Question about Desa International Blower Glow Warm Wall Heater
Pilot lights ok but when i release the control button it goes out
    Scholar:
  • 146 Answers
This sounds like a problem with your thermocouple.
Just remove the end of the thermocouple from where is goes into the gas valve and leave the end that goes into the flame in place.
Clean the end of the thermocouple connect by scraping off just a little metal from the end just about there the nut tightens the thermocouple into the gas valve. After you have exposed some new metal do the same inside the valve where the thermocouple seats into the gas valve.
Use a small pic or similar item to scrape inside the gas valve to expose some new metal there also.
Now reassemble the thermocouple into the gas valve and see if the heater works.
Here is a link with some more instructions.
http://www.msservice.net/ts/reseat_thermo-clean_pilot-ODS.htm
Thanks
Posted on Oct 16, 2010
4 Suggested Answers
Therinnaiguy
  • 1420 Answers
SOURCE: Unable To Keep Pilot Light Lit!
Clean or change out the pilot assembly. Check for a lose connection of the flame rod at both the pilot assembly as well as the gas valve.
Posted on Aug 30, 2007
SOURCE: Laars Lite 2 Pilot will not light
If you have not found the problem yeat, it IS the thermocoupling( or pilot generator(same thing))
You may test by placing a multimeter on the red and white leads coming to the gas valve. you do not need to disconnect the leads first but you can
Posted on Jul 25, 2008
johnsonr1
  • 91 Answers
SOURCE: The pilot light will not stay lit to light the heater.
The power pile (pilot generator) is defective. It produces a milivolt signal to ensure to keep the gas valve open. If it goes bad, the valve thinks the pilot is out, even when you are holding the button down, so when you release the button, it shuts the gas off to prevent excess gas buildup and a possible explosion.
Posted on Sep 12, 2009
Pilot goes off as soon as I release the button
You need to hold the button down for about 3 mins. If it goes out after that long the thermocouple is probably bad. Look at how long the wire is from the pilot light to the gas valve. They come in different lengths.
Jan 18, 2016 | World Marketing Kozy-World 3 Plaque...
How do I light my janitrol ucs100-55 heater?
you need to turn on the gas supply. then turn the button on the valve to the "light" position. now press down that button repeatidly until the pilot light lights, when the pilot lights you will need to hold that button down for about 15 seconds. then when you release the button the pilot should stay lit. when it does... turn the button to the "RUN" position. thats it... turn up the thermostat and the heater should kick in.
Jan 06, 2015 | Heating & Cooling
Pilot light ok when release finger pilot goes out
Your thermo couple is bad. Thats the copper tube that goes from the gas valve to the pilot. It senses thats the pilot is lit. Thats not working thats why it goes out. You can get a new one at lowes or home depot for about ten bucks its pretty easy to change just dont kink it when you put it in. It will just plug in at the pilot and screw in at at gas valve.
Jan 11, 2013 | Bosch Worcester Spark Electrode...
We have an atwood lp gas water heater 6 gallon g6a7 white rogers control. The pilot lights but when we turn it to on it goes out, even after holding it up to a minute. It was running fine, we thought we...
If pilot stay lit, then thermocouple is working.
If pilot will light, then you have gas. If pilot goes out when pilot button is released, then thermocouple is next suspect.
Thermocouple tip must sit in pilot flame.
The pilot light heat applied to two different metals inside thermocouple causes small current.
The current travels back to gas control valve through copper line.
If the gas valve receive this current, then a magnetic switch stays open and allows gas into the gas control valve.
The magnetic switch is on the end of the red button you push down when lighting pilot. Essentially the red button is an override to the magnetic switch.
If the gas control valve does not receive the current, then the magnetic switch does not stay open when you release the red button.
When replacing thermocouple, note that it is not screwed very tight into the gas control valve. Finger tight + 1/4 turn. If it is overtightened, then the small thermocouple current shorts out against the gas control body.
Sep 01, 2012 | Water Heaters
I have a Vulcan Gas wall furnace that is not working. We cannot work out how to light the pilot light. According to the documents we have it is a 26.4MJ model or the 40MJ model
The Quazar manual says....
-Thermostat control knob to 0
-Then press and hold down * (Star) button
-The press the "ignition" button one or more times until the pilot lights
CONTINUE to hold the * button for at least 15 seconds and release slowly making sure the pilot stays lighted.
-If the pilot goes out.. repeats steps above and hold the * button for much longer than 15 seconds and THEN release the * button slowly.
Kelly
May 06, 2011 | Heating & Cooling
Pilot light goes out
if the unit goes thru the cycle of heating the water and when temp is met pilot goes out you need to replace the entire temp control if pilot goes out as soon as you release the pilot button you need to replace the thermo couple little copper wire the goes from regulator to inside burner...check for 800 number on front of w/h for warranty info..as regulator can be expensive
Dec 09, 2010 | Reliance Natural Gas Water Heater Control
Pilot will not stay lit after button release
most likely you have a thermopile that has low output. it takes about 100mv to maintain pilot light
Jun 24, 2009 | Hayward 250kbtu Ng Pool Heater - Inground
Pilot goes out once button is released
If the new thermocouple was installed properly, with its tip in or across the pilot flame so as to be heated by the flame, then the control valve may be faulty.
Note: The pilot primer button may need to be held down for a longer period of time.
Aduz
Mar 24, 2009 | Water Heaters
I need to know how to light the pilot on my somewhat old water heater. The model is called the challenger 5 the model number 153.331471
On these older gas water heaters there is a gas control with temperature selection and below that is a removable cover. Once you remove the cover you can gain access to the pilot. You must rotate the knob on the top of the control to the pilot position. When in the pilot position, hold the red button down and light the pilot. Continue to hold the button down after the pilot is lit for about one minute. If when you release the red button the pilot goes out, try one more time. If it goes out again after releasing the button your thermocouple is bad and must be replaced. The thermocouple generates a millivolt electrical current that hold the gas valve in the operating condition when the pilot is lit. When the pilot goes out there is no heat to generate this small electrical field.
Jun 08, 2008 | Kenmore Heating & Cooling
Desa International Blower Glow Warm Wall Heater Logo
848 people viewed this question
Top Desa International Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
mcijoe
Level 1 Expert
Are you a Desa International Heating and Cooling Expert? Answer questions, earn points and help others
