Question about Kenwood KDC-MP205 CD Player
The system will not find the Aux function anymore meaning I can only use the radio and CD functions. I would like to be able to use my iPod
  • paul_farus Oct 14, 2010
    how do you get to the setting mode to enable it?
  • 10,594 Answers
Go to Built-In Auxiliary input setting mode and enable Aux On1 mode to get Aux Input active in unit.
Details are available in user manual page-22
Click Kenwood Support link to download free copy of user manual for KDC-MP205 that will explain it in details.
Thanks.
Posted on Oct 14, 2010
  • Shahid Electronics
    Shahid Electronics Oct 14, 2010
    Press SRC button and select Standby display then change settings with <<, >> buttons.
    Or press Menu button for 2 seconds to display menu then do the required changes.
I have a Pioneer DEH-P5200 and i plugged the aux chords in the back to my ipod but dont know how to switch to the aux mode on radio...
OK - had the same problem and got it finally figured out. Power the unit on the ignition key. Press and hold the source button so the unit shuts off. With the unit shut off press and hold the function button (the key is to hold the function button down) The clock, aux etc will show on the screen. Press (but do not hold) the function button and it will move to each function. When you get to the AUX press the ^ button and the will switch the AUX to "on". Once you know, like everything else, it's pretty easy.
Nov 29, 2010 | Pioneer DEH-P5200 CD Player
Ipod not working on a JVC KD331 cd/radio car player
Check your stereo for a button that says "Aux" or a "Function" button. It could also say something else depending on the radio. The one in my 93' Mustang says "Band" and in my truck it simply says "iPod" Just mess around a little bit and see what you find.
Apr 11, 2010 | Car Audio & Video
There is a auxiliary button on the sony cdx-m8800. Is there a way to hook up an IPOD? The stereo also has MP3 written on the inside face. Thanks
Contrary to the below Expert's testimony, the UK CDX-M880 has a REAR AUX connector that will enable you to play your iPod through your car's stereo.
You will not be able to control the ipod's interface through the radio. You will have to use the control on the iPod .
You require a Male 3.5mm extension cable like the following...
a5e60c6.jpg A 4-6 foot length is recommended, as the cable will need to be routed from behind the radio to a place your iPod can be easily manipulated.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 18, 2009 | Sony CDX-M8800 CD Player
Getting the ipod to work on my radio
You have to have something connected to aux.
  1. Use multi control to activate aux the function name tag is highlighted.
  2. press multi control to turn aux on aux on appears on the display
heres a link to the manual:
http://www.pioneerelectronics.com/pio/pe/images/portal/cit_11221/86592493Operation%20Manual%20DEH-P860MP.pdf
Jun 02, 2009 | Pioneer Premier DEH-P860MP CD Player
Put in new car battery, now can't get aux to work
Hi there
hold down the source button to turn off the unit (unit must be off)
now hold down the function button till it beeps once it has done this press the function button i think 3 or 4 times and you will get a message on your deck unit saying (aux - on,off) turn on and press the source button to turn the unit back on to the CD or radio now press source button2 or 3 times till Aux shows up (press means push it let it go) (hold means don't take your finger off button)
hope this solves your problem
Oct 11, 2008 | Pioneer DEH-P4700MP CD Player
How do I turn on the "external aux" for my pioneer DEH-p7000r
You'll need an adapter cable such as this one:
http://www.crutchfield.com/App/Product/Item/Main.aspx?search=ip+bus&i=469PIOPRCA
The adapter cable will convert the changer port on your head unit into an AUX input with dual RCA jacks. Once connected, the head unit will detect the cable and allow it to be another source (i.e. radio, cd, aux).
To connect your iPod to the adapter cable, use any iPod cable or dock that outputs to male RCA plugs.
Apr 01, 2008 | Pioneer DEH-P7000r
Hooking up an Ipod to my stereo
I'm having the same problem. I pressed the "function" button about 50 times and AUX never showed up.
Jan 06, 2008 | Pioneer DEH-P3700MP CD Player
I have a pioneer DEH-P3000
Hi nhmteam. I have the solution for you: 1. With your DEH-P3000 turned off, press your FUNCtion button. It's a tiny button towards the upper right of the faceplate. Hold it down until you "ALARM OFF" or "ALARM ON" on the display. Release the button. 2. Press the FUNCtion button again and you should see another feature. I don't remember how many features you need to cycle through, but keep releasing and pressing the FUNCtion button until you see "M-CD ON" on the display. If you miss it just keep going and eventually it will come back. 3. On the right side of your faceplate there is a button with 4 arrows. You will need to push the up or down arrow until the display reads "M-CD OFF". If your display already reads "M-CD OFF", kip to the next step. 4. Press and release the FUNCtion button again and you should see "AUX OFF" on the display. Again press the up or down arrow until the display reads "AUX ON". 5. Now, turn on your unit, then press the INPUT button until the display reads "AUX". You are now ready to use your iPod in the way you always did. Keep these instructions for the future since I believe every time you disconnect the unit from the battery the unit will reset itself and disable your iPod cord. Best regards - TomR
Aug 30, 2007 | Pioneer DEH-P3000 CD Player
AUX inputs
Turn the ignition key to on or accessory position, turn the stereo off, then hold the function key for a couple seconds, the stereo will turn on and you scroll through the menu with the left and right arrow buttons and change settings with the up and down buttons
Feb 25, 2007 | Pioneer DEH-P6800MP CD Player
Kenwood KDC-MP205 CD Player Logo
223 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
