Question about Kenmore 95172 / 95174 / 95179 Electric Kitchen Range
Describe your Kenmore C970 - 688022%2C Fault Code Problem When I switch on the broiler, the stove shuts off and fault code F 13 appears
jsrock516
  • 5911 Answers
SOURCE: BEEPING OVEN
The F1 and constant beeping is an error code indicating that your electronic control board (clock/timer) is defective. The fault cannot be reset and the control board must be replaced. This can be an expensive repair if your range is no longer covered by a warranty or service plan. The cost to buy a new control board can be in the neighborhood of about $200. Sorry...but I do hope this helps you.
Posted on May 12, 2007
SOURCE: Error code E1 -F5- Broil element comes on and wont shut off
I just did the self clean option and when it was done I received the error code E1 -F5- and it does have to do with the door latch. After turning off the power to the stove I was able to open the door and wiggled the latch and that solved the problem.......
Posted on Oct 24, 2007
TheMobilian
  • 8220 Answers
SOURCE: kenmore oven has f3 code
What you have is a fried relay on the board. the contacts are stuck, Find the board and yank out the wire marked Br1 and see if the broiler shuts down. Do youur findings while the machine is without power amigo. More than likely you needs an expensive new control board. You could just remove and tape off one of the broiler wires if the bake still works.
Posted on Apr 10, 2009
localwonder
  • 6784 Answers
SOURCE: oven quit working
Hi. this is common in many old gas range ovens. There is a set of coils that are attached to the gas valve assembly. These coils , when activated and operational, open and close the main and secondary valves in this unit. They are controlled by the main ERC(clock/oven control board). I recommend checking these coils and there respective wiring harnesses. if the clips and wires are worn and corroded, simply replace the entire wire harness.
Now, if the wiring harness and wires that are connected to the coils look good and there are no signs of corrosion on the wires and connector clips, this will confirm that the coils have failed and you will need to replace them.
You can also preform an additional test with a multimeter. simply connect your multimeter or voltage meter to both terminal posts located on the coils. once your meter is connected, start the oven cycle. you should register some sort of current during this test at this time. if the current is sufficient and the coils do not initiated the valve action, this will confirm coil failure. if the meter dosen't register a current during oven operation, this will confirm ERC(control) failure. you will have to replace the Oven control board in this case.
The Most common issue in this situation will most defiantly be the coil assembly and not the control.
Please rate and god bless:)
Posted on Apr 21, 2009
blueextc3221
  • 15935 Answers
SOURCE: f-1 error code on kenmore
Here's a simple explanation of what's going on and how to troubleshoot:
The F1 code indicates that:
a. The electronic range control (ERC) is sensing heat in the oven when in a time-of-day (i.e., not cooking) mode.
b. The ERC is receiving information to run multiple heat functions simultaneously.
Although different components (depending upon the model) could generate the code, simple and straightforward testing using your ohm meter is all you gotta do to test for it.
1. Check the oven temperature sensor. The oven sensor has to be within spec or it will cause the F1 code.
As an example of being out-of-spec, the ERC will generate an F1 fault code when the sensor shows 1650 ohms during a time-of-day mode.
This is equivalent to 350°F in the oven.
The resistance isn't high enough to generate an F2 code (runaway temp) or an F3 or F4 code (shorted/open sensor circuit).
The ERC monitors the sensor circuit after a heat cycle and expects the resistance to drop back to 1050-1100 ohms.
The fault code is generated when this doesn't happen. Checking the sensor circuit means also checking the harness,
harness connections and the sensor itself.
2. If the oven sensor circuit checks okay, then turn your inquisitive eyeballs to the touchpad.
If the range has a separate touchpad/keyboard, the keypad may have moisture that is shorting several circuits simultaneously.
If the F1 code is given immediately (instead of during or after a heat cycle),
remove the ribbon connector from the touchpad to the ERC after clearing the F1 code. If the F1 code does not return in five minutes,
then cast a suspicious gaze upon the touchpad/keyboard. Shorts may be caused by using an ammonia-based glass cleaner.
