV
Screen turns off on its own
Check its main power regulator for the fault. If there is any loose solder terminals, this kind of fault can occur. Re-solder all the suspected solder terminals and check. It it do not help you, replace the power board as card basis.
Feb 07, 2013 | LG 32LG30 32 in. LCD HDTV
TV Turns Off Automatically While Watching
Stop trying to turn on the set. You are causing more damage. The hissing sound you are hearing is either a High Voltage Transformer on the SMPS (Switched Mode Power Supply) indicating a short somewhere in the set or some capicitors that have shorted out. Also there can be a CRT that is leaking cooling fluid onto the Main bd or the Power/Deflection bd or both bds. Have a trained Samsung tech troubleshoot the set.
Jul 15, 2009 | Samsung HCM4215W 42" Rear Projection...
Tv turns off
sounds like a bad solder connection i usually fix these problems for a very fair price call tv shop but i'm 90% sure dad solder
May 02, 2009 | RCA HD52W58 52" TV
LG TV Turns itself off
Sounds like it could be a poor connection in the power plug or a ' dry joint ' on the power board, if it's the latter, it will respond to light thumping at the side of the tv. If that's the case it needs resoldering by a technician..
good luck !
Mar 30, 2017 | LG 32LG30 32 in. LCD HDTV
Ringing noise coming from my philips 30PW9110D/37
This noise is coming from the power supply.
You may want to look for a local repair shop from this website to get service if desired.
If the power supply were to be replaced, it could be done by you if you are somewhat savvy.
Mar 31, 2008 | Televison & Video
TV shutting off
try this part first 5600110347 you can get it at www.vancebaldwin.com
Jan 31, 2008 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Replace power relays on power board...
Bill
Oct 08, 2007 | Philips 55PP9401 55" Rear Projection...
Screen 1/2 black with random caption in middle side
CHANGE CAPTIONS SETTING YOU HAVE IT ON TEXT1 TURN OFF THIS SETTING. IN YOUR SETUP MENU
Aug 16, 2007 | Sanyo DS24205 24" TV
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
