Question about Canon Office Equipment & Supplies
Paper feeds skewed to one side. Ink smears, paper twisted and jams.
  • Modemo Aug 28, 2008
    The paper starts moving on the right side but the left side is jammed.  This causes the paper to go through the printer at a tilt and come out damaged.  This is from the automatic feeder.  I can't get the cassette to work at all.
    I can print 4 X 6 prints by feeding them on the right side.
    I tried to clean the rollers but paper wouldn't go through.
    Mo
My ip4300 was pulling the paper in toward the right and then it would crnkle the paper and jam. I tried all the cleaning techniques I could find suggested on the web. I called my grandson, who used to work on printers, and he suggested using sandpaper to roughen up the feed rollers (two on the right side when facing the printer.. a large and a small). So, I first used some #100 sandpaper to roughen the rollers, but that did not fix the problem. I then used some #60 sandpaper, then used a damp cloth to clean the rollers after roughing them up and then dried them with a dry rag. My printer now works beautifully! If nothing else works, you may want to try this—it's what my grandson said they did at the shop he worked at.
Posted on Jun 27, 2009
HP 4250 SKEWING PAPER
Yes, it is possible to be the problem. Most of the time you would replace the whole fixing unit, it could also be the paper feed rollers in the paper tray or the manual feed tray. Good Luck
Sep 04, 2012 | HP LJ 4250 Printer
When i give print command the paper was jammed in printer.
The following sections describe how to load media into the different input trays. CAUTION: If you try to print on media that is wrinkled, folded, or damaged in any way, a jam might occur. Priority feed slot The priority feed slot holds one sheet of media up to 163 g/m2 (43 lb) or one envelope, transparency, or cardstock. Load media with the top forward and the side to be printed facing up. To prevent jams and skewing, always adjust the side media guides before feeding the media. Back to top 150-sheet main input tray The input tray holds up to 150 pages of 75 g/m2 (20 lb) paper or fewer pages of heavier media of 25 mm (0.9 inches) or less stack height. Load media with the top forward and the side to be printed facing up. To prevent jams and skewing, always adjust the side and front media guides. NOTE: When you add new media, make sure that you remove all of the media from the input tray and straighten the stack of new media. This helps prevent multiple sheets of media from feeding through the printer at one time, reducing media jams.
Also go to this link to do a Printer Cleaning
Dec 03, 2010 | HP LaserJet 1020 Printer
6110xi leaves a dark line on the right 1/3 side of the printed page. It usually looks like just a pressure impression mid print and sometimes leaves other 1/2 spaced ink smears on the borders. The...
Print is skewed
  1. The rear access door might not be fully locked into place, causing the paper to skew in the all-in-one. Remove the rear access door by pushing in on both release tabs as shown in the figure below. Inspect it for damage, and then reinsert it. Make sure it is securely latched in place. Figure 6: Releasing the rear access door latch on one sidec00222462.jpg Figure 7: The rear access door removedc00222463.jpg
  2. The paper feed rollers may be dirty. Over time, paper fibers and dust will stick to the rollers and should be removed.
    1. Unplug the power cord from the back of the all-in-one and open the front to expose the print mechanism.
    2. Gently wipe the paper feed rollers with a soft clean cloth slightly dampened with clean water. These rollers may be rotated with the power unplugged.
    3. Remove the rear access door shown in the figure above and wipe the paper supply feed rollers. These rollers may be rotated with the power unplugged. Allow the water to dry for five minutes before reinserting the rear access door and locking it in place.
    4. Close the all-in-one and reinsert the power cord.
Apr 07, 2010 | HP OfficeJet 6110 All-In-One InkJet...
MP830, how to retrieve faxes in memory to my PC
- A margin appears
on printouts.
2 B Paper feed
Improper paper
feeding:
- Multi-feeding
- Skewed paper
feeding
- Paper jam
- Paper feeding from the
ASF
- Plain paper
- Highest print speed
(Custom setting to 5)
- In the high temperature
and high humidity
environment
- In the low temperature
and low humidity
environment
- With the maximum
amount of paper set (13
mm)
and high humidity
environment, paper
becomes wavy; in the
low temperature and
low humidity
environment, paper
curls significantly.