The touchpad surface will absorb ammonia-based cleaners that are sprayed directly on the glass surface. When heat is applied,
the surface material can break down causing shorts.
If you're gonna use ammonia-based cleaners on your control panel, then you should spray it on the rag and then wipe the touchpanel
-don't spray directly onto the surface of the touchpad.
3. On Amana ranges with a rotary temperature dial, be sure that the knob is in the OFF position when performing tests.
4. If these tests all check good, then replace the ERC.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 23, 2010
Whirlpool Gold Series stove. When turning on the oven to pre-heat, the broiler came on and we got a fault saying FAULT - PRESS ENTER TO RETRY.
Appears the burner is faulty, check connection at burner receptical first then check with meter for opens. Here is the Whirlpool link for parts repair manual etc. https://www.google.com/url?sa=t&source=web&rct=j&url=https://www.whirlpool.com/services/replacement-parts.html&ved=0ahUKEwiCvdH97rDTAhVk7IMKHX4gAtMQFghZMAA&usg=AFQjCNEsdfUwvP3qyVcDj7qJikAtiHTfUQ
Apr 18, 2017 | Whirlpool Kitchen Ranges
What does an F-1 code mean on the display? washer will not start.
power problem
  • Whirlpool Fault Codes - AppliancePartsPros.com www.appliancepartspros.com > Appliance Repair Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • Washer Diagnostic& Repair - F1 Error Code power supply ... www.youtube.com/watch?v=BAVS9mI3JLQ
    • BY APPLIANCEVIDEO.COM
    • 4 MIN
    • 65K VIEWS
    2014-02-07 · Troubleshoot your trusty Whirlpool Top Load Washer that has these following symptoms: F1 Error Code At: http://www.appliancevideo.com To ...
  • Whirlpool Cabrio f1 error and how to fix it https://whirlpoolcabriof1error.wordpress.com Control board W10189966 will work with the Whirlpool model numbers listed at the bottom of this page. These models include the Maytag Bravos and Kenmore Oasis.
  • whirlpool F1 code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • 68 POSTS
    • FIRST POST: 2008-07-28
    2009-09-29 · Discuss whirlpool F1 code in Washer Repair. "whirlpool cabrio washing machine displays f1 code. have already pushed cancel and restart to no avail.
  • Cabrio Washer by Whirlpool F1 Error Code - Facebook www.facebook.com/CabrioWasherByWhirlpoolF1ErrorCode Cabrio Washer by Whirlpool F1 Error Code. 793 likes. Got the F1 Error Code? Tell your story! Share ALL your issues with this washer to warn others...
  • Whirlpool Fault Codes - Appliance Help Online appliancehelponline.com/whirlpool.html Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • May 04, 2016 | Whirlpool WTW8200YW Cabrio Top Load Washer
    F7 code on Jenn air stove
    Robert,
    Here is a link that has fault codes for Jenn Air stoves. Hope tis helps!
    Jennair Fault Codes AppliancePartsPros com
    Mar 09, 2015 | Jenn-Air Kitchen Ranges
    How do I fix code 13 engine speed sensor Above 1000 rpm
    Clearing the codes is simple that is done by removing the fuse of the EFI from junction box 2 for 10 seconds. Make sure to remove the jumper wire and switch the key off before clearing the codes.
