Question about Samsung Washing Machines
Washing machine Samsung Sensor Quick SWFP12 won't start when pushing the start button. There is no visible or audible reaction. The door can be opened normally. Door contact is ok. The tiny start push microswitch on the pcb is ok and is effectively pushed-in when pushing the start button in the centre of the program selection knob. Pump and heating element are ok. Electromagnetic water valves are ok. (Multimeter measurements). Program selection is ok. Time indication is ok. There is no error code and no alarm led is on. Some diagnostic (?) program - left two pushbuttons pushing and then on-off-switch pushing on - leads to spinning and pumping. Thanks in advance for your suggestions. Karel
  • 100 Answers
SOURCE: He3 Won't start - lock door or start water flow, although dispay works with no error
The door switch is damaged and needs to be replaced.
Posted on Oct 30, 2007
SOURCE: no display when power on pushed
Had the same problem as described above. Could hear it trying to pump out the water but had no lights except for the Door Locked light. Cleaned the pump filter by removing the bottom front cover. Unscrew the filter and clean out the lint and junk. Have a bucket ready to catch the water.
Posted on Dec 03, 2007
SOURCE: Whirlpool Duet Sport Washer Does Not Work, Door Lock is stuck
have you checked the belt to see if it came off or maybe broke off,if its not the belt then maybe the motor whent bad or needs reset,that just some of the possibilitys you might want to check,some motors have a reset butten on thim
Posted on Mar 01, 2009
dh1200s
  • 335 Answers
SOURCE: Maytag Neptune TL electronics problem
I’m not sure what machine model you have your in the FAV6800AW forum. I got Maytag CSV to send me a Control Board for my FAV6800AW. Had to do some arm twisting it is under warranty for 5 years. If you think your Control Board or console is under warranty give it a try. They wanted a Cert Svr Tech to diag the problem. I told them my neighbor was a Svr Tech (me) he had diag the problem and would install the part. They sent me the Control Board, it might be worth a try. I have a number spare parts not under warranty and ebay is my 1st choice, Second Choice . I use this for parts look up Sears Parts Direct.
What is your model type? It sounds like you have Service Manual for your machine and you are troubleshooting in the right direction. Do you have surge protection on the 120VAC outlet powering your machine. Good Luck Rich.
Posted on Jun 21, 2009
  • 574 Answers
SOURCE: Bosch Classixx 1200 red wash light flashes but doesn't start
Could still be the water inlet valve. What you need to do is pull the washer out where you can get to the valve and the plug. Unplug the inlet valve and start the washer and when you start it as normal check the volts of the plug and see if its 110 if it is you know that the valve is getting power to open but not,replace the valve. If you dont get any voltage then it could be the relay or control board
Posted on Sep 02, 2009
Electrolux w455h washing machine is comming error 45 moter not floow..what is the reason comming like this????thanks...
Family error code E40 is visible to customers and (could be E41,E42,E43,E44 and E45 only visible in service mode) means problem with open door or door interlock.
I suggest rapid reading alarm code when appliance is in normal operating mode (e.g. during the execution of the washing
programme):
Press and hold down START/PAUSE and any of the option buttons for at least two seconds: the LEDs initially switch off, and then display the flashing sequence corresponding to the alarm.
The alarm sequence continues as long as the two buttons are held down.
E41 - Door open
E42 - Problems of door closure
E43 - Interlock power supply triac faulty
E44 - Door interlock sensor faulty
E45 - Door interlock sensing circuit triac faulty
Possible causes:
Door interlock faulty, wiring faulty or PCB faulty.
Dado
Apr 05, 2016 | Electrolux Washing Machines
EWF 1704 erro 41
programme):
Press and hold down START/PAUSE and the nearest option button simultaneously for at least two seconds: the LEDs initially switch off, and then display the flashing sequence corresponding to the alarm.
E41 - Door open
Possible causes:
Dado
Sep 14, 2015 | Electrolux Washing Machines
Error code E40 on a Electrolux Front Loader Washing Machine EWF1090 What does it mean and how can I fix it?
programme):
E41 - Door open
Possible causes:
Dado
Feb 24, 2015 | Electrolux Washing Machines
Why won't washing machine start?
It is most probably the door sensor that is faulty. If the sensor does not sense the door closing the machine will stay in "open door" mode and will not start with it's program.
If the machine is still under warranty, take it in for repair or have someone check it out for you. It should be a quick fix, if parts are available.
May 24, 2014 | Washing Machines
Washing machine won't start
Check your door when it closes, it should hit a push-in button above that door latch, at times I have seen the door hinge bent down just some, causing the door not to strike that button dead on.
If thats fine, then its likely to be the door latch assembly or the CCU board bad.
Oct 14, 2012 | Kenmore Washing Machines
Kenmore HE2 front load washer. All power to the maching is good. Thhe start button just beeps in quick sucsession. Won't start. It seems to think the door isnt' closed but it is, and tightly. ...
It is indicating that there is a problem either with the door lock or the door locked sensor requiring a service call, sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Sep 19, 2011 | Kenmore HE2 Plus Front Load Washer
Door light turns on when you start the machine but turns off a couple of seconds after that and the washer won't do anything. It's a frigidaire aft7000eg0. Any ideas.
check the door interlock sensor. Somewhere there is a tab or button that lets the washer know when the door is closed. If this switch isn't being triggered it could be that the machine thinks the door is open and won't function.
Jun 01, 2011 | Washing Machines
Washer won't start cycle after door is closed
Try taking the top of the machine off and checking all of the electrical connections, including the one to the door lock. I have to do this about once a month with my machine and it seems to work.
Jan 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Maytag Neptune - door locked, clothes inside, lights are on, no reaction to unplugging and replugging. Help! My work clothes are in there! Thanks a lot.
The manual says that you should push the on/off button to turn off the machin. Wait for 2 minutes for the door to unlock. Then open the washer door.
Audioguy4
Sep 29, 2008 | Maytag Neptune MAH5500B Front Load Washer
Samsung washing machine reset code
i have samsung
6 kg WA80HAG silver nano
dear'
plz help me to reset washing
machine
thanks
Mar 18, 2008 | Samsung WF337AA Front Load Washer
Washing Machines Logo
170 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