When the maximum
amount of paper is set
in the ASF, and if the
paper-return tab fits in a
wave or curl of the
paper, the tab slips and
does not catch paper
properly, causing paper
feed problems.
- Reduce the amount of
paper set in the ASF to
half (approx. 5 mm
high).
- Multiple sheets of
paper feed at the
same time.
- Paper feeds at an
angle.
- A paper jam
occurs.
3 C Print results
Skewed paper
feeding (at the
level of +/- 1%)
ASF
- Credit Card size
Since coaxial tolerance
between the pinch roller
and the LF roller, which
determines the paper
feed alignment, is
0.2mm, skewed paper
feeding can occur.
However, according to
the field data of current
models, the skewness
level caused by the
coaxial tolerance of
0.2mm is within the
criteria of +/- 1%, thus
the phenomenon is left
as is.
- Align the paper guide to
the paper edge tighter
than usual.
- Paper feeds at an
angle.
- A margin appears
on printouts.
4 A Print results
Soiling on the
back side of paper
(lines or streaks
parallel to the
paper feed
direction)
- After continuous
borderless printing of
small sized paper (such
as 4 x 6), when a larger
sized paper (such as A4)
is printed.
- With Photo Paper Plus
Double Sided or
postcards, the
phenomenon is likely to
be noticeable and to be
complained of by users,
as printing is performed
on both sides of such
paper.
In borderless printing,
printing is performed to
the size slightly larger
than the paper size, and
ink off the paper is
absorbed by the platen's
ink absorber. Absorbed
ink may attach to the
platen rib(s) after
several dozen sheets are
printed, causing soiling
at the leading edge of
paper or on the back
side of paper.
1. Perform Bottom plate
cleaning (from the
MP driver or via the
operation panel) up to
3 times*1.
2. If soiling on the paper
still remains after 3
times of Bottom plate
cleaning, wipe the
platen rib(s) and their
surroundings with a
cotton swab.
- Paper gets
smeared.
- The back side of
paper gets
smeared.
Soiling on paper in
automatic duplex
printing (lines or
streaks
perpendicular to
the paper feed
direction)
- Automatic duplex
printing (Photo Paper
Plus Double Sided,
postcards, plain paper)
On the rib(s) inside the
sheet feed unit used for
duplex printing, ink
mist may accumulate,
smearing paper.
Temporary operational
solution:
Cancel automatic duplex
printing, and manually
print each side of paper.
Cleaning by user:
cleaning (from the
3 times*1.
- Paper gets
smeared.
- The back side of
paper gets
smeared.
- Even after Bottom
plate cleaning
was performed,
and the platen
ribs were cleaned
with cotton swab,
paper gets
smeared.
2-10
Oct 12, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Paper is jammed--how can i release roller to access the paper
ASF paper feed
roller cleaning
- When paper does not feed properly.
- When the front side of the paper is smeared.
To clean the paper
feed rollers.
- Machine buttons
- Computer (MP driver)
2 min.
Oct 08, 2009 | Canon Office Equipment & Supplies
The fax part of my machine feeds only one side of the paper causing it to jam. Is it the rollars that are broke or is it something I can adjust
most times it is wear, check that there is nothing caught on one side that will cause paper to skew. Another factor is a slippery guide wheel caused by excess ink buildup from the paper. Use alcohol to clean all the rollers. Put papert into carriage ensuring no dog ears and restart.
Jul 27, 2009 | Office Equipment & Supplies
Paper jams at front feed. noisy when starting. grinding noise
Run remove ink smears. Clean pick an feed rollers with packing tape.
Jul 27, 2009 | Xerox Phaser 8500/DN Printer
Black ink smears everything.
you may have to clean the print head. since the jam cause the smear, and there still have some ink left on the print head.
you wouldn't get aclean copy till all of the ink trace are gone.
May 20, 2009 | Canon Office Equipment & Supplies
141 people viewed this question
old marine
old marine
