Question about Lasko 2554 WIND CURVE Fan
My Lasko will not turn on, it just went out what happen?
How to grease or oil a lasko fan model u15700
when a fan makes noise while turning,means the bearing is,
starting worn out.best to replace it.when its not turning,its allreddy,
overheated.
Jun 05, 2014 | Lasko Max Performance Pivoting Utility Fan...
New lasko heater keeps shutting down
fatly over heat switch or tilt switch some r very picky
Dec 10, 2013 | Lasko Heating & Cooling
How to open a lasko 3520
how to open lasko 3520 and change the fuse
Aug 31, 2012 | Lasko 3520 20-Inch Cyclone Fan
Won't turn on. It gave me a beep when I plugged
Have you cleaned the filter that's on the back? This has happened to me, and I just took the filter out and cleaned it, and it worked fine after.
Dec 27, 2009 | Lasko 5130 Ceramic Compact Heater
My Lasko 40" Tower fan stopped working.
ok everybody who has this model #2534 it seems that the motor has gone bad so you have two choices you eighter find the recipt where you brought it from but there a catch 1 year from the day you brought it from. second choice buy a new motor. third choice buy a new one. sorry!
May 13, 2009 | Lasko 2534 40", Executive Tall Blower...
Heater won't get hot
I went on several websites until I located the company. Recieved a call from them to day and they are sendin me a manual.
Dec 15, 2008 | Lasko 5520 Ceramic Compact Heater
Lasko 5350 will not power up. Tempermental.
I had the same problem with mine,, I called the 800# and they told me to either vacuum it out weekly or use a hair dryer to blow out the vents, both solutions seemed to have work for me ~ good luck
Nov 14, 2008 | Heating & Cooling
Lasko 2554 Wind Tower Fan
I have a Lasko HVB, but this might apply to your fan:
Without taking the thing totally apart, here's an idea you can try: The power cord on some models (like mine) has a "warning" tag. I had the damn thing all apart when I noticed this. (Well, who reads 'em??) Seems like there's a mini-fuse in the PLUG itself that, when it blows, there's nothing you can do about it except send it for repair to a factory authorized yadda yadda yadda. Who's going to do that??
If you plug in and NOTHING HAPPENS, here's what might turn out to be an cheap and easy fix: cut off a few inches of the plug end of the cord and go buy another plug at Ace. Heavy duty might be appropriate: don't think I'd want a lamp plug on this baby. Get one that's easy to install. Bring the cut off piece and they'll help you find exactly what you want.
If you want to open it up, there's a screw behind the Lasko medallion, remove that and you can snap out the grille. You can see where the cord comes in from the back of the blower housing. Test the line voltage. If you're not getting about 120VAC, it's the plug.
If that's not it, IMHO, without some knowledge or a schematic, you're screwed. That'd be me. It wasn't the plug.
-Chuck
Jun 08, 2008 | Lasko 48" Xtra Air Tower Fan with Air...
No power
Go to the Lasko Website and get a new one for free. They were recalled
Jan 17, 2008 | Lasko 5540 Ceramic Compact Heater
Lasko 2554 WIND CURVE Fan Logo
49 people viewed this question
Top Lasko Dryers Experts
Shehu Pro
Shehu Pro
Jay Finke
Jay Finke
Are you a Lasko Dryer Expert? Answer questions, earn points and help others
