Question about Honeywell Heating & Cooling
No heat in the zone when thermostat asks for it.. Zone gets heat only when other zone asks for heat. V8043F motorized heating zone valve operates once thermostat is asking for heat, but its end switch stays open. Therefore up until other zone valve turns the circulatur and furnace/boiler controller on they remain off. Thus no heat. Can I fix the end switch by checking the actuator function? Can I change just the switch? Should I change the entire valve head? Should I switch the valve head with other zone valve to see if problem follows? If the last two options are the only ways to get ahead, then how to change the valve head ?
  • 2 more comments
  • STARB Oct 15, 2010
    How do I get to it?
    There is no information on how to change the faulty end switch, is it ?
    18 years
    Okay, is it sealed from the ball valve? I mean, can I do the head replacement w/o draining the water, refilling after, getting air out, etc.
    Genius:
  • 1,035 Answers
Hi. You might need to change the valves of your unit. here are few tips on how the valve looks like. i included also the manual for the your unit.
The first thing is the V8043 number. This number is the same for the straight through two way valve body configurations. The next letter for most heating system zone valves is the one that is confusing sometimes. Usually it will be an E or a F. There are other Letters but they are not nearly as common for home heating.
This is the E valve
This is the F valve
The thing to remember here is that the E letter tells you that the zone valve has the 4 - 18" wires coming out of the motor. And the F letter tells you that the motor has the 5 terminal board on it. They can be interchanges but if you have one type already installed and you go to replace it you will have to do some figuring to know how to hookup the motor correctly. If you replace your valve with the same letter valve you will just be able to hook it up again as it was.
Then, as far as the last four numbers go, they just tell you what size pipe the valve is for.
If you need to replace the zone valve motor you can check the pricing for a replacement motor or complete head, but I have found that many times the best pricing will be to buy the whole valve and then just take the head off of the new valve and switch it with the old one.
You can look for the manual by clicking here. These link came from my fellow expert.
Have a good one!!
Posted on Oct 16, 2010
  • 712 Answers
How old is the model?
Posted on Oct 15, 2010
  • Sebin Punnacheril
    Sebin Punnacheril Oct 15, 2010
    I think you should replace the valve head. It will be available in the nearby Honeywell outlet.
  • Sebin Punnacheril
    Sebin Punnacheril Oct 16, 2010
    Generally the valve head is sealed to the valve. I'm not sure about your model. In most cases you should remove the entire valve and that makes you do all those things, and the most difficult one among those is pumping the air out.
  • 11,896 Answers
Replace just the end switch first.
Posted on Oct 14, 2010
How do I connect a 24v damper motor with 6 colored wires red white yellow green blue black to NO COM NC terminals.
Choose two colors of the thermostat wire, and connect them to the NO and COM and connect them to the zone control board leads for the zone intended. Almost all zone valves spring return open when deenergized. So ensure the zone valve is open with the system is off. At the base of zone valve there is a set screw that needs to engage the damper valve shaft in the open position with the motor in the spring release position. Most zone valve are 90 degree moment from full open to full shut. If you have a Carrier zone valve, they go full open to full shut in 45 degrees of motion. Your open stop need to be set so the valve stops in the full stop position.
To help understand the operation of a zone system, say you have 2 zone system and zone 1 thermostat initiates a heat or cool demand. Zone 2 valves energizes and shuts and zone 1 stays open and allow air to heat/ cool zone 1. If zone 2 thermostat simultaniously initiates the same heat/cool demand, the zone 2 valve opens and both zone heat/cool. When either thermostat is satisfied the opposite zone valve closes and when both thermostat are satisfied both zone valves open.
Hope this helps you understand zone operation. The same works for higher multizone systems.
Jul 27, 2014 | Honeywell Motorized Small Rectangular Hvac...
5 zone baseboard heating all with indiv thermostats. One zone will not allow manual override even though I hear it click on. Swapped the therm and it works on another zone. Is there a problem with the...
is the system zone valves or seperate pumps for each zone?
If zone valves locate and check the valve in question for 24 volts
if you have 24 volts at the valve but no heat replace valve.
was there ever heat in the zone in question?
