Question about Foxconn (945G7MA-8KS2) Motherboard
When turn on system, get solid beep. Just replaced power supply. Problem now also occurs with old power supply. Did I connect something wrong?
    Master:
  • 497 Answers
Check your memory modules
Posted on Oct 14, 2010
I have a Antec performance all tower that use too beep when turned on now its just a solid orange light and does nothing
All PC's beep when turned on, it is a sign that the system has passed power up test. If it is not beeping then the system is faulty. It could be a power supply failure or something else.
May 27, 2016 | Computers & Internet
Blinking green light, will not power on
Did you have a surge protector that your computer was plugged in if not it may have done something to your power supply good luc hope this helps Merry Christmas
Dec 09, 2017 | HP Pavilion a810n (PP164AA) PC Desktop
Dimension 3100 wont turns no power button light there is also an green light on motherboard cpu and power suplly fans working but wont bot up
Contact technical assistance.They will most likely ask you to send it back to repair.
This chart is where I got my conclusion.
Power Light
Problem Description
Suggested Resolution
Solid green
Power is on, and the computer is operating normally. On the desktop computer, a solid green light indicates a network connection.
No corrective action is required.
Blinking green
The computer is in the suspended state (Microsoft® Windows® 2000 and Windows XP).
Press the power button, move the mouse, or press a key on the keyboard to wake the computer.
Blinks green several times and then turns off
A configuration error exists.
Check the diagnostic lights to see if the specific problem is identified.
Solid yellow
The Dell Diagnostics is running a test, or a device on the system board may be faulty or incorrectly installed.
If the Dell Diagnostics is running, allow the testing to complete.
If the computer does not boot, contact Dell for technical assistance.
Blinking yellow
A power supply or system board failure has occurred.
Solid green and a beep code during POST
A problem was detected while the BIOS was executing.
See "Beep Codes" for instructions on diagnosing the beep code. Also, check the diagnostic lights to see if the specific problem is identified.
Solid green power light and no beep code and no video during POST
The monitor or the graphics card may be faulty or incorrectly installed.
Check the diagnostic lights to see if the specific problem is identified. See "Video and Monitor Problems" in your Owner's Manual.
Solid green power light and no beep code but the computer locks up during POST
An integrated system board device may be faulty.
Check the diagnostic lights to see if the specific problem is identified. If the problem is not identified, contact Dell for technical assistance.
Mar 06, 2011 | Dell Dimension 3100 PC Desktop
System was up an running then, Then shut down
It sounds to me like it overheated and something burnt out, but I could be wrong. The main pieces in a desktop computer are: power supply, motherboard, cpu, ram, and video card (which is on the motherboard for lower end systems.)
Each one will need to be properly tested to find out which part(s) is(/are) failing, and the failing part(s) will need to be replaced.
Apr 19, 2010 | HP Compaq Presario SR1110NX PC Desktop
Gateway 503gr has no power, the standby light flashes green when I remove power. Tried new PS and the standby LED stays lit. I then tried both new and old PS disconnected from board and shorted...
Disconnect everything from the motherboard except the power supply connections and cpu fan. Install one stick of RAM and connect your monitor. Then try starting up. See if you get any BIOS boot messages. This will tell you that the board and processor are okay.
With what you say you've tried already, I'm thinking you might have a bad processor. Most every other problem would result in some kind of error like POST beep codes or messages on screen. If the system still doesn't boot with the bare minimum parts installed, replace the processor.
Mar 02, 2010 | Gateway 503GR PC Desktop
My Liebert PSA itON 600 UPS keeps beeping when i turned it on
To figure out what's wrong with the UPS, first you have to do a few things.
When calculating the rating a UPS can handle, it's voltage x amperage. If it's Watts multiply the number by 1.67 to give the rating of the device.
Add up all the devices (use the power supply rating in the computer) as well as any other device, and add them up.
If this rating was exceeded, then you have overloaded the UPS. If it was too long that you did this, then you wore out the battery.
When a UPS beeps even when not connected, that means the battery is very weak.
If the battery is more than 3 years old, it will need to be changed. If the online tests of the unit were done and the battery doesn't need replacing, then other parts of the UPS need fixing.
Check the battery.
Jul 27, 2009 | Liebert PowerSure ProActive PSA700 UPS...
Computer turns on but now booting up
Make sure the memory stick is securely installed on the motherboard. Also make sure that any additional cards in the expansion slots are also securely installed.
I had a similar problem on another machine and it was due to a memory stick that wasn''t fully secure, I reinstalled the memory stick and made sure it was a solid connection and it resolved my problem.
Please let me know if this helps you.
Feb 03, 2009 | Dell Dimension 3100 PC Desktop
Workstation POST
Answer is C, D, E
Nov 13, 2008 | Computers & Internet
Motherboard power on but no display.
Greetings!
Check first if all the cable, wire are connected properly.
See also at the back of your power supply if the switch is on, cause some power supply have switch aside from your system unit.
Usually once you open your computer you can hear a beep sound if their is no beep sound means something wrong with your computer.
As you turn on the computer see the fan of your power supply at the back of your unit if it revolves if not something wrong with your power supply, if the fun of your power supply re volves it's your motherboard have something wrong.
Thanks
Nov 11, 2008 | Intel D845GVSR Motherboard
Hercules switching power supply 500 wat max
yes 20 pin connecter power supply is ATX(advance technology extended )power supply and old which was low watt and 24 pin is EATX (enhaunced advance technology extended) power supply is new and high watt so 4 pin connecter can be detached from 24 pin connecter and can be fitted in 20 pin connecter
Oct 18, 2008 | Guillemot Hercules Dual Fan ATX 450W Max...
Foxconn (945G7MA-8KS2) Motherboard Logo
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
David
David
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
