Question about Compaq Presario X1000 Notebook
Notebook screen stays dark
I read your post about a dark screen wich still shows the image in some bright light. i'm having exactly this problem. you said the inverter needs to be fixed and that it isn't very expensive. could you clarify a bit more? what and where is the inverter and can i change it myself?
    Problem Solver:
  • 11 Answers
Make sure you check under a bright light that you can actually see the image.
This model is notorious for a bad video card (Radeon) that makes it seems like something is wrong with your screen but if you press down just above the keyboard it will work while you are holding it.
If you see an image you have one of two things:
Bad inverter
-or-
Bad backlight bulb
If you saw the screen turning pink or red on cold starts before your backlight is burned out and it's just faster and easier to replace the LCD.
If you just saw a flicker and then screen went black the inverter is the problem.
The inverter is a little circuit board that sends power to the backlight bulb, so even though the bulb is good it won't get power to light up. If the bulb is bad replacing the inverter won't change anything.
The inverter is located just below the LCD. Disconnect AC and remove battery.
Remove the rubber plugs along the top and the two oval stickers on the bottom corners. They cover the screws. Remove the screws and carefully pop off the bezel with your fingernails moving around the edge as you go.
Under that you'll see the inverter. Use a fingernail or flatblade to carefully pry the connector off and then unplug the wire harness on the other end. Install the new part. Test it.
If it's working, then reassemble. If it's still dark the backlight is shot or your inverter was a dud.
If it's the backlight, you can remove the screen now that it's open. There are just a few more screws on each side of the LCD and removing a couple on the lower brackets can help you temporarily raise the screen up from the lid to more easily access the screws on each side.
The connector on the back is very delicate. Walk it out with your fingernails and try to reuse the tape if you can. Never pull by the wires.
Replace and test again.
Again, make sure you can POSITIVELY see an image on the screen before doing this repair.
As i mentioned earlier the X1000 has a bad video card the makes the computer boot up and show a black screen and even boot into windows but will NOT display video on the LCD or even the EXTERNAL video out. You can test this by plugging it into a desktop monitor.
That will be $300 please!
Posted on Jan 03, 2009
My screen is VERY dark...I can shine a light onto it and I can see it...how do I repair it?
On your laptop there is an Fn (function) key and another button showing the image of sun. Keep Fn pressed and then click the "sun" button to increase the brightness of your screen.
Regards,
nicolasiac
May 07, 2010 | Toshiba Satellite M55-S141 Notebook
The brightness is very dark. Any nightime scene
Your CRT's getting old. Plus dust on lenses don't help much. You have to open front frill (below screen) and back of the TV. Clean up lenses using dry paper towels, do not wet.
In front of the TV after grill remove center cover and locate "black box" that have 6 potentiometers on it that looks like plastic adjustment screws for philips #2 screwdriver slots. 3 of them should read "Focus" These you don't touch. Another 3 reads "Screen". Put some still image on your screen (like paused DVD movie frame). Carefully add brightness in all 3 colors trying to avoid horizontal lines appearance. If lines show up, just turn it back a little. Try to keep color balance looking at the picture.
This procedure will brighten up image but further reduce CRT's life.
In case that you posted wrong model here and you have DLP Projection TV - just replace the lamp.
Mar 09, 2010 | Pioneer SD-643HD5 64" Rear Projection...
In my w180 image is clear and bright in the LCD screen but when i downloaded the images to my PC it shows poor lighting and dark images pls help me
The lcd screen on your camera is back-lit and shows a brighter picture than the one you actually take. If you can turn down the screen brightness that may help. You could also raise the "exposure compensation" setting and experiment until you find a setting you like.
Oct 23, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Display is dark
try to adjst the brightness and the contrast..
Feb 21, 2009 | Dell Inspiron E1505 Notebook
Screen on lap top has gone very dark and dont no how to get it back to normal
there are 3 possibilities I can think of
  1. The brightness or contrast has been turned down (check your manual)
  2. The power save settings are telling monitor to be at low brightness to save power (check manual)
  3. the back light has failed
Post back exact model notebook and I may be able to assist with more specific advice
Jul 08, 2008 | Toshiba Computers & Internet
Hi
adjust the brightness of the screen may u hav accidently turned to zero brightness.
if this doesnt solve then let me know.
May 01, 2008 | Compaq Presario X1000 Notebook
Screen went dark (almost completely)
check your power cord and make sure it's plugged in all the way, and if it is, check your brightness setting.
Usually it's the Fn key + an arrow key. Make sure the brightness is up all the way
Dec 12, 2007 | Dell Inspiron 6000 Notebook
Acer Aspire 3000 pc screen problem
Have u tried re-installing the video drivers?
Nov 27, 2007 | Acer Aspire 3000 Notebook
Scceen flickers on and off
You'll have to describe the problem in a bit more detail, because it could be a couple different things based on when it goes dark and what "dark" means.
I'm going to guess that the monitor is turning itself off after that second, but you might be describing that it doesn't say it's off, but there is no image (or maybe a really faint image that you can see in the bright light). Try checking it in the bright light after it goes dark. Also, does it seem different if you bang on, shake, or turn it upside down. Don't do this if you haven't already as it will more likely damage it than fix it, but if you have already banged on it, does it change?
I'm working on the same model with a similar problem (not sure it's the same) and will be ripping into it soon and will post the results.
Nov 02, 2007 | Liquid Video A170E101 Monitor
Compaq Presario X1000 Notebook Logo
165 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
