Question about Gateway GTW-P42M102 Television
Main Power Board
My 6 yr old set has been diagnosed with a bad Main Power board.
Gateway wants $250 for the part. Can a lay person replace the board?
Can I just take off the back and plug in the new board?
Thanks!!
Roundtrip
  • 42 Answers
The power supply board can be changed without any knowledge of repair but there are sometimes adjustments necessary if the picture is not normal. Many times it is fine. There a 4-5 voltage adjustments that would take some knowledge and a meter to accomplish. You need to hope it was diagnosed properly first. If it is completely dead the p.s is a good possibility. If it clicks on then back off almost immediately it is not likely the power supply.
Posted on Jun 23, 2008
Hello, I have a 2 yr old LG 32" tv model 32LN5300. The screen is black. No backlights. With a flashlight I can see images on the screen. Would this be led drive board/ motherboard
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Apr 04, 2017 | LG Televison & Video
I have a 40 in Westinghouse tv less than yr old, after about 5-10 min the picture goes out but still have sound. What can I do
back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Nov 15, 2016 | Westinghouse Televison & Video
I have a 40 inch Sony Bravia that is a yr old and we have sound but no picture we have tried everything. Help
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
May 30, 2016 | Sony Televison & Video
How do you fix a vizeo tv with sound and no picture?
Oct 29, 2015 | Televison & Video
LED Backlights on LG TV?
If audio is OK, the backlight inverter is the part should suspected. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Oct 25, 2015 | LG Televison & Video
Main Menu and lock cymbol keep coming on screen. How do I get rid of them?
Wendy ohlsen, I know you really like your E173FP, but it is quite "old" in CCFL back-lit lcd display years. It could be 4 to 6 years old. Retrevo .com lists unit as "time to retire" ,, Please reply back with the "date of manufacture" from rear of unit. Tell me if unit has a "lay on floor" power adapter or just a plain old "line cord" that plugs into the wall. When "strange stuff" starts to appear on screen, problem is most likely inside the unit on the power supply board. Let me know if your husband or boyfriend can assist you with an internal visual investigation of unit's power supply board. See YOUTUBE video clips of repairs being done on typical Dell units first. Pay particular attention to BAD CAPACITORS being replaced with new ones!!! 12fixlouie
Sep 14, 2010 | Dell E173FP 17" LCD Monitor
RCA L26WD12 26IN, LCD TV will not turn on, the red off light stays on with no response from the on off button or the remote, to get the tv to turn on I have to unplug and plug in the power cord five or six...
It can be due to unstable DC power from the power supply due to bad caps, or bad main board (I had to replace my main board, and later on the inverter boards). You may want to think about putting money into this TV.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
http://s807.photobucket.com/albums/yy352/budm/RCA%20L26WD12/
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx
Aug 11, 2010 | RCA L26WD12 26 in. LCD TV
When turned on, monitor power light comes on for a moment and then goes out. Monitor eventually comes on after several minutes. The same happens if the monitor is left on but goes into sleep mode.
This is a common problem on these monitors. There are three or four capacitors in the power supply, three on the inverter board and anywhere from 2 to 6 on the main board that go bad.
The number on the main board depends on how long the monitor has been having problems before it was serviced. The longer the wait, the more capacitors will have gone bad.
The power and inverter boards are easy to repair, the main board is not. As mentioned, it is a multi layer board so removing the old capacitors and the old solder can be troublesome. I would suggest you have someone experienced at soldering repair the main board.
Btw, our shop would charge $60 labour plus $2 for each capacitor.
Dec 18, 2009 | ViewSonic VP2030b 20.1" LCD Monitor
Gateway Plasma 42" TV
my 5 yr. old 50 inch plasma hd that i paid almost $7000 for started flashing for afew sec. when first turned on.progresivly got worse,flashed for about 30 min. then ok until turned off.after about a month power light comes on fans start then trips off. gateway phone 888 737 6949 wants $250 for power supply $330 for video?board $600 plus for other boards no guarantees.i fixed mine by spending $1000 for a new vizio 50 inch plasma hd.if anyone wants a free dead gateway email me,
archie
Mar 02, 2008 | Gateway GTW-P42M303 42 in. Plasma...
Open Questions:
Televison & Video Logo
259 people viewed this question
Top Gateway Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Gateway Televison and Video Expert? Answer questions, earn points and help others
