Question about Toshiba Satellite A40-S161 Notebook
The screen went dark this morning and you can barely read it. Any other settings to change other than the function keys?
  • 2,567 Answers
1. Test using an external monitor. If it works, then either the screen bulb or the inverter board might be defective.
2. Test the inverter. Easiest way to do it if you have a good screen with a good bulb. Connect the good screen to the inverter board & test it. If it lights up, then the inverter board is good. If it did not, then the inverter board is bad & needs to be replaced.
3. If the inverter board is good, then we are left with the possibility that the screen bulb is bad. To fix this, we will need to replace the LCD screen.
Posted on Oct 14, 2010
The screen is too dark to read
See if there is a contrast adjustment somewhere on the laptop first, if not then its a possibility your back light has gone and needs replacing.
Jan 19, 2010 | Acer Aspire 3000 Notebook
My caculator screen is faded, i can barely read the numbers. it s barely a year old and i put in new batteries. how do i fix this?
After the change of batteries, the screen reverted to default contrast. You should try to darken the screen.
Press and hold the [Diamond] key and tap the [+] key. Keep at it until screen is dark enough.
Hope it helps.
Oct 12, 2009 | Texas Instruments TI-89 Calculator
Vaio laptop- screen went dark but is still on.
check power from adapter, if its ok, try looking at your function key and adjust brightness through function key. or else you might have to replace the lcd bulb....
Feb 18, 2009 | Sony VAIO PCV-W20 PC Desktop
Screen went almost completely dark, can barely see at all.
This is a hardware failure of the LCD back-light or a loose connection which requires partial disassembly to verify. Most likely it will require an LCD replacement. If you have an external monitor you can connect it to the video output so that you can see.
Nov 28, 2008 | HP Pavilion dv4000 Notebook
Problem Using stand alone monitor with laptop computer
signal out of range suggests that your laptop is asleep..open the display settings, and disable those, until you get this resolved.
Oct 15, 2008 | Dell Inspiron 8600 Notebook
Laptop screen very dark very,very,difficult t read.Laptop has t0 be lnked to an ouside monitor
You have lost the lcd backlight, probably the backlight power supply, this is very common. What type of laptop is it?
Jul 16, 2008 | Intel Motherboard
My TI-89 calculator screen is so dark I can barely read it. Is there a brightness function or is something wrong with it?
press the diamond shaped green key and the minus sign back and forth and the screen will brighten up!
Jul 09, 2008 | Computers & Internet
Screen to dark to read
Find out if you are still in warranty this is not fixable.
Mar 01, 2008 | RCA OPAL M4001 MP3 Player
Display is so light that I can barely read it, I've replaced the batteries and no change
Have you attempted darkening the display on the calculator through the function keys? Push "2nd" and then push "up" a few times. After resetting the calculator, this setting will always revert to a lower, unreadable setting. I'm sure TI knows about this, but they probably arent too inclined to fix it.
Jun 04, 2007 | Texas Instruments TI-83 Plus Calculator
Toshiba Satellite A40-S161 Notebook Logo
127 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
