Question about Brother IntelliFax-2820 Laser Fax
While trying to fix the auto confirm function, we seem to have disabled the fax ing ablility of the machine
  • 46 Answers
Press reception mode button until auto is shown.
Posted on Oct 15, 2010
Trying to print a fax confirmation
Press
Function
66
set
for individual confirmation
stop
Press
Function
74
set
12
set
set
stop
For confirmation always
Nov 30, 2009 | Panasonic PanaFax UF-8000 Laser Fax
FAXING CONFIRMATION
to disable tx confirmation report on a c250
1 press the utility/counter button
2 touch administrator setting
3 enter the password 12345678 and touch ok
4 touch fax setting
5 touch report setting
6 touch tx report
7 touch off
8 touch exit and return back to the normal copy screen
Jan 19, 2009 | Konica Minolta bizhub C250 All-In-One...
Auto print off
Most often, Auto Print Off is activated by pressing the On/Off button, and documents are then stored in memory. Disable this function by pressing the On/Off button again.
The fax will also turn off Auto Print when the machine runs out of ink or paper, in which case, you should replace the ink cartridge or supply more paper. This situation usually results in display of the message Rec'd in Memory as well, and the unit will receive up to 30 transmissions or 60 pages maximum.
Please post back if you need further help, otherwise thank you for using and rating FixYa!
Jun 07, 2008 | Canon FAX-JX200
TECHNICAL PROBLEM
May 22, 2008 | Canon FAX-JX200
Screen display auto print off
Course:
[Manorhouse:
Try holding the button down just a moment as opposed to tapping. If it still doesn't work, please post a new issue, by selecting "Ask Me", and I will continue to help you through other troubleshooting steps. You need to make sure to check that all your other supplies are in place and OK! Thank you.]
Apr 22, 2008 | Canon FAX-JX200
Telephone callers get fax sound even when fax is in manual
Sounds as though you are answer ing a phone that is not connected to the unit and you have the Man/Auto switch set to on. Press Function then Data Registration press Set using the > scroll to RX Settings press Set scroll to Man/Auto Switch make sure it is turned to Off.
Apr 21, 2008 | Canon FAXPHONE L80 Laser
How to set an old fax machine
function 7,1 set for date & time, press set after entry
function 7, 4 set then parameter 12 for confirmation report, set to on.
Apr 16, 2008 | Panasonic Panafax UF-560 Plain Paper Laser...
Pana fax uf 8000
I'm not sure which key is used on that model but look for a key that says one of these: menu/user settings/reports/program.
what you are really trying to do is get to your reports programming section, then select tx report, then choose print tx report and will fix your problem, you may want to change you fax number if that number changed also.
mikey
Mar 14, 2008 | Panasonic PanaFax UF-8000 Laser Fax
Confirmation pages
press function
press dataregistration
press set
use scroller up and down to select the function that you want to do, there's a lot of function, like user setting, report setting vvvvv.
select user settings, then scroll up or down
select activitiy report, then set it auto print off
will help you, play around with it.
Oct 22, 2007 | Canon FAXPHONE L80 Laser
Fax function doesn't work
check your phone lines.then connect it to the machine.press on hook dial.if dial tone is not there you may need a service engineer.
Apr 05, 2007 | Ricoh Aficio 2018D All-In-One Laser...
Brother IntelliFax-2820 Laser Fax Logo
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
