Question about Kenmore Refrigerators
Kenmore refrigerator m/n:71299100 s/n:EL22382910 The "frost-free" freezer is icing up, and the defrost heater isn't turning on when it should to defrost it. Also the fridge isn't cooling, & there's condensation all over the inside walls (top&sides). Defrost heater is functioning, but not when it should be. I think its a combination of the defrost control board, & a bad sensor maybe, but not 100% sure
  • 1314 Answers
SOURCE: Auto defrost not working
a manual defrost will help in the sense that it will healp save your food now if you dont mind spending a little cash may i suggest you go buy a eurika 350 hand held steamer its great for defrosting and about 1000 other thuings around your house you canget it at lowes places like that after defrosting the unit will freeze again in about two to three days depending on how many times you open your door reply to this thered with the appox age of your unit and i can better advise from there some times as in the case of a stuck theroma stat if seen it fix them but i wouldnt count on it hold my rating tii we are done
Posted on Jan 19, 2008
bobotfel
  • 236 Answers
SOURCE: samsung fridge RS2630SH, side by side, icing up on freezer.
You have to pull out the sensor from the board and test with tester, both sensor should read the resistance of 10,000 to 20,000 ohms. The reading that you show is very low it means that the thermistor is out of range and need replacement.
Posted on Mar 08, 2008
  • 236 Answers
SOURCE: Defrost problem on a LG Bottom Freezer Refrigerator
You have a problem in the automatic defrost circuit. I suppose you know that !
You may have to disconnect the power from your refrigerator and use hot water in a pot or a hair drier to melt the ice away. You'll have to remove the back cover of the freezer and clear the ice from there too. You most likely have an open defrost heater and/or defrost thermostat.
If you have a tech sheet which is normally stored near the compressor section, you can trace the circuits and find your problem. If you're not comfortable with this kind of work , you'll need to call a tech to check it out for you. If you don't do something soon you'll lose all the food in both your refrigerator and freezer sections.
I hope this helps you
Stargazer
Posted on Mar 19, 2008
  • 1073 Answers
SOURCE: Refrigerator Defrost Troubleshooting
you cannot do this
just check the defrost heater and the bi metal, if they check good then the adaptive defrost control is bad
Posted on Apr 25, 2008
SOURCE: refrigerator keeps running
I have the same problem. I called a service rep for G.E. and he said that there are 3 thermodisc
sensors behind the white evaporator cover. He gave me a price to repair that was completly out
of range for the problem. I paid him for his service call and sent him on his way. I then decided to
to order the parts from a factory online parts center at less then half the cost of my estimate not
to mention that when I was ordering the part the Factory emailed me a complete parts breakdown showing the Thermodisc and that my unit only has 1 thermodisc not three installed from the factory.
I ordered 2 one for a backup just in case. I deiced the buildup and installed the disc after 24 hours the refrigerator was working normal for about 4-months. Once again the refrigerator iced up and stopped cooling so I called the factory tech support and they told that it is normal to have some ice on the cover of the evaporator and the thermodisc is at that point supposed to open the cooling circuit to let the unit go into defrost mode and then close again. The Tech said that I had a bad
Thermodisc again so I put the spare one that I ordered in and it also worked for about 3 months
now I have the same problem ????????
Brad
Posted on Sep 14, 2008
Kenmore Freezer 106.727581: The freezer ices up and the temp goes up to 34 degrees. If I manually defrost it, it goes to 5 below zero in about 6 hours. How can I determine which of the below need to be...
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited. Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system: The defrost timer The defrost thermostat (also called the bi-metal switch) The defrost heater. To determine if the defrost heater is burned out, watch this part testing video
Aug 21, 2011 | Kenmore Freezers
My kenmore refrigerator is glowing orange in the freezer.
That is completly normal, what your seeing is the glow of the defrost heater and its usually on for about 15- 20 minutes every 2-3 days,if you have your manual that came with the ref it will tell you that is't completly ok
Most people hear the term frost free but that is a misnomar and if a refrigerator isn't frosting it isn't working,their is manual defrost types that you need to defrost and automatic defrost types that a heater comes on and melts the frost after the ref. has for for appx 16 hours. Not 16 contunious hours but 16 hrs. of running (10 minutes on and 2 hours off takes awhile to accumalate 16 hours of run time)
Jul 26, 2011 | Kenmore Refrigerators
Frost free freezer keeps frsoting up. It's a french door refrigerator with the freezer on the bottom. The vent is not blocked. The door has not been opened frequently. The appliance is only 9 months...
Sounds like a defective defrost timer
If its a frost free upright freezer and the evaporator is frosting up with a snow like frost you have a defrost problem.. defrost themostate, heaters, or timmmer
Also note that
Dirty condenser coils are not the problem. It's most likely the defrost timer or defrost heater. The heater should come on about 3 times per day to melt the ice on the evaporator coils. If the defrost timer is not turning on the heater or the heater is burnt out, the coils will freeze up......
Hope this helps
Jul 28, 2010 | LG LRBN20510WW Bottom Freezer Refrigerator
Fridge not cool enough but frosty at the back
Since you are getting frost in you frost free refrigerator, tell me that the defrost circuit has a problem. It is made of a defrost timer/module, defrost heater and defrost thermostat. What should happen is that the defrost timer should periodically turn off the compressor for about 30 minutes and turn power to the defrost heater via the thermostat. The heater is attached to the evaporator coil and melts any frost build up on those coils.
It sounds like the defrost circuit has not been working for a while because the ice build up is not allowing the air to circulate around the coils to cool the refrigerator. The typical failures to the defrost circuit are the defrost timer motor fails to advance, or the defrost heater burns out. Hope this helps you.
Jul 14, 2010 | Kenmore 64802 Top Freezer Refrigerator
Kenmore Coldspot model 106 - Snowing in freezer!
its not defrosting. check heater operations. bimetal near heater. check defrost timer
Feb 08, 2010 | Refrigerators
Frost free freezer not defrosting
Sounds like you need a new defrost heater. Check your manual for it's location. Basically all a defrost hearer is , is a glass tube with wire inside of it, that acts as a resistor, it heats up, and melts all ice. Remove all food to another freezer, thaw freezer, and check heater if it is bad, it will look like a burned out halogen bulb.
Nov 10, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice getting accumulated even it is frost free
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Sep 07, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
Frost free freezer icing up
It should still be covered under the warranty.
Sep 02, 2009 | Amana ATB1832AR Top Freezer Refrigerator
Kenmore won't cool down.
I you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 15, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Kenmore upright freezer
you have a defrost system problem. Could be the defrost timer or defrost heater or defrost thermostat. Bottom filled with ice could be from a plugged drain system. Where you termed "condenser coil" is in reality the "evaporator coil".
May 24, 2008 | Zanussi ZEBF250W Bottom Freezer...
Refrigerators Logo
216 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
