Question about Sony Televison & Video
I have a sony model KP-48V90 All of the sudden the picture started ghosting and the color went green and redish haze
  • Sony Master
  • 3,459 Answers
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
To get fixed either call in a local TV repair company or goto sites such as www.TvRepairKits.com to get a repair kit with instructions.
Posted on Oct 15, 2010
Triple colored ghosts
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 17, 2010 | Sony KP-43T90 43" Rear Projection...
Sony 51" Rear Projection TV is blurry with colored ghost images
Thats caused by a convergence failure. The Sony type 1 convergence repair kit from www.tvrepairworld.com will usually correct that issue the kit contains the components and the CD with repair instructions so you can repair yourself.
Dec 20, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
The screen is redish in color and the sound doesn't work!
This link has the instructions on how to fix this problem and other similar problems. You
have nothing to lose, so I recommend that you try it.
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
This works with the two other colors, blue and green also. Not all models of Sony Projection
TVs have the red, green, and blue pots in the same order as the picture that is listed on
this link, so you may want to google search for your model's service manual. The service
manual can also help you be able to remove the cover for your particular model of TV. I was
able to find the service manual for my model, and sure enough, the order of the pots are
reversed on mine, so I would have been adjusting the wrong color. Read all of the comments
on this link too, because you can find other helpful tips and may even find someone with the
same model of TV as you that gives more specific instructions for your model.
You may also find your model's service manual here:
http://esupport.sony.com/US/perl/index.pl
You can find information on Sony blink codes here:
http://www.somelifeblog.com/2007/08/sony-tv-led-blinking-codes-what-does-it.html
Blurry picture/adjust convergence
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C426085
I hope this helps you!
Fare well. :)
Iconoclast
P.S. You can also clean the mirrors and dry dust while you're in there which can help with blurriness and focus.
Jul 19, 2009 | Sony KP-57WS500 57" Rear Projection...
Sony KP-43T75 color repair
This link has the instructions on how to fix this problem and other similar problems. You have nothing to lose, so I recommend that you try it.
This works with the two other colors, blue and green also. Not all models of Sony Projection TVs have the red, green, and blue pots in the same order as the picture that is listed on this link, so you may want to google search for your model's service manual. The service manual can also help you be able to remove the cover for your particular model of TV. I was able to find the service manual for my model, and sure enough, the order of the pots are reversed on mine, so I would have been adjusting the wrong color. Read all of the comments on this link too, because you can find other helpful tips and may even find someone with the same model of TV as you that gives more specific instructions for your model.
Fare well. :)
Iconoclast
Jun 27, 2009 | Sony KP-51HW40 51" Rear Projection...
Sony kp-48s75, shadow or ghosting picture
The most likely cause is shorted convergence chips and possibly a few pico fuses.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
*Screen Looks 3-D
*Colors wont align
Problem #2
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 07, 2009 | Sony KP-48S75 48" Rear Projection...
Getting Ghosts and color line separation.
my sony kp-57wv600 is showing a ghost of the image in all three colors.. anyone no how i can fix
Dec 27, 2008 | Televison & Video
Sony KP-51WS510 has a haze or back glow that cant be adjusted
It seems U are having no screen voltage.
U need to get it repaired
Rifaa
Nov 10, 2008 | Sony KP-51WS510 51" Rear Projection...
Convergence and picture problem.
convergence ic's
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
Jan 07, 2008 | Sony KP-57WV600 57" Rear Projection...
Sony KP-48V90
seve la pantalla toda verde y con rallas horisontales
Jan 06, 2008 | Sony KP-48V90 TV
Distorted picture
dont touch those lenses that is not your problem the problem is your convergance ic are bad replace them and the fuses and this will fix your problem
Sep 15, 2007 | Sony KP-53HS30 53" Rear Projection...
Televison & Video Logo
102 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
