Question about Cretors Goldrush Popcorn Maker
The tempature for my popcorn maker is to high how do i adjust it?
  • 55 Answers
The thermostat isn't adjustable. If it is a newer model, the thermostat may be bad, and it may be operating on the high limit instead. The thermostat is in the kettle. Try calling Cretors' tech support at: 773-433-7450
Posted on Oct 27, 2010
Will thermostat stop kettle from overheating and blowing thermal fuse
The thermostat built into the kettle stops the kettle from heating at a prescribed temperature. usually around 425 F. This is hot enough to smoke and cause instant burns, but is the required temp for popping popcorn.
I do not know of a "thermal fuse" built into popcorn machines. Mechanical thermo stats are not flawless. they can and do malfunction, either too cold or too hot. the model popper you have is not adjustable, or repairable.
If you are tripping a electrical circuit breaker that is a different problem not related to kettle heat. It is a symptom of an overloading problem of your outlet, or a ground fault in the popcorn popper.
Jan 09, 2014 | Nostalgia Electrics KPM-508 Popcorn Maker
Klixon failure
Not replaceable, but you know that.
My popcorn machine won't heat up
No heat at all most commonly used is just a burned wife connection in the kettle . I find that a lot of the time. To repair it you should use high temp nickel ring terminals. Standard ones won't last l long like these do. It might be time for a while new KETTLE wire set. Find a dealer in your area . They should help you determine what to do.
Dec 28, 2013 | Cretors Goldrush Popcorn Maker
Popcorn machine doesnt heat high
Popcorn needs 400F to pop, if you machine is not hot enough it will not pop popcorn.
You did not include very much information to help fix it, but if it is a home use popper, you cannot repair anything on them.
A true commercial popper you can replace thermostats, and fix the problem.
Aug 12, 2013 | Kitchen Appliances - Others
Model 39A gets too hot too fast
That model has a thermostat (also called a high limit) that is set at 450F. it should produce a popping cycle of 3 mins, and yes will burn popcorn if you don't dump it fairly quickly.
The speed it heats cannot be too fast, there is only so many watts in the heat element. it may go to hot, but never to fast.
The best way to test temp is time the 2nd popping cycle with a stop watch. the second batch should be 3 mins +/- 30 seconds. if it is 4 mins it is too cold. a 2 min popping cycle is to hot.
A popper that is too cold is also popping poor quality popcorn, higher amount of unpopped kernels, and small chewy popcorn.
Measure carfully when doing time test popping. That model is 2oz oil, 6oz popcorn, and 1 tsp salt. Start timing when you put ingredients in, and stop when you dump it. The kettle must be hot, that is why you time the 2nd batch.
May 20, 2013 | Star 39 JetStar Popcorn Maker
Cretors machine thermostat, 32 oz.
Try calling Cretors' tech support at: 773-433-7450 or Try finding a local dealer at: http://www.cretors.com/dealers.asp Have your serial number ready.
Feb 15, 2010 | Cretors Goldrush Popcorn Maker
Powercord replacement
This is a standard high-wattage appliance cord -- you can find one at any appliance parts store.
May 29, 2009 | West Bend 82306 Stir Crazy® Popcorn...
No instruction manual
Try one ounce of oil, 1/2 teaspoon popcorn salt and 1/2 cup of popcorn and see how much it fills your machine and adjust quantities from there. This will usually fill a wok size bowl.
Mar 21, 2009 | Kitchen Appliances - Others
We need to replace the adjustable feet and kernel drawer on our Nostalgia Electrics CCP-509 Popcorn Maker but cannot find an outlet to assist >
We are under new management.
Please call us at 1-920-347-9122 and we can help or you can visit our website at www.nostalgiaelectrics.com
We are more than happy to help you with the parts that you need.
Mar 12, 2009 | Nostalgia Electrics CCP-509 Popcorn Maker
Popcorn maker jams up - burns kernels
Please call Nostalgia electrics at 1-920-347-9122 so we can help you get the piece you need.
Nov 25, 2008 | Bond Helman Old-Fashioned Movie Time...
Cretors Goldrush Popcorn Maker Logo
314 people viewed this question
Top Cretors Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Cretors Kitchen Appliances - Other Expert? Answer questions, earn points and help others
