Question about Siemens Dryers
E46-38 tumble drier - has started to leak water The machine did not need to use the unbuilt water tank and it worked until it was recently moved - i have connected a pipe at the back so that the water tank fills when drying but I want to put it back the way it worked previously
gittos73
  • 244 Answers
SOURCE: CONDENSER DRYER IS LEAKING WATER
make sure it is pushed all the way in but it could be something simple like when it was moved water has splashed out into the inside of your dryer which will make it look like it is leaking had same problems like that with other customers dryers leave it to run and more than likely that it will dry itself out
Posted on Aug 11, 2007
mirran
  • 515 Answers
SOURCE: Water leaking into machine
Take out the brewing unit and check the hole in the chassis behind brew unit. It can also be the element that is leaking and have to be replaced.
Posted on Jul 11, 2008
SOURCE: Candy CIC60 01 Tumble drier
Hi you need a new heating unit which is behind the back casing. Price approx £42 plus labour
Posted on Oct 12, 2008
mirran
  • 515 Answers
SOURCE: "Fill water tank" prompt
Make sure the magnet in the water tank flow up when you fill it with water.
Best regards
/Mirran
Posted on Oct 26, 2008
SOURCE: drum doesn't move or spin
kenmore tumble action washer model#417.44152400,
Washer is approximately 3 years old. Will not drain or spin. When it tries to spin, clicking noise heard inside of unit. Would a clog insie the lines disable the spin cycle ?
Posted on Nov 22, 2008
How do i clean filter at bottom of hotpoint condenser tumble drier. Water coming out at base.
if you mean the condeser itself ...it just pulls out..........best way to clean is with a hosepipe gets all the fluff out....but.if you have water leaking...........best bet is to check the tank at the rear.....at the bottom of the base.....the tank operates via a piece of plastic or fibre which floats up as the tank fills.....which inturn hits a micro switch
...setting the pump going to pump the water to the empty tank........check the float first.........
cheers
May 02, 2017 | Hotpoint Dryers
Why is my Tumble Drier keeps beeping without stopping a few minutes into the drying program?
It sounds like the carbon brushes are probably worn down - they ride on the drum (in the top ) and determine the amount of moisture left in the clothes for drying - they connect to the drum and the metal bar inside the dryer - A wet clothing item conducts between the two giving the dryer an idea of how much moisture is left in the load - equal to how much time / heat is needed to dry load as required. These brushes wear out and need to be replaced over time
Aug 03, 2014 | Miele Washing Machines
Hooverlightflashing
A tumble drier should only be used to dry clothes that have been through a hydro extractor (spin drier) first. They are not designed to put wet washing in. Dripping wet washing must first be wrung out or else the excess water will run out the bottom. If it is a washer/extractor, look for leaking pipes or door gasket.
Nov 25, 2013 | Dryers
Air conditioner does not work
You need to add water, to your water jug, or add coolant. When in the progress of doing so, make sure that nothing is leaking. Below...
Jun 08, 2012 | Cars & Trucks
Water leaking from underneath water tank.
I rang Saeco service centre about my leaking water tank and they posted me a new tank - no questions or need to return the faulty item. I believe there may be a bad batch of tanks which leak because of faulty valves.
Mar 24, 2009 | Saeco Primea Cappuccino Touch Plus Coffee...
Drum doesn't move or spin
Oct 18, 2008 | Kenmore 43142 Front Load Washer
Asko T741 - Thermostat keeps cutting out
Ken from Mecheltec suggests removing condensate sump and pump assembly and servicing it. Clear condensate hoses from lint and debris then carefully reinstall assembly. You should be ok.
Oct 06, 2008 | Asko T741 Dryers
White knight 767 tumble drier
If the rug was very heavy you could have burnt up the motor. If it will restart after it cools off, replace the motor and clean out the vent system.
Good luck.
Dec 08, 2007 | Dryers
Dryers Logo
143 people viewed this question
Top Siemens Dryers Experts
Tim Whalen
Gerry Harvey
Gerry Harvey
Mike
Are you a Siemens Dryer Expert? Answer questions, earn points and help others