    Here are some common Lexus vehicles 1990-1995 codes:
    Code 12 and Code 13 Rpm signal circuit fault
    Code 14 Igniter signal circuit fault
    Code 16 ECT control signal fault
    Code 21 and Code 28 Main oxygen sensor fault (for ES300; SC300 & GS300 models)
    Code 22 Coolant temperature circuit fault
    Code 24 Intake temperature sensor circuit fault
    Code 25 and Code 26 Air fuel ratio fault (for ES300 & SC300 models)
    Code 27 Sub-oxygen sensor circuit fault (for ES300 CA & GS300 models)
    Code 31 Low airflow meter voltage (for ES300 and GS300 models)
    Code 32 High airflow meter voltage (for ES300 model)
    Code 35 Barometric pressure sensor circuit fault (for GS300 & SC300 models)
    Code 41 and Code 47 Throttle position sensor circuit fault
    Code 42 Vehicle speed sensor circuit fault
    Code 43 Starter signal
    Code 51 Switch condition signal fault (for ES300; GS300 & SC300 models)
    Code 52 Code 52 and Code 55 Knock sensor circuit fault
    Code 71 EGR system circuit fault (for ES300; GS300 & SC300 models)
    Code 78 Fuel pump control circuit fault (for GS300 & SC300 models)
    Nov 18, 2014 | 1990 Lexus LS 400
    Kenmore electric stove model 95012102 displays EO-F2 the cooktop works.
    that code is a bad touchpad.
    F2 - E0 Shorted keypad (also called touch pad) 1. Check keypad connector for firm connection (keypad connects to control board).
    2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
    Read more: http://www.appliancepartspros.com/repairtips/repairtips_appliance+fault+codes.aspx#Sears / Kenmore Fault Codes#ixzz1cHA0Nn50
    Oct 30, 2011 | Kitchen Ranges
    I get failure code F9-3
    What a scam by service personnel.
    -Simply press "Stop/Clear", then gently push the door handle until "Lock" appears on the screen. Press "Stop/Clear" again and the door unlocks itself!
    J. Kalicak
    Jan 22, 2009 | Jenn-Air JES9800A Electric Kitchen Range
    Oven door locks and un locks code F90
    The F90 fault indicates that the maximum time allowed for oven door unlock was exceeded. The control attempted to unlock the door. The door lock motor or mechanism failed to unlock the door within the maximum amount of time it is allowed to be energized by the control board.
    It is unlikely that you will be able to reset this fault code. You can try to completely disconnect electrical power and leave it off for 5 minutes. After reconnecting power, the fault code will probably reappear since the control will still detect that the oven door is locked. The only way to clear the fault code is to disassemble the range and repair or reset the oven door lock assembly. You will need a service technician to complete this repair.
    Dec 16, 2008 | Kenmore 79013 Stainless Steel Gas Kitchen...
    Broiler won't turn off. Error code F-3
    The broiler won't turn off even when you press the "Off/cancel" button? It sounds like the broiler control relay is stuck shut. The F3 code means the oven temperature sensor has failed, this probably happened because the oven got too hot when the broiler was stuck on. There is fail-safe thermal fuse that will blow if the oven gets too hot, so the oven won't melt down but you should leave the unit off so you don't blow the fuse.
    To fix the relay, you will have to replace the oven control module. I think this is about $200 and not too hard to replace if you are somewhat handy. The temperature sensor is also serviceable, you can find parts at Appliance Parts Pros on the web. Hopefully you haven't thrown the range out yet, let me know if you need further assistance.
    Nov 27, 2008 | Whirlpool RBS305PD Electric Single Oven
    Kenmore drop in range code F7
    Oven control beeps and Electronic control as detected fault condition.
    Press CLEAR to clear the display and stop displaysF1,F3, F7 ,or F9 beeping.
    Program oven again.If fault recurs,record fault number.
    Press CLEAR and contact your Sears authorized qualified service agency.
    Oct 17, 2008 | Kenmore Kitchen Ranges
    if it is a whirlpool, kitchen aid or kenmore by whirlpool you need to check the self clean latch asembly found on the rear of the unit. check the micro switches with an ohm meter. always remember to unplug the oven before you test any thing or replace parts. not sure why the broil wouldnt shut off. but the f5 error is definatly related to the door latch.
    Sep 06, 2007 | Kenmore 95822 / 95824 / 95829 Electric...
    Kenmore 95172 / 95174 / 95179 Electric Kitchen Range Logo
    95 people viewed this question
    Top Kenmore Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Sal De
    Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
