Question about MSI : K8N Neo4 Platinum Athlon64/S939/nForce4 Ultra/DDR400/PCI-Express/ATX Motherboard (MOT81)
Power supply Good day i have a viper atx case,I am running windows xp pro, have 3 hard drives,2 80 g,and 1 300g,1 video card 8600gt nvidia ,2 sticks of 512 mb,cpu is a 3500 amd ,motherboard is k8N Neo4,now programs are incrediamail,google is my browser ,i have alist of programs that are too few to mention , i play time shift and fear,and bejewled 2.I was told that my power supply was too small which was a 5oo watt ,replce it with a anctec 850 true power quattro last feb of 08 ity fried last night as i was playing bejewled and listing to some tunes,i was told this morning that the power supply was over tax,are they right
  • 3 Answers
Ok you will need a gaming computer power supply to run this or it will over power and blow up not literally but it wont work
Posted on Jun 02, 2008
Computer shuts down on its own. First it starting
Could be HArd disk drive issue or Windows OS issue, try repair windows operating system before you change your hard disk drive , good luck
Aug 07, 2013 | Computers & Internet
My nvidia 8600gt wont work it is installed properlly
@Duarte,
Don't see what you are stating. Linda's statement was 220 WATTS or 320 WATTS, not Voltage.
(Voltage X Amperage = Wattage, capish?)
@Linda,
A) Minimum power requirement is 300 Watts, for an Nvidia GeForce 8600GT.
This is of course, based on a full computer system, AND the graphics card, by the graphics card manufacturer.
Card by itself uses 92 Watts.
http://extreme.outervision.com/PSUEngine
(Takes a couple of seconds for the page to load)
B) Due to your statements about the present Power Supply, I feel it is a generic model.
Made back in the time when Power Supply manufacturers would 'fudge', the actual maximum rated Wattage, to sell power supply's.
Actual maximum rated Wattage, would be more like 60 to 70 percent of what is stated.
220 Watts? That would be either 132 Watts (60 percent), or 154 Watts. (70 percent)
320 Watts? 192 Watts or 224 Watts.
As you can see neither fits the bill.
C) Don't shoot the messenger, but you do have the monitor plugged into the GeForce 8600GT, right?
Do you know the monitor cable is good? Monitor?
D) Did you observe Anti-Static Precautions when building the computer, and installing the graphics card?
If not you have an expensive doorstop.
(Motherboard does make a good one-way Frisbee, though)
E) Unclear of this statement of yours to Nicholas;
".....but not sure if the power supply is big enougth either seems to be running......."
I got the part about, not sure if the Power Supply is big enough,
[ A) + B) ],
Explain -> .......either seems to be running.......
Post back in a Comment.
F) Installation disk of graphics card is installed -> F-I-R-S-T.
Drivers and Nvidia Control Center are installed.
(Or downloaded, and installed from Nvidia Support website, or graphics card manufacturer website)
If not there is a driver conflict.
Drivers: Small pieces of software that allow the Operating System to communicate with a device.
Windows XP and Windows 7 are two examples of an O/S.
The graphics card in this case is the device.
When a device is installed, Windows 'breaks it's neck' to find suitable matching drivers.
If THE drivers are not there Windows will match up one of it's THOUSANDS of generic one-size-fits-all drivers.
This = No.
A driver conflict can result.
Windows: "Which drivers do I use? These or THESE?"
Installing the drivers, will do nothing to the present drivers already being used, nor graphics.
You'll still be using the same Ol' drivers, until the new device is installed.
Regards,
joecoolvette
Aug 27, 2012 | Gigabyte Computers & Internet
MY COMPUTER GOT LOST POWER SUDDENLY NOW THE PROBLEM IS WHEN I TURNED ON THE POWER BACK NO BOOT COME OUT FROM MY INNO 8600GT VCARD I REMOVED THE VIDEO CARD FROM THE MOBO AND USED THE BUILT IN GRAPHICS THERE...
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error hope this helps
Apr 17, 2011 | Nvidia Inno3D nVIDIA GeForce GT240 (1GB...
My husband recently built a new computer (previously built 5 others successfully). Motherboard seems to be working properly. Green LED lit. Graphics card works in another computer. Power supply...
Hi, the thing to do here is to narrow down what could be causing the problem, initial suspects would be the RAM chips. If you have known working ones you can try in it, try these, if not, try without one, then swap them over, or even try without both.
Also, remove any components that aren't strictly necessary, i.e. hard drives & cables, cd-rom/dvd drives, extra PCI cards,network cards etc
Another suspect may be just a loose connection, try taking everything out, re-seating it. Again, pay particular attention to the RAM chips.
It could possibly even be a faulty processor, have you another you could try? Try taking it out and re-seating it.
Apr 12, 2011 | ASUS M4N75TD AM3 NVIDIA nForce 750a SLI...
Nvidia 8600GT not working well witg games
If you have Win Xp, Nvidia updated the driver on Jan 22 last month.Try the new driver. Link below:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/askIris.jsp
Feb 14, 2009 | XFX NVIDIA GeForce 8600 Graphics Card
Blank screen using Vista x64 with Nvidia Forceware Drivers 8600GT
Most like the sound card you have is not compatible with Windows Vista. You need to check the manufacturers website to see if there is any patch for Windows Vista
Oct 02, 2008 | Computers & Internet
8800gt black screen
Hi Juan016, you have done everything right. I'd say the 8800GT is bad & return it for a refund. Run the 8600GT & the NVIDIA 6100 at the same time. If you check the middle of page 9 in your manual. NOTE: It states; if a PCI-E is inserted the bios will automatically run the PCI-E card. (No need to make a bios setting change).
It also says if you change the setting in the bios to, OnChip and PCIe VGA, the motherboard should run both. Depending what amount of memory you set the NVIDIA to run with. Once in windows check the amount of total memory the NVIDIA or 8600GT reports.
Example: You set the NVIDIA to use 64MB & the 8600GT has 512MB than the NVIDIA or the 8600GT should show 576MB. Its not that uncommon one buys a bad video card.
Reading the manual & windows not seeing the 8800GT tells me the bios did not see the 8800GT card. The card is bad. You’re doing just fine.
Mike
Sep 14, 2008 | PNY XLR8 NVIDIA GeForce 8800 GT 512MB...
Playing CRISIS..
heres more info on the game
http://en.wikipedia.org/wiki/Crysis
Operating System - Windows XP or Windows Vista
CPU Minimum - 2.8 GHz or faster for XP, 3.2 GHz or faster for Vista
cpu Recommended - Intel Core 2 Duo @ 2.2 GHz, or AMD Athlon 64 X2 4400+
Memory - 1 GB RAM for XP, 1.5 GB RAM for Vista
Recommended - 2 GB RAM
Hard Drive Space - 12 GB of free space
Minimum Graphics Hardware - 256 MB video memory, NVIDIA GeForce 6800 GT/ATI Radeon 9800 Pro (Radeon X800 Pro for Vista) or greater
Recommended - NVIDIA GeForce 8800 GTS 640MB or ATI 2900XT 512MB
Sound Hardware DirectX 9.0c compliant card
Jun 16, 2008 | AMD Athlon 64 4000+, 2.4 GHz...
Video card
This may sound weird, but remove ram to make it 2 gigs and try it again, some mobo's have issues with 4 gigs. 3 gigs usually works too.
Apr 03, 2008 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
MSI : K8N Neo4 Platinum Athlon64/S939/nForce4 Ultra/DDR400/PCI-Express/ATX Motherboard (MOT81) Logo
79 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