Jan 31, 2014 | Trane Munchkin High Efficiency Gas Boiler...
How to add a heat zone
You can buy a zone valve at a plumbers supply. Get a 24 volt one with a 24 volt transformer and a thermostat. Place it in the circuit that feeds the zone that requires heating and it's own control
Nov 16, 2013 | Plumbing
My heat rises higher than the designated temperature. For example, if I set the thermostat to 60 the temperature will go up to 73. Invensys 9405
there could be a few things causing this, the first would be a bad thermostat. The second would be an improper setting of a heat anticipator on the thermostat, the third could be a stuck zone valve that is allowing heat to go in the zone as another zone is calling. Or it could be a stuck flow check also allowing hot water to flow through the zone much like a stuck zone valve.
If your thermostat is an older one with Mercury in it, replace it with a new one and dispose of properly. If the thermostat is newer, remove the cover or consult the owners manual to see if there is an adjustment that shuts off the thermostat a bit sooner to compensate for the heat that will be released from the system so you do not overshoot your setting on the thermostat. There may be either DIP switches to adjust the setting or a small pointer that slides over a small coil of wire and acts like a dimmer switch. Try adjusting and testing the system to see if it helps. Remember the original settings in case it does not help.
If you have zone valves (small boxes that allow flow of water to the zone) it may be stuck open allowing water to flow into that zone as another zone calls. You can test this by feeling the pipes at a baseboard when you know that the zone over heating is not calling for heat (turn thermostat to lowest setting). Check other zones to see if there is a call for heat in one of them. Make sure you adjust one of the other zones to force a call for heat in it, After a few minutes, feel the pipes in the zone overheating and see if the pipes are getting hot (be careful). This is the same test to check for a stuck flow check valve.
Mar 05, 2011 | Heating & Cooling
I have a two zone water baseboard system... I installed a new zone valve to the upper zone which was not calling for heat.. the only heat it got was when the lower zone was circulating... Now the upper...
Good clues to work with--
Let's review how you wired up the Zone Valves, in relation to the Boiler Control panel...
You say the upper zone does NOT SHUT DOWN--
Does that mean it is OPEN ALL THE TIME?-- (even when the circulating pump is OFF? )
That sounds like the thermostat is not even in the circuit, then.
Have you been able to cycle each of the valves thru their cycles-- Open- and then closed?
-- It almost sounds like you have an interconnection between the two valves-- is this possible?
Each Thermostat has to control its valve only...
and most systems do this thru a control panel at the boiler--
So-- How is your control panel connected to the 2 thermostats, and how are the 2 zone valves connected to the Control board?
Are you following a wiring schematic for hooking the valves and thermostats to the control board?
There should be a schematic with the new valve you must installed, right?
did you wire it like the instructions showed?
Make a few more tests, and get back with us--
Mack B
Jan 18, 2011 | Heating & Cooling
I have 2 zone heating - my one zone, the heat keeps running, doesn't stop at indicated temp, the other zone works fine
Hi the zone valve could well have a blockage in the valve seating you turn off either side the valve and remove the body to check in side , and see what is in there.
Mar 18, 2010 | Honeywell Programmable Thermostat Heater
I have a gas boiler with 5 zone valves. The heat
The zone valve when there is a call for heat opens and the lever should give you no resistance. I am curious to know if other zones are heating ok. You could have a bad circulator or a frozen zone.
Jan 16, 2010 | Honeywell Electronic Programmable...
The Zone 1 (basement) and Zone 3 (second floor; no
On the zone damper motor, there should be a little lever allowing you to open the damper for emergency heat. Probably a bad zone motor or connection.
Dec 26, 2009 | Honeywell Electronic Programmable...
Valve replaced , but 1 zone out of 3 no heat when
Hello. Each zone in you home has one thermostat controlling one zone valve. Generally, when a thermostat is calling for heat the zone valve opens and the circulating pump comes on to move the water around that loop. If your other two zones are both working as they should and you now have a new zone valve on the third loop I would suspect that the thermostat is faulty. Regards, Joe
Dec 12, 2009 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
113 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
