How do you set up a bush lsd33/c micro stereo?
Signal unlock display on dennon d-m39s micro stereo unit
Try checking the sound settings on your tv. You may want to change the output to PCI instead of dolby.
Nov 14, 2013 | Denon D-M39S 192kHz/24-Bit Micro Component...
What should i set the micro switch on the back at?
Power:
2 ohm stereo (per channel): 975W
4 ohm stereo (per channel): 660W
8 ohm stereo (per channel): 400W
4 ohm bridge-mono: 1950W
8 ohm bridge-mono: 1320W
Load Impedance: Safe with all types of loads. Rated for 4 and 8 ohms in Stereo mode, 4 ohms in Bridge-Mono mode
Voltage Gain to 1-kHz, 8-ohm rated output,
CE 1000:
30.5-dB gain at 1.4-volt sensitivity;
26-dB gain at 2.34-volt sensitivity.
CE 2000:
32.1-dB gain at 1.4-volt sensitivity;
26-dB gain at 2.83-volt sensitivity.
Required AC Mains: 50/60 Hz (North American units are 60 Hz only); 100, 120 and 230-240 VAC (+/-10%) units are available.
AC Line Current,
100 Volts: 11.4 A;
120 Volts: 9.5 A;
230-240 Volts: 5.0 A;
At Idle: All amps draw no more than 90 watts.
AC Line Connector: NEMA 5-15P (15 A).
Sep 07, 2012 | Crown CE2000 2-Channel Amplifier
Volume will not raise - does this need a repair? Is this common ? Is there a wonderful set of earphones that would fix this. Office is on a very tight budget.
Try different tapes, if the audio is low from all tapes you can try to used a micro cassette head cleaner at http://www.tvps.com/Products/Certron-MCHC-Micro-Cassette-Head-Cleaner---New__CE-MCHC.aspx other option is to get a really good headset this model is incredible for Mono or stereo units at http://www.tvps.com/Products/ECS-Deluxe-35-mm-Mono--Stereo-Over-Head-Headset---New__ECS-OH3-prd-5MSVC.aspx or just Send an email to service@tvps.com or call (805) 644-9525. Please indicate model, serial and detailed description of problem to service your unit.
Aug 29, 2011 | Olympus Pearlcorder T2020 Desktop Cassette...
We have a Franke Evolution coffee machine and the fault 'E43 Motor Time Out' error keeps appearing. Could you please advise me what this fault is. Is it related to the upper head micro switches and if so...
E43 error motortime out refers to the brew unit not being "sensed" by the micro switch, the most common fault is the micro switch failing. other causes are the failure of the brewmotor itself, or bushes within the brewer. The micro switch is simple to replace as its obvious withits location. the other however will require the expertise of an engineer.
Sep 30, 2010 | Franke Evolution
I have a Fender G-DEC Guitar amp and it has an output for recording, can I connect it to the BOSS MICRO guitar input? The Fender amp has many rhythm functions which I am very familar with, besides it has...
you can use the line in/mic stereo input, but you will have to turn the input level way down to around 1 or 2.
i assume that the record outputd a re rca outs. you can get a rca stereo to 1/8 inch stereo adapter, like the ones they use to connect protable cd palyers to recievers, and then get a 1/8 inch stereo to 1/4 inch stereo adapter form radio shack to complete the connection.
Aug 15, 2010 | Boss Micro BR Digital Recorder
Connecting a turn table to a micro stereo system
You will need the following to connect this to that system:
1) Phono Pre-amp
2) 3.5mm to RCA adapter or 3.5mm 'Y' cable to RCA
3) Turntable
Your turntable will connect to the Phono Pre-Amp input. This pre-amp will also have an output. This output is RCA, from here you connect to your system using the 3.5mm adapter or cable.
That's it.
- Davis
DJ Pro Audio
www.djproaudio.com
www.repairnyc.com
Aug 07, 2008 | Audio Players & Recorders
Bush tv picture
Do you have any large stereo speakers near your tv? They have large magnet in them. It sounds like your screen is magnetized Your set has an automatic de-magnetizing circuit built into it. This circuit could have failed. If you have large speakers near your tv, they need to be moved,but you did say that you're sure that no magnetic field was near your set. Stargazer
Jan 09, 2007 | Bush 5693D 24" TV
81 people viewed this question
 Grubhead
Grubhead
