Question about Emerson MW8626W Microwave Oven
Is it possible to get a replacement door for an Emerson MW8626W microwave oven? If so, how much would it cost and where can I purchase one?
4 Suggested Answers
Noggin
  • 944 Answers
SOURCE: Operating a microwave oven without a load
In principle no it is not hazardous. In practice however, unless the machine is clean to the point of sterile, small items in the microwave can absorb more energy than they would if a large item was in the machine also. This can produce some damage to the machine. manufacturers generally recommend not running microwaves empty. Why would you want to? If in doubt, just a cup of water would be more than adequate. it is not a good idea to modify a microwave oven in any way. Hope this helps :)
Posted on Aug 17, 2007
SOURCE: I need to replace the glass turntable tray on my
I looked up the right reference nº on the internet site which sells glass turntable trays. Thanks for your response!
Posted on Jun 13, 2009
heatman101
  • 43501 Answers
SOURCE: Where can I obtain a replacement glass plate for
That is not that hard to fix and you can easily buy the parts yourselfonline...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Posted on Sep 25, 2010
Need Emerson MW8626W microwave owners manual. Unable to download from this site. Please help
Try this site: http://elektrotanya.com/emerson_mw8626w-b.pdf/download.html
Nov 26, 2014 | Emerson Microwave Ovens
On model mw8626w can i use it in my semi with a 1000 watt inverter?
Take a look at the oven's electric rating information. It should be on the label with the model and serial number, and it will tell you how many amps the oven needs. Power in watts is volts times amps, so a 1000-watt inverter is good for about 8 amps at 120 volts output. Some inverters also use a peak rating, meaning power than can be delivered for a short time. The continuous power may be less than that; you'll need to look at the inverter. As long as the power needed by the oven is within the inverter's ratings then you'll be able to use it. Otherwise you'll need to shop for one with more output power.
Jul 15, 2011 | Emerson MW8626W Microwave Oven
Cooked food smells funny,could it be a leak?
Unless you can associate the odor with burning electronics, it probably isn't being caused by the microwave.
Mar 17, 2011 | Emerson MW8626W Microwave Oven
Worked yesterday, but this morning is totally dead - power at the outlet is fine. Is there a master fuse somewhere? Aprox 4 years old. Thanks,Pat.
Dead appliance, power on wall outlet.
YOUR SAFETY IS PARAMOUNT!
Attempt this only if you are competent.
If your appliance has absolutely no functions at all, remove it from the mains supply, remove the case and see where the mains lead goes in to the appliance and follow the cable until you find the main fuse.
ONLY USE THE SAME TYPE AND RATING OF FUSE TO REPLACE IT.
The usual cause of this fuse failure is the door switches are contaminated or sticking. Check the door switches before putting power back on to the appliance.
Hope this helps.
Jan 18, 2011 | Emerson MW8626W Microwave Oven
My microwave lights blinked off right after i closed the door after checking meal and re-entering time. i unplugged it and tried a different socket nothing happens no sound lights for time or inside the...
I suspect the interlock monitor switch in your microwave oven is the culprit. This is one of several switches operated by the door latches. It's designed to blow the fuse if you try to run the microwave with the door open. The switch is probably stuck, or is out of adjustment (which can happen if the oven door gets closed hard), and when you restarted the oven it blew the fuse. It is possible to adjust or replace the switch as necessary, but it might not be worth it. You should have a professional do the repair as there's a chance of microwave leakage if repairs involving the door aren't done properly. Between labor and parts, the repair cost might come close to (or even exceed) the replacement cost for a small oven.
Hope this helps, and thanks for using Fixya!
Nov 09, 2010 | Emerson MW8778 Microwave Oven
Where can I obtain a replacement glass plate for thr Emerson MW8626W microwave oven?
heatman101
Sep 25, 2010 | Emerson MW8626W Microwave Oven
When u open the door should the light come on???
Yes it should. Is the rest of the machine working? Find and replace the lamp with a 25 watt appliance lamp typically available at your grocery store, FixYa.com advertiser or appliance parts place in your community.
You may have to remove the cover to get to the lamp though some ovens have a access panel inside.
When you remove the cover, be sure to unplug the machine first and never touch the silver can benind the control.
Thank you for posting your question on FixYa.com
Please vote
Thank you
a
Nov 11, 2009 | Emerson MW8626W Microwave Oven
I need a new glass shelf for Model # MW8107WA
The original part number was 441X335A10, which is no longer available, but you can get a direct substitute here.
Jul 09, 2009 | Emerson MW8626W Microwave Oven
I need to replace the glass turntable tray on my Emerson MW8626W microave oven
Jun 13, 2009 | Emerson MW8626W Microwave Oven
Aug 17, 2007 | Emerson MW8626W Microwave Oven
Emerson MW8626W Microwave Oven Logo
19 people viewed this question
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
